So you push your 1st gen offroad - what cracks next?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Squeaky Penguin, Sep 27, 2019.
  1. May 24, 2021 at 8:47 AM
    #281
    cynicalrider
    cynicalrider #NFG
    Jersey
    At 11:20 lol
    https://youtu.be/KTym2EXMTgQ
    jubei likes this.
  2. May 24, 2021 at 8:47 AM
    #282
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    The ARB in my 8.4 axle that was set up by ECGS did leak occasionally, seemed like it did it more when it was cold (snow wheeling, etc). The ARB in my FJ axle has been bulletproof so far, and was easy to set up. Honestly that might be one of the best features of the 9.5, it is probably one of the most straightforward gear setups for those of us just getting into doing our own gears. Personally I would definitely trust the ARB over a 25 year old e-locker in who knows what condition. Or a Harrops like Monte said, although that's $$$.
    Welding on new shock mounts will be a joy compared to cutting off all the 3/16" link brackets and coil buckets though, what a pain in the dick.
    slander likes this.
  3. May 24, 2021 at 8:50 AM
    #283
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I've seen a few people with ARB issues, but mine was working well yesterday so it's on year 6 with zero issues.
    I wouldn't get one of those Harrops given the 'feature' that they unlock when you roll backwards. Sounds terrible if you have a manual.
  4. May 24, 2021 at 8:56 AM
    #284
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Is that really a thing? I never heard about that before. I thought the point of a locker was to remain "locked", lol
    otis24 likes this.
  5. May 24, 2021 at 9:28 AM
    #285
    Squeaky Penguin
    Brett
    That was an awesome day, and one of the examples I was thinking about on ARB issues. Sorry Ryan.
    They did have a bad batch of seals that I believe have all been phased out. I think Ryan's has been working ever since he got the seals replaced.
    When I researched them a couple years ago, I read about issues with sporadic disengagement and issues when changing direction. Was a definite no-go for me at the time. Maybe they're better now? :notsure:
  6. May 24, 2021 at 9:39 AM
    #286
    jbrandt
    Justin
    Hey @Kwikvette, didn't you have a harrop on your taco?
  7. May 24, 2021 at 9:42 AM
    #287
    Kwikvette
    Fresno County
    4 run, 2 don't
    I had bought a Harrop for the front awhile back but went against installing it.
    I went Harrop due to zero maintenance needed; over time ARB needs their seal replaced and I didn't want to bother taking apart a front diff after finding out the hard way when it wouldn't engage.
    I'll go Harrop on the next vehicle I decide to modify.
  8. May 24, 2021 at 9:53 AM
    #288
    jbrandt
    Justin
    Just curious if you had heard about the disengaging thing.
  9. May 24, 2021 at 11:02 AM
    #289
    Kwikvette
    Fresno County
    4 run, 2 don't
    I read no such thing and straight from ECGS, they've never had a Harrop come back, ever.
    They've had ARBs sent back, or diffs with an ARB.
  10. May 24, 2021 at 11:03 AM
    #290
    jbrandt
    Justin
    Yeah, I hadn't heard about it either...
  11. May 24, 2021 at 11:06 AM
    #291
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm all for cry once and buy once, which is why I went Harrop.
    But for the next vehicle, we'll see what's available.
    Might be an older Yota solid axle or Land Cruiser.
  12. May 24, 2021 at 11:10 AM
    #292
    jbrandt
    Justin
    But those aren't tons...
  13. May 24, 2021 at 11:22 AM
    #293
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    https://forum.ih8mud.com/threads/why-e-locker-should-be-locked-before-pulling-axle-shafts.1050317/
    Post #20 talks about if it ever gets bound up and the axle shaft you have to cut it out.
  14. May 24, 2021 at 11:34 AM
    #294
    Kwikvette
    Fresno County
    4 run, 2 don't
    And you're a red head but I still talk to you.
    Compromises brother :fistbump:
  15. May 24, 2021 at 11:45 AM
    #295
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It's a saftetly feature to keep axles from breaking.
    It only does it for a very small rotation and only when a change in direction happens.
    https://www.youtube.com/watch?v=nT_H6rpd-Ck
    Doesn't seem to be an issue I think. I'd run one in a heart beat.
    Reh5108 and jbrandt[QUOTED] like this.
  16. May 24, 2021 at 11:46 AM
    #296
    Blackdawg
    Monte
    Wyoming/St. Louis
    Doesn't seem to be a big issue to me. It's just to keep axle bind from happening and to save your axle. I doubt it would be a big issue.
  17. May 24, 2021 at 12:05 PM
    #297
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I've always kind of thought the same about the U-bolt flips. I would think that's a good contender to some of these leaking axles at the perches.
    Compared to the stock U-bolt config with the bottom bracket that cradles the whole axle, there's a lot more of a contact patch with the axle tube than just two U-bolts.
    I can't think of anyone with a stock U-bolt setup that's had a leak from the same places
  18. May 24, 2021 at 12:07 PM
    #298
    jbrandt
    Justin
    :rofl:
  19. May 24, 2021 at 1:39 PM
    #299
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It still leaks sometimes, but I think it stays engaged. If I did it again I'd go with something else. Could be an issue with quality control at ECGS.
    Interesting observation.
    I think this video describes what Brett is talking about. https://youtu.be/1nYZo--7Xh4
  20. May 24, 2021 at 1:54 PM
    #300
    cynicalrider
    cynicalrider #NFG
    Jersey
    Seems it's an "If" scenario not a "It happened" scenario. Mostly that thread seems to discuss the proper way to pull the axle shafts and the risks of not doing so correctly. :notsure: Doesn't seem like it's enough of a reason to go ARB vs the electric locker it already has in place.
    You might have a point there, I definitely feel like my axle housing looked slightly deformed.
