So you wanna put big tires on your 2.7 powered truck
Discussion in '4 Cylinder' started by TYetti, Aug 4, 2019.
  1. Aug 3, 2020 at 5:52 AM
    #121
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I wouldn't burn the resources (time and money) on a regear to only go up one size. Prepare for the future, somewhat, when gearing was more or less what I was told by many other 2TR 5spd owners. Specifically those with 4.88 and running 33 or 35 inch tires, which was what my dream was then.
    I'll be going to 35s in the next couple weeks. Already pulled liners and flares.
    whatstcp likes this.
  2. Aug 5, 2020 at 2:03 PM
    #122
    TYetti
    TYetti [OP] 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Just for reference I'll be moving to 5.29s my trial setup overwhelmed the 4.88s, moving forward with the add-ons I need to accommodate my wife and two dogs for two or more weeks on the road, needs moar low
    Hartford likes this.
  3. Aug 5, 2020 at 2:44 PM
    #123
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I don’t know where you live, but I’ll share my experience. I live in Maryland, it is not considered mountainous here. So when I say hill, I mean a small hill. With 4.88’s and 33’s (essentially a 285/75) I have a really hard time maintaining highway speed (65mph) no even the smallest grade. Rolling hills aren’t so bad if I can get a running start. But even a shallow grade if it’s pretty long will have me holding up traffic. On the bigger hills we have in the west part of the state, I am crawling up them at 45mph with the motor screaming at 5k rpm with 18-wheelers passing me.
    I can’t imagine how terrible 33’s with 4.10 gears would be. My current experience with 4.88’s is so bad that I’m converting my truck to manual because everyone says it’s way better. We will see.
  4. Aug 6, 2020 at 12:20 AM
    #124
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Well, technically there’s less “loss” in a manual transmission. However, you’ll no longer have that torque converter to help you put around at low speeds, nor aid in torque multiplication.
    I’m in a 3rd gen v6 manual, and rock crawling in the 3.5l has really made me wish i had that torque converter.
    What’s the numerical gear difference? Most 4speed autos are effectively a 5 speed minus 1st, ratio-wise.
  5. Aug 6, 2020 at 5:04 AM
    #125
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    The mt has to be better. I'm on stock 4.10s with heavy (50lbs per) e range 235 85s. I also carry around some weight and my truck has 234k on it now. I still have to down shift to 4 for longer moderate climbs, and I can pull steep in 3rd. Just have to make sure you're planning ahead with gear selection and can't be afraid to wind her out. 4k plus rpms in 3 for the win on steep.
    The only place I have ever held up traffic was on steep windy roads in Colorado. The turns were so tight I couldn't run high enough rpms to really get going in second. Have to slow down to ten or fifteen mph for the hairpin and then I'd have to start all over again in first.
    '14RC likes this.
  6. Aug 6, 2020 at 5:07 AM
    #126
    jowybyo
    Joe
    Baltimore, MD
    Yea. I'm guessing the torque converter adds no more than 44%. So I think in most gears, the manual is still better. Also, the torque converter locks in 3rd and 4th.
    5-speed manual:
    1st - 4.31
    2nd - 2.33
    3rd - 1.44
    4th - 1.00
    5th - 0.79
    4-speed auto:
    1st - 2.804
    2nd - 1.531
    3rd - 1.00
    4th - 0.705
    AKGSD[QUOTED] likes this.
  7. Aug 6, 2020 at 5:10 AM
    #127
    jowybyo
    Joe
    Baltimore, MD
    You definitely have to drive it like a racecar. I will downshift into 3rd before I even get to the bottom of the proceeding hill so I'm already on the pipe as I get to the uphill. If you wait until you start to lose speed, it's too late.
    Hartford[QUOTED] likes this.
  8. Aug 6, 2020 at 5:12 AM
    #128
    Hartford
    Maine
    2011 Acc Cab 5spd
    What tires are you running?
  9. Aug 6, 2020 at 5:20 AM
    #129
    jowybyo
    Joe
    Baltimore, MD
    ST MAXX 255/85/16....10-ply. I also probably had an extra 600lbs in armor and a cap.
  10. Aug 6, 2020 at 5:43 AM
    #130
    dirty deeds
    Nick
    Eastern KY
    I can attest that 5spd, 4.88s, armor, LCE Pro clutch, rear lunchbox locker, and 255/85 r16 KM2s is a killer combo in a 2.7 AC! Even with a few extra pounds of camp gear in the bed. Low speed crawling was easy, little gas or clutch inputs.
    Now, with the exact same config, take away the locker and gears, it wasn't that great, but bearable. I had to be quick on the clutch, always use low range, and bump things harder. More gas, more clutch.
    Take away the LCE clutch and it was even worse! All the gas because clutch was burnt by yours truly.
    Mind you, I'm lumping on/off road together in my statements.
    We'll see how this setup likes 35s real soon like!
  11. Aug 6, 2020 at 5:46 AM
    #131
    dirty deeds
    Nick
    Eastern KY
    How much extra junk you packing?! o_O
  12. Aug 6, 2020 at 6:04 AM
    #132
    BassAckwards
    AWD Turbo 2TR-FE
    Last weekend I drove my pop's '14 DCSB PreRunner 2.7L with the 4spd Auto and 265/75/16s, and it was a complete dog compared to my 09 2.7L 5spd with 295/70/17s and 5.29s. Mind you, i've got heavy cooper st maxx on my truck 66lbs each, and a full set of aluminum skids, steel sliders and steel bumper. I was really surprised my 5spd felt way peppier than his truck. Figured i'd throw it out there for reference. The auto makes the truck a whole different animal
    MattCowsmasher likes this.
  13. Aug 6, 2020 at 6:21 AM
    #133
    dirty deeds
    Nick
    Eastern KY
    The auto must be just a damn turd. It either needs over-gearing beyond the MT, and/or a better torque converter. I'm gonna say no one makes the latter, so 5.29s for the auto and 35s?
    BassAckwards likes this.
  14. Aug 6, 2020 at 6:42 AM
    #134
    BassAckwards
    AWD Turbo 2TR-FE
    I believe IPT makes upgraded transmissions and converters
  15. Aug 6, 2020 at 6:44 AM
    #135
    BassAckwards
    AWD Turbo 2TR-FE
  16. Aug 6, 2020 at 6:56 AM
    #136
    dirty deeds
    Nick
    Eastern KY
    Well how bou dat!? You auto folks have options.
    BassAckwards[QUOTED] likes this.
  17. Aug 6, 2020 at 11:03 AM
    #137
    AKGSD
    Joe
    Alaska
    Ok, so you’d probably have a more powerful launch with the manual — though with the torque converter, you get the benefit of not worrying about clutch wear at low speeds.
    However, if you consider the 4speed auto as a five speed minus 1st, i’m not sure your highway performance is really going to be much better — unless there’s a /lot/ of parasitic loss through the automatic
    Maybe a high-spool torque converter would help “launch” it. — though that will reduce your downhill engine braking capabilities
    And i guess an important question is, what is the automatic’s rear end gearing compared to the m/t?
  18. Aug 6, 2020 at 11:25 AM
    #138
    dirty deeds
    Nick
    Eastern KY
    Auto gearing is 3.90 or 3.91 I believe. I know that a 2nd gen 4 cyl MT is stock geared at 4.10.
    EDIT: I imagine any and all parasitic loses in both trannys are through the flywheel and converter first and foremost. But lightweight flywheels are poo off road is my understanding
  19. Aug 6, 2020 at 11:53 AM
    #139
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    2nd gen 4 cyl automatic 4x4 should be 4.10 gears. The engine just isn't made for performance and when you add weight and bigger tires it definitely takes a hit and can't maintain OD on the highway with hills.
  20. Aug 6, 2020 at 11:57 AM
    #140
    jowybyo
    Joe
    Baltimore, MD
    I agree. I'm cautiously optimistic that it will be better on the hwy. But it should be about 13% better based on overdrive ratio. Where I think it will be a lot better is on steep hills. With the auto, the jump between 2nd and 3rd is huge. If 3rd isn't enough, 2nd tends to be overgeared. So you're screaming up hills at only 45mph. With the manual, there's another gear between those. So hopefully 3rd on the manual will be a good gear to pull up some of the bigger hills and maybe I'll have a shot at keeping up with traffic.
    Yea, I don't really know much about it. My truck is currently like a boat though. I have to stay on the gas down even the biggest hills or I will come to a stop.
    I've been comparing anecdotally with people that have the same rear end ratio as me (4.88). I think in 2014, both the manual and auto came with the same rear gear ratio (4.10). I've since changed mine obviously.
