So you want to buy an AR-15 - FAQs
Discussion in 'Guns & Hunting' started by Packman73, Apr 8, 2010.
  1. Jul 1, 2011 at 8:02 PM
    #61
    BMart
    BMart Member
    Willamette Valley, OR
    2018 T4R OR
    CBI Sliders
    Possibly. I would pass if its made by Olympic, Hesse/Blackthorne, or Roggio. Hard to tell without knowing more about the rifle. If you're on a tight budget Spikes' Tactical makes an excellent AR for a bargain.
  2. Jul 1, 2011 at 8:33 PM
    #62
    Packman73
    Packman73 [OP] ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    SLim-to-none that an AR15 for $500 is anything but a pos.
    SJC3081 likes this.
  3. Jul 29, 2011 at 11:59 AM
    #63
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    ive never really noticed this but that is spikes lower right?
    that picture looks like a bucktoothed Klansman lol
  4. Jul 29, 2011 at 11:59 AM
    #64
    Packman73
    2007 TRD Off Road
  5. Jul 29, 2011 at 12:09 PM
    #65
    Packman73
    2007 TRD Off Road
    Keep them for your next rifle. There will be another eventually.
  6. Jul 29, 2011 at 6:29 PM
    #66
    Packman73
    2007 TRD Off Road
    I gave you my solution. If you don't like what I suggested, do something else and piss off.
  7. Jul 29, 2011 at 7:17 PM
    #67
    Packman73
    2007 TRD Off Road
    Listen, I told you what I would do and then you come at me with: "Soooo...you have no input on this possible solution?"
    So, who's being a dick?
  8. Jul 29, 2011 at 7:28 PM
    #68
    Packman73
    2007 TRD Off Road
    Fair enough.
  9. Jul 29, 2011 at 7:38 PM
    #69
    white96850turbo
    white96850turbo Member
    Wisconsin
    none... yet
    I have the MBUS on my AR and hate them... They look cheap, feel cheap, and when folded the rear one gets in the way of my Eotech 512's (unless i mount my 512 very far foward, witch i do not like) buttons. I wish I would have just paid the extra $50 to get some nice low profile / fold flat sights. I would say get some MI or YHM low profile sights so they don't get in the way of your optic.
    I've never used / know of anyone that has used a riser on a gas block to mount their back up sights, but I don't see why it wouldn't work.
    Good luck on what ever you end up going with!
  10. Aug 2, 2011 at 10:39 AM
    #70
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
  11. Oct 1, 2011 at 8:39 AM
    #71
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    I've got MI's on one of my rifles, and I run a 512 on it... no issues.. the only think I dont like is they have a little locking piston that you need to toggle to fold/unfold. I understand the design, but it could be an issue if you're heated and your optics take a shit. I'm not really a gloved shooter, but I could imagine gloved shooters may have issues....
  12. Dec 1, 2011 at 8:21 PM
    #72
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Oooh I think about wanting to build one and I run into this....a sign?
  13. Dec 1, 2011 at 8:47 PM
    #73
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Yep, nothin' special about MBUS.
    Supposedly the latest revision lays flatter.
    I would get a different gas block or watch the MBUS melt.
  14. Jan 11, 2012 at 11:58 AM
    #74
    spearhead
    spearhead Taco Supremist
    Winston Salem NC
    09 4DR Mag Grey 4WD Sport
    TRD CAI Eibach Springs 5100s all around Front set to .85 Toytec AAL
    I think they work great for the price, but yeah don't stick one on a gas block
  15. Feb 8, 2012 at 7:30 PM
    #75
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Don't use the MBUS on the gas block, the heat issues could distort the front sight, not a good option.
    As for the small riser rail, that won't work either because the difference in height from the railed gas block to the receiver is not the same the small risers you will find, so your front sight will either sit way to low and you front sight post will sit up outside of the ears or it will sit way too high and your front sight won't have enough negative elevation to get properly sighted in. Both are an issue. The riser will not put the front and rear sighs on the same plain, thus they will never zero correctly.
    As for the "adding a rail to the hand guards" this won't work either because your handgaurds are plastic clamp ons and will move, wiggle when you hold the rifle, so your rifle will never maintain zero, even shot to shot you handgaurds will move thus moving your front sight, so that isn't even an option.
    Your options are:
    *replace the gas block with a different height gas block and rail (~$80 in parts)
    *replace your gas block with a A2 style gas block with built in front sight at the correct height (~$50 in parts and then gun smith fees to install the cross pins properly for an A2 sight base)
    *buy a front sight from MI or the like that is made from AL and it also the correct height to be used with your railed gas block (~$60 in parts) - this is the best low cost option, you also won't need armor tools and you won't have to modify the weapon, you could also likely sell the front MBUS for $30 and make 1/2 what you need for the MI sight
    *buy a low profile gas block and put a quad rail free float hand guard on your rifle and then mount your MBUS to that (~$300 in parts)
    *finally just buy an optic and forget about the back up sights, if you buy a quality optic it is more likely that you will be dead or dying before it stops working, so the concern with a back up set of irons is almost silly unless you are a serious bad ass :cool:
  16. Mar 24, 2012 at 6:47 PM
    #76
    USFCON
    USFCON Well-Known Member
    Jeff
    Melbourne, Florida
    Prerunner SR5 Off Road
    FLM URD Short Shifter Debadged Gate 4 D-ring add on Weathertech floor mats Sport Wheel Swap Color matched Grill Bed lights Air freshner mod AAL Bilstein x 4 Tacolean Spacer Tins Bike Fork Mount Sexy Tires Blacked out Valence
    I'm looking for a AR-15 SP1. Hard to find? Any additional info is appreciated. What do I need to look for to verify it's a SP1? Going to Orlando gun show in a few weeks. Have about 3-5K to spend.
    Thanks
  17. Mar 25, 2012 at 5:45 AM
    #77
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    Well, now that I'm almost ready to buy one, of course the supply has dried up. I have found one in San Antonio, a Palmetto with a red dot, magnifier, and fluted stainless barrel. I expect that by the time I have the cash in hand it will be gone.
    Any thoughts on PSA guns? I'm not looking for perfect- just functional and acceptably accurate.
  18. Mar 25, 2012 at 8:56 AM
    #78
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    PSA uses all mil spec parts and are good to
    Go. But they also don't sell a gun with a fluted stainles barrel.
    Why not just go online and order from PSA directly? You can build a complete AR for right around 600.
  19. Mar 25, 2012 at 8:58 AM
    #79
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Are you wanting am actual SP1 or just a clone?
  20. Mar 25, 2012 at 2:41 PM
    #80
    Dimonback
    Patrick
    Do I need to use an FFL transfer service, and how tough is it to mate the upper and lower?
