Socal Craigslist Finds
Discussion in 'Southern California' started by blackhawke88, Apr 25, 2011.
  1. Aug 10, 2017 at 5:42 PM
    #2941
    surftaco16
    surftaco16 Well-Known Member
    Oahu
    1997T100 V6, MT, 4WD T100 1996 V6 5lug Taco, MT
  2. Aug 14, 2017 at 1:44 PM
    #2942
    l SWAY l
    l SWAY l Well-Known Member
    Sway
    SoCal
    2011 DC TRD OR 4WD
    Some of this & some of that...
  3. Aug 14, 2017 at 4:47 PM
    #2943
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    not CL but Im selling this.
    Going to a different rack set-up and looking to sell my rack, powdercoated satin black. Built by unique fabrication for me, has side mounts for rotopax (4) center load bars use interlocking bolted tube clamps so the 2 mid and rear bar are removable (made so I could load 2 dirtbikes without removing entire rack - or - any other tall / large item.
    It's a strong, and built well and has plenty of clearance for items under rack.
  4. Aug 14, 2017 at 4:57 PM
    #2944
    tcjacado
    tcjacado Well-Known Member
    What are you asking or it?
  5. Aug 14, 2017 at 5:39 PM
    #2945
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Is there enough of a flat surface on there to attach 2x4's or something to raise it a bit for transporting long pieces of lumber?
  6. Aug 14, 2017 at 8:05 PM
    #2946
    blackohio
    Cliche Guevara
    white mudflap
    $900 cost me about 1300 to build
    tcjacado[QUOTED] likes this.
  7. Aug 14, 2017 at 8:12 PM
    #2947
    blackohio
    Cliche Guevara
    white mudflap
    The bars are right at roof level. So with small shims it should clear. I'll include the bar clamps that hold the solar panel on when swung around they sit about ¾" above load bars but if you did mount a 2x4 to the 8 tent mount tabs you'd be 2" off or 4".
    There are 3 cross load bars. The 2 rearmost are the removable ones where the front cab side one is there to
    MotoEd and GPsevinSixx[QUOTED] like this.
  8. Aug 14, 2017 at 8:15 PM
    #2948
    GPsevinSixx
    Ros Angerus
    Thank you, been eyeballing a rack for other duties also. Always liked your one-off setup. Will let you know when I make a decision.
  9. Aug 14, 2017 at 8:17 PM
    #2949
    blackohio
    Cliche Guevara
    white mudflap
    So many different needs with racks. For me convertibility for the dirtbikes was imperative number 1.
    I like it because if I bought say a washer and needed to get it home I don't need to remove rack just 8 Allen head screws and load bars are out. It's like 2 minutes
  10. Aug 14, 2017 at 8:24 PM
    #2950
    blackohio
    Cliche Guevara
    white mudflap
    Where you can see the clamp height when swung around to the top and there are still the 8 welded or formed tabs the tent mounts to
    GPsevinSixx[QUOTED] likes this.
  11. Aug 14, 2017 at 8:25 PM
    #2951
    GPsevinSixx
    Ros Angerus
    The rearmost upper crossbar ( 2 are mentioned) looks welded on in the pics. How does it come apart? Pull the rack off the truck and then split?
  12. Aug 14, 2017 at 8:34 PM
    #2952
    blackohio
    Cliche Guevara
    white mudflap
    The bar closest to the cab is welded as a stiffening part of the hoop. There are 2 cross bars mid and rear of bed. Those have joints like these on the ends with the other side on the caged sides.
    You can see one of the joints here. If you zoom in you can see all 3 bars on the left side. You just unscrew 2 screws on each joint one on the upper keyed piece and one opposite under. Then the bars lift right out
    9TRDTCO and GPsevinSixx like this.
  13. Aug 14, 2017 at 8:41 PM
    #2953
    mrxw1zard
    mrxw1zard Well-Known Member
    ATX
    2016 TRDORDCSB MGM
  14. Aug 14, 2017 at 9:30 PM
    #2954
    greenEFSI
    greenEFSI TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
  15. Aug 15, 2017 at 4:43 PM
    #2955
    surftaco16
    Oahu
  16. Aug 15, 2017 at 10:12 PM
    #2956
    jessetoedtman
    jessetoedtman Well-Known Member
    Jesse
    San Diego
    2010 Tacoma SR5 DCLB 4x4
  17. Aug 16, 2017 at 11:34 AM
    #2957
    k_j_souv
    k_j_souv Well-Known Member
    NorCal
    3G OR DCSB, Dual Case, 42s
  18. Aug 16, 2017 at 5:59 PM
    #2958
    LilRedTac0
    LilRedTac0 Member
    Cucamonga
    2006 4x4
    I unfortunately get into lurking on forums more than I do posting nowadays, so I don't think I'll ever hit the 50 to post in for sale. Just wanted to give anyone local on TW a heads up on these before I have to deal with the special folks on Craigslist.
    Got my old '96 manual and Hayes Tacoma 1st gen books for free to anyone local.
    '05 headlights - some hazing, all tabs good. $20 each ($40 set)
    '05 tail lights - great condition. $25 each ($50 set)
    anyone want pictures, just shoot me a message. They'll hit offerup/craigslist over the weekend.
    Nicklovin, SKULLY and angeldavid216 like this.
  19. Aug 17, 2017 at 9:02 PM
    #2959
    blackohio
    Cliche Guevara
    white mudflap
    and gone!
    angeldavid216 likes this.
  20. Aug 17, 2017 at 9:14 PM
    #2960
    9TRDTCO
    9TRDTCO Well-Known Member
    I'm there! When can I pick up??
    tcjacado likes this.
