Socal Craigslist Finds
Discussion in 'Southern California' started by blackhawke88, Apr 25, 2011.
  1. Jan 15, 2018 at 8:58 PM
    #3261
    eon_blue
    Azusa, CA
    Also keep in mind you must run at least 91 octane with a supercharger and more than likely you'll need some kind of fuel mod to keep from running lean (URD 7th injector, methanol injection, larger fuel injectors, high flow fuel pump, etc.) unless you're lucky. Also 2 step cooler spark plugs.
    Boost ain't cheap
    Prayn4surf, eccracer104 and oni06 like this.
  2. Jan 15, 2018 at 9:06 PM
    #3262
    oni06
    oni06 Well-Known Member
    But its FUN
  3. Jan 15, 2018 at 9:23 PM
    #3263
    eon_blue
    Azusa, CA
    2nd gens (4.0s) are lucky in that you don't require any supporting fuel mods unless you modify the blower for more boost, and even then it's not always necessary. But overall it's more expensive to boost the 4.0...the blower itself is more expensive and you guys require a piggyback tuner or ECU reflash to run it.
    Prayn4surf and dtaco06[QUOTED] like this.
  4. Jan 16, 2018 at 7:05 AM
    #3264
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    What would you say a rough estimate for fuel mods etc for the 1st gen to get it to run would be, if the sc was in good condition? rebuild costs?
    I emailed the seller to ask what kind of maintenance he has done and if he changed the oil, i read some peeps change it at 50-70 k just to be safe, some let it run to 120k and ran into issues. No response as of yet...boost would be sweet, not sure i have the dough for this right now but maybe hahah
  5. Jan 16, 2018 at 7:15 AM
    #3265
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    You break enough shit as is :rofl:
    eccracer104 and dtaco06[QUOTED] like this.
  6. Jan 16, 2018 at 9:38 AM
    #3266
    eon_blue
    Azusa, CA
    Depends...the 3.4l supercharger is advertised as a bolt-on-and-go modification, and for some people it is...but others (like myself) experience lean issues with the stock setup and it seems to be pretty common. You have 3 options to compensate for running lean that I know of...the URD 7th injector kit (which I have), runs about $900 and is basically a 7th fuel injector that plugs into the back of the supercharger and sprays fuel into it when you hit a certain amount of boost, which helps even out your air/fuel ratio and stop the pinging from running lean. There's also methanol injection which is the same concept but instead of spraying fuel through the supercharger, you're spraying a methanol mixture which also evens out the A/F ratio and has the added benefit of cooling the supercharger itself. Those kits are usually cheaper, somewhere around the $400-500 range.
    People that have the EGR system on their trucks can't run the 7th injector kit (not sure about methanol) so URD sells a kit that replaces the 6 stock injectors with 6 larger ones to accommodate higher fuel flow, I think it's around $900 as well.
    Also you want to run at least a boost gauge and a wideband AFR gauge...neither one comes with the supercharger, have to get them separately.
    Prayn4surf[QUOTED], itaro and YumaTRD like this.
  7. Jan 16, 2018 at 6:01 PM
    #3267
    Prayn4surf
    Socal
    Wow awesome info man thank you! I want a sc hahah
    YumaTRD likes this.
  8. Jan 17, 2018 at 2:36 PM
    #3268
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
  9. Jan 17, 2018 at 2:39 PM
    #3269
    eon_blue
    Azusa, CA
    No prob. I have a love/hate relationship with mine lol...my truck came with it on. I personally would never have considered doing one if it had come stock, I'm less concerned with power/performance and more into offroad capabilities/performance. But it's fun to have. Just adds a lot more to your plate that you have to take into consideration with certain things, not to mention boost is a rabbit hole of mods on it's own. Also by no means does it make the 3.4l a "fast" motor or turn the Taco into a race truck...you can tell it's adding horsepower for sure but you'll still get beat off the line by most other cars on the road, lol. At least I do with the heavy tires and armor weight.
    But I'll be goddamned if that blower whine doesn't give me a partial boner each time I downshift into 3rd or 4th and mash the gas pedal :burnrubber:
  10. Jan 18, 2018 at 5:23 PM
    #3270
    StrangeDuck
    San Diego
  11. Jan 18, 2018 at 5:29 PM
    #3271
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    bigbarlo likes this.
  12. Jan 18, 2018 at 5:55 PM
    #3272
    icetreye
    icetreye If I ain't lurkin', then I must be jerkin'.
    Kevin
    SoCal
    '14 BRM Prerunner TRD OffRoad
    9TRDTCO and itaro like this.
  13. Jan 18, 2018 at 7:01 PM
    #3273
    StrangeDuck
    San Diego
    The ad says "fits a Toyota Tacoma 6 foot tray" and "Top is more worn than the attached pictures" so he may have just pulled some pics from Google for the ad.... hit him up and ask!
    Tdogg11 likes this.
  14. Jan 18, 2018 at 7:07 PM
    #3274
    StrangeDuck
    San Diego
  15. Jan 19, 2018 at 12:26 PM
    #3275
    SDTaco89
    SDTaco89 Well-Known Member
    2017 TRD Off Road DCSB Super White
    Bilstein 5100's, SCS Ray 10's, Falken Wildpeak 285/70/17, TRD Pro Grille
    StrangeDuck[QUOTED] likes this.
  16. Jan 20, 2018 at 10:26 AM
    #3276
    msegal55
    msegal55 Insta: babe.the.blue.ox
    Mitch
    Orange County CA
    18 Cavalry Blue Trd Pro
  17. Jan 26, 2018 at 11:05 AM
    #3277
    joetacoma16
    joetacoma16 Active Member
    2016 tacoma trd OR access cab
    Hello
    I have 2 items for sale fit 2016+ Tacoma;
    Hondo Garage Air Vent Mount with 1" ram ball. Lightly used $25 free shipping. If you don't buy mine get one from him direct, they are amazing.
    Salex Toyota Tacoma Center Console Organizer. Ligthly used $6 free shipping. It's 4 pieces of plastic that form a grid.
    6ft. Genuine Toyota Bed Mat for 2016+ Toyota Tacoma. Lightly used $75 for pick up in San Clemente, CA. To big to ship, come get it.
    Everything is in great condition. I no longer have my truck and do not need these items. I will put these items on Craigslist next week.
    Payment in Cash, Paypal, Venmo and Bitcoin accepted.
  18. Jan 26, 2018 at 1:19 PM
    #3278
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    Dropitmore and TheDude94 like this.
  19. Jan 29, 2018 at 10:05 PM
    #3279
    d.shaw
    d.shaw Well-Known Member
    2012 Silver TRD-OR
    Vagabond Drifter, King 2.5 coilovers, King 2.5 rear, Pelfreybilt front / rear bumpers and skids, rock sliders, Safari snorkel, Smitybilt winch, Baja designs 20in, wide cornering spots, S2 rear. Deaver expedition series stage 3 rear leaf.
    THEPYRITETACO and dtaco06 like this.
  20. Jan 30, 2018 at 9:47 AM
    #3280
    Julian
    Julian 92yota
    Julian
    Inland Empire, CA
    1992 Toyota Pickup DLX V6 Manual 4WD
    |• 255/80/R17 Toyo R/T Tires on 2nd Gen Tacoma Sport wheels| |•Bilstein 4600 Series Shocks|
