SoCal differential and axle shop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Otaku1, Oct 20, 2017.
  1. Oct 20, 2017 at 9:07 AM
    Otaku1
    Otaku1 [OP] Active Member
    SoCal
    '17 TRD Sport 4x4
    After doing a lot of searching on the site for someone that had good/bad experiences at shops that handle gearing, I haven't come across any recommendations in Southern California. I'm new to owning a Tacoma but not new to offroading. I used to have a '94 YJ running 33x12.5 super swampers. My rear end was a reverse cut Currie built Dana 44, 4.56 gears and a Detroit soft lock. I never had the chance to change out the front Dana 30 to a sturdier 44 but it did just fine. That being said I really don't want to change out the entire rear end for a Currie since I'm not doing that style of rock crawling. I do want to put 4.88's to match the tires and lift I plan on doing. I need a shop though.
  2. Oct 20, 2017 at 9:12 AM
    tcjacado
    tcjacado Well-Known Member
  3. Oct 20, 2017 at 1:10 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
  4. Oct 20, 2017 at 1:19 PM
    tcjacado
    No I have not, but he is the best I know as he is a certified toyota master tech and he has done a bunch of work on members trucks in socal.
    @eccracer104 Will also agree I am sure.
    Drainbung and eccracer104 like this.
  5. Oct 20, 2017 at 1:26 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Jason is the MAN for installs, repairs and some custom work, but I don't think he does gear installs when you need to measure the backlash and all that jazz. I know he will do the ECGS full drop in gear sets, but if you have gears alone and need them installed you would want to call yotamasters.
    https://www.yotamasters.com/
    tcjacado and TWTaco like this.
  6. Oct 20, 2017 at 2:16 PM
    TWTaco
    Dave
    Anyone in the Orange county area for gear installs, looking at Rebel offroad.
  7. Oct 20, 2017 at 2:24 PM
    bob4x4
    bob4x4 Active Member
    15 TRD OR dcsb
    I have used Unitrax in Anaheim and sent many others there
    TWTaco likes this.
  8. Oct 20, 2017 at 2:27 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
  9. Oct 20, 2017 at 3:06 PM
    Blazingbluesport
    The OC!
    When I spoke to Rebel off-road about doing my lift and replacing the needle bearing with the ECGS bushing, the guy I spoke to said there is no issue with with the needle bearing and replacing it with the ECGS bushing is a waste of time and money.
    I used Jason to do the work. I don’t know about replacing gears but lack of established knowledge, which is even acknowledged by Toyota techs would keep me away from Rebel off-road. I think they specialize in Jeeps.
    TWTaco[QUOTED] likes this.
