SoCal Switch-Pros installs
Discussion in 'Southern California' started by AY_ARONTRD, Mar 5, 2020.
  1. Nov 12, 2021 at 4:09 AM
    #261
    AY_ARONTRD
    AY_ARONTRD [OP] Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Sounds like a plan. Also I’m able to get Switch-Pros and lighting at discounted prices. If interested just PM me.
  2. Nov 30, 2021 at 8:37 PM
    #262
    The Pirate
    The Pirate Takoyaki Takoma
    I also posted this in the SP install thread.
    Sorry for the delay but I finally got around to my install last week. It wasn’t super difficult, but with my skill level I did find it time consuming. Thanks to @AY_ARONTRD and @daveeasa for all of your help!
    @AY_ARONTRD made a really nice bracket, which I surprisingly had a little difficulty mounting (no fault of his), the lack of space, angle, and fact that i don't have any hex sockets made it tough, i think if I wasn’t using an allen key or if it was just normal bolts this part probably would have been a non factor.
    Next going through the fire wall was slow but doable with 2 people, we ran a stiff wire first and then attached and fished through the control wire. I ran the pink and white trigger wires off of a T-harness from the headlight made by Dave, and did a fuse tap for the blue.
    [​IMG] [​IMG]
    I also ran the red and white wires off off dave's harness which are for the the DRLs on the MESO turn signals that I haven't installed yet.
    I ended up installing the controller in the left cubby panel and got a MESO custom piece to fit it into, this involved some cutting but wasn’t too bad, also everything fit a little too tightly, but works.
    The next issue was that I couldn’t fit all the switches plus the SP control so decided to relocate the traction control switch to the overhead panel (In hindsight I wouldn’t do this again) and install a MESO 3 switch mount. This was by far the worst part, not only did i have to run wiring under the KTJO not so OEM drivers side handle but it also involved a lot of cutting. Despite trying to be very carfull and taping everything I ultimately ended up doing some minor cosmetic damage to the panel, not getting a good fit and getting really frustrated. But that's all part of the adventure I guess...
    [​IMG] [​IMG]
    It doesn't look as bad in really life, but I would have avoid this step if I got a do over.
    After everything was done all the switches worked but I couldn't get the Bluetooth to connect, Aaron told me to disconnect and reconnect the switchpros control wire. I did that and now everything works great. I forgot to put the labeled heat shrinks that Aaron provided me with on, so I will add those later as well as adjusting the bracket upward. Beside the few (mostly self inflicted) hiccups I ran into I am very happy with the finished product, and highly recommend Aaron's work.
    Thanks Aaron!
    AY_ARONTRD[OP], Trd420 and daveeasa like this.
  3. Nov 30, 2021 at 9:46 PM
    #263
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Looks very nice. You need a battery tie down from @Coupe though.
  4. Dec 25, 2021 at 8:18 AM
    #264
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Sorry I haven't been on here to much during the holidays. Busy with my normal job and with the family.
    Thank you For the awesome write up! well detailed and shows that even guys that are not local are able to purchase this setup from me and take the install on themselves. Looks like you took your time and did not rush the install. The Allen head bolts for underneath the mount are a little tricky to get to for you MT guys. What I use is extended length Allen sockets for installs. Helps from preventing beating up the knuckles.If there's anything further I can assist with feel free to reach out to me.
    Trd420 and The Pirate[QUOTED] like this.
  5. Dec 25, 2021 at 8:24 AM
    #265
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Merry Christmas to you all! Thank You for the kind words and support with what I am doing. Helps keep me motivated to keep providing my time and work for Tacomaworld. After the Holidays I will be getting back on track with builds and help with purchases on parts I can get my hands on.
  6. Feb 10, 2022 at 4:05 AM
    #266
    SubstanceP09
    SubstanceP09 Member
    Super Interested...Sent you a PM but no response :(
    AY_ARONTRD[OP] likes this.
  7. Feb 13, 2022 at 7:08 AM
    #267
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Sorry , just responded back to you as well as about 9 other people. Life got super busy and just didn’t want to Accept peoples money and have them waiting on products. Slowly starting to free up time so would be a good time to start ordering Switchpro’s since I’m sure there may be a small lead time. Sorry guys.
    elmontemike likes this.
  8. Mar 11, 2022 at 11:36 PM
    #268
    Dcal
    Dcal Member
    Dante
    San Diego
    2018 Cement TRD OR
    Bilstein 6112/5160 Built Right UCA Tri-Pack Yokohama Geolander MT 285/70R17 Method 701 Bronze 5.29 Revolution Gears ARB Front Air Lockers Prinsu Rack Fabzone Rock Sliders Baja Designs Sport Fog and Ditch Lights BAKFlip MX4 Tonneau Cover
    PM sent
  9. Jul 7, 2022 at 7:59 PM
    #269
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Just finished this one up for @SubstanceP09 . This will be shipped to him for him to enjoy the install. MT setup w/bluesea fuseblock. Notice he went a little different with a similar paint to quicksand. I like the results. :thumbsup:
    8C70E6A5-1182-48DB-910F-15F758CFA39F.jpg CFF390BB-0141-41FC-9B21-29A59579A188.jpg
    elmontemike and daveeasa like this.
  10. Jul 8, 2022 at 5:24 AM
    #270
    elmontemike
    elmontemike Well-Known Member
    Great work. That looks awesome. I like the color on the plate.
  11. Jul 8, 2022 at 5:34 AM
    #271
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Thank you sir :hattip:
    elmontemike[QUOTED] likes this.
  12. Jul 11, 2022 at 6:38 PM
    #272
    AY_ARONTRD
    Aaron
    Murrieta ,CA
  13. Aug 22, 2022 at 10:30 PM
    #273
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 LC250
    @AY_ARONTRD, sent you a PM with some questions. Thanks.
  14. Sep 11, 2022 at 8:43 PM
    #274
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    All PM’s replied. Let’s get this thread going again… :popcorn::woot:
  15. Sep 26, 2022 at 1:23 PM
    #275
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    What lighting do you get at discounted prices? If you want just PM me.
  16. Sep 29, 2022 at 8:01 PM
    #276
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Was able to finish this up and meet up with @BTHawk on his visit from Hawaii. It was nice to meet you and was happy to see your reaction on the setup I built for you. Enjoy! :cheers:
    139A36C9-E294-4A34-943B-15434B451ECA.jpg 8AAE834A-C171-45F9-9DE1-9B9D31B97D16.jpg
    BTHawk and daveeasa like this.
  17. Sep 29, 2022 at 8:07 PM
    #277
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    I must say, it’s pretty cool being able to build these setups and see them not only be installed on trucks local by me, but also actually be shipped and installed a distance away knowing I was able to help simplify adding electrical accessories. :cheers:
    Tombiology70 and daveeasa like this.
  18. Oct 2, 2022 at 8:08 PM
    #278
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    All builds complete. Just did an install yesterday for @mysubiewasalemon .
    Have some available spots, able to take on a few orders. PM for details. :thumbsup:
  19. Oct 6, 2022 at 1:24 PM
    #279
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 LC250
    Great to meet you as well, Aaron! Thanks again for the fantastic product, installing it this weekend!
  20. Nov 3, 2022 at 7:24 PM
    #280
    Getskyhigh
    Getskyhigh @el_yota_
    Fernando
    2016 MGM Tacoma TRD OR 4x4 MT
