SoCal Tacoma's BS Thread
Discussion in 'Southern California' started by RJALLDAY702, Feb 28, 2012.
  1. Jul 15, 2012 at 9:02 PM
    #3781
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Small item that won't benefit you in any way until then. Until you know what leafs you are getting and how much plunge you are going to have they won't have any idea how much to shorten your driveshaft.
    Its off a 4x4, there not on a 2x4 Offroad.
  2. Jul 15, 2012 at 9:03 PM
    #3782
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Thank you! I will wait a couple of months then,
  3. Jul 15, 2012 at 9:03 PM
    #3783
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    and the 4x4 ds is shorter right?
  4. Jul 15, 2012 at 9:04 PM
    #3784
    nfs257
    DFW
    She gone
    4x4 only came in access cab LB or double cab SB so yes it is shorter.
  5. Jul 15, 2012 at 9:04 PM
    #3785
    lembowski
    Rolando, CA
    Jeeper Creeper
    Its shorter cause it has the slip yoke on it
  6. Jul 15, 2012 at 9:06 PM
    #3786
    Special_K
    Special_K o_o
    Eddie
    Alexandria, VA
    2019 Tacoma Cav Blue
    My driveshaft length was fine with the Defined kit, but when I switched to the F70s, it had to be shortened more. Got lucky with that as you're better off doing it once when you figure out your rear set up.
    I'm not a good example of doing things once and being done with it though :(
  7. Jul 15, 2012 at 9:06 PM
    #3787
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    Awesome..keep up the good work
  8. Jul 15, 2012 at 9:19 PM
    #3788
    lembowski
    Rolando, CA
    Jeeper Creeper
    What are your plans for the rear?
  9. Jul 15, 2012 at 9:22 PM
    #3789
    nfs257
    DFW
    She gone
    I need to ride/drive a SUA and a linked so I can decide... Also some one mentioned a linked spring under being a pretty good option... ?
  10. Jul 15, 2012 at 9:23 PM
    #3790
    rcfreak201
    rcfreak201 Well-Known Member
    links and spring under? combined? What? haha
  11. Jul 15, 2012 at 9:25 PM
    #3791
    anthony250f
    Anthony
    San Diego, CA
    linked springs :p:p
  12. Jul 15, 2012 at 9:27 PM
    #3792
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Awwww, Eddie... you're a fine example in everyway dude !!!!...:)
    Hey matt , thanks for the heads up with James , he got me hooked up with a trans. real quick ....:):)
    & yeah pretty sure only 2nd gen 4x's have a slip yoke....
  13. Jul 15, 2012 at 9:27 PM
    #3793
    nfs257
    DFW
    She gone
    :notsure:
  14. Jul 15, 2012 at 9:28 PM
    #3794
    nfs257
    DFW
    She gone
    This is what I was referring to...
    Linked is obviously best, but SUA works well too, the 4 link will give you far more precise control since it is solidly located and cannot move outside its intended arch of travel, and leafs will deflect front to rear and side to side due to the nature of using a spring to control all movement.
    You can also do the SUA and use link bars as a cheaper option that will perform rather well actually..
  15. Jul 15, 2012 at 9:31 PM
    #3795
    lembowski
    Rolando, CA
    Jeeper Creeper
  16. Jul 15, 2012 at 9:32 PM
    #3796
    rcfreak201
    I've never heard of anything like that(besides that show bro truck).
    But if you are considering links you should get a cab cage done at the same time. Links aren't very DD friendly without a proper rear sway bar since you will have ALOT of lean.
    SUA is good for the road and much better offroad! Even with SUA you should consider a cab cage but with links its a must. Links are also much more involved than just a simple bedcage and leaf springs. I know american motorsports just came out with their 5 lug link kit retaining the bed but usually you cut the frame off completely after the cab, usually remove the bed, fuel tank, and axle. It requires a fuel cell(In CA it wont pass smog unless you know people:spy: ) It needs a beefier axle and usually a full bed cage. Thats just the little stuff i know about links :eek:
  17. Jul 15, 2012 at 9:32 PM
    #3797
    nfs257
    DFW
    She gone
    :rofl: But please explain? You know after the talks friday im unsure...
  18. Jul 15, 2012 at 9:33 PM
    #3798
    rcfreak201
    What are link bars? lol
  19. Jul 15, 2012 at 9:33 PM
    #3799
    nfs257
    DFW
    She gone
    Thank you. This is the type of info I am looking for...
  20. Jul 15, 2012 at 9:34 PM
    #3800
    nfs257
    DFW
    She gone
    :notsure: Thats why I posted it... LOL :eek:
