SoCal WTT: Deaver Stage 3 Leaf Springs for Deaver Stage 2
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by pc3coyote, Nov 16, 2022.
  1. Nov 16, 2022 at 4:23 PM
    pc3coyote
    pc3coyote [OP] www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
    I have Deaver U402 expedition stage 3 leaf springs with Deaver polyurethane leaf springs
    that I am looking to trade for Deaver U402 expedition stage 2 leaf springs.
    Mine have ~5000 miles and no issues.
    Anyone add a new camper or weight in the bed and need some extra support? :)
    I am located in Hermosa Beach, CA and can meet in the Los Angeles area to do the swap. Maybe +cash on your end depending on condition. Thanks!
    From Deaver:
    Stage II – 9 leafs, military wrap, diamond cut ends, anti-friction pads and four piece bolt through retaining clips. 2-inch lift. Designed for bed weight of 400-600 lbs.
    Stage III – 9 leafs, military wrap, diamond cut ends, anti-friction pads and four piece bolt through retaining clips. 2-inch lift. Designed for bed weight of 700-1000 lbs. Driver and passenger side specific.
  2. Nov 16, 2022 at 6:45 PM
    wdissident
    wdissident Well-Known Member
    chris
    orange, cali
    2022 trd sport
    call up deaver. they're in santa ana. they can probably remove a leaf or heat and bend a piece to turn it into a stage 2. they're really cool dudes.
    pc3coyote[OP] likes this.
  3. Nov 16, 2022 at 6:49 PM
    Longtech
    Longtech Well-Known Member
    Long
    SoCal
    15' OR converted 4WD
    are the stage 3 too much for your setup? from your pic looks like you got some weight there...
  4. Nov 16, 2022 at 7:03 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    FYI, you can just remove a leaf to make them stage 2. That’s what I did with mine. I have stage 3 leafs but run them as stage 2. IIRC, it was the second or third leaf that I removed.
    pc3coyote[QUOTED][OP] likes this.
  5. Nov 16, 2022 at 7:57 PM
    pc3coyote
    Paul
    SoCal
    sweet thank you! I originally picked them up in person so wouldn’t mind another trip over there!
    Stage 3 was perfect for my current setup which was a camper, bed drawers filled with gear, and high clearance bumper with swingout.
    I’ve removed the bed drawers, probably am going to remove the swingout and run the bumper without it, and may be switching to a topper from the camper down the road. So I was thinking stage 2 may be more appropriate.
    thanks, Sergio! I may hit you up haha I thought stage 2 and stage 3 were both 9 leafs which is why I thought you couldn’t just remove a leaf like you do with Dakar leaf packs
    GHOST SHIP[QUOTED] likes this.
  6. Nov 16, 2022 at 8:06 PM
    GHOST SHIP
    GHOST
    Disclaimer: I’m no engineer but I’ve been running my leaf pack this way for a couple years now and haven’t had an issue. Somebody with a degree might jump in here and tell me why I’m wrong and removing a leaf is sacrilege and I should take my pagan ramblings straight back to the cave I crawled out of.
  7. Nov 16, 2022 at 8:23 PM
    pc3coyote
    Paul
    SoCal
    haha I definitely see you as an expert on these things! that’s why I let you chop up my truck! :D
  8. Nov 17, 2022 at 8:28 AM
    pc3coyote
    Paul
    SoCal
    I spoke to Deaver and they said they don't necessarily recommend removing a leaf as the pack isn't designed for it but if you wanted to, you could remove Leaf #5 (assuming Leaf #1 was the top leaf). They said it wouldn't impact the capability a ton but could impact the progressive loading. They recommended swapping. Food for thought!
    GHOST SHIP[QUOTED] and eurowner like this.
  9. Nov 17, 2022 at 2:41 PM
    funnytaco
    funnytaco Well-Known Member
    Disneyland, CA
    2020 Taco TRD Pro MGM
    I just checked out your build thread. SICK
  10. Nov 17, 2022 at 3:06 PM
    pc3coyote
    Paul
    SoCal
    Thank you sir! :cheers:
