SoCalRoadie's LT Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SoCalRoadie, Jun 19, 2011.
  1. Jun 19, 2011 at 7:25 PM
    SoCalRoadie
    SoCalRoadie [OP] Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    2010 MGM Tacoma Double Cab Off-Road
    Engage Front LT
    King 8" Coilovers
    SAW 8" Triple Bypasses with 2" rod extension
    ProComp 2" Bumps
    10" Straps
    Engage Spindel Gussets
    Glassworks One Piece Clip
    SMP Front Bumper with skid
    Engage Rear Bedsaver Cage
    Engage 50T Pack
    King 2.5" x 16" Triple Bypass with Remote Resi
    Slip Joint added to drive shaft
    King 2.5" bumps
    4.56 Nitro gears
    Spydertrax 1.25" Spacers
    Glassworks Bedsides
    Konig Countersteer X 17" Black
    Hankook Dynapro ATM 315/70R17
    Rigid Dually Spot and Flood
    Rigid 30" E-Series with White and Amber LEDs.
    OTRATTW Switches and Blue Sea 12 circuit Aux fuse box.
    Cobra 75 CB (mag mount antenna)
    Kenwood 281 w/cap mod (mag mount antenna)
    KR Fab Cab mount chop and clearance for 35"s
    KR Fab Sliders
    KR Fab Locking Truck Box
    KR Fab Floor Jack shelf
    Trifenix HF Floor Jack Skid
    2x RotoPax 2 Gal with Lox
    2x NATO 5 Gal cans (4WP Blitz can mounts)
    DMZ Motor Mounts
    DMZ Coil Bucket Crossmember
    TC UCA Gussets
    TC Cam Tabs
    TC Dual Shock Hoop
    SMP Rear bumper integrated into a Dual Lay down spare tire carrier.
    SMP Roof Rack with 40" Baja Designs LED Bar
    SMP Cab Cage and Engine Cage
    MCM Solid Mount LCA with Delrin Bushings installed
    MCM Re-mounted my secondary shock tabs so I can cycle my bypasses correctly.
    What I've broken so far:
    Rear driver bedside lower mount before tire
    Tow Hitch electrical connector plate
    Stuffed passenger front tire/lca into core support
    Passenger headlight tabs
    Taillights are hanging on by the nubs
    Rear Frame and Bed Cage
    What I'd like to do next:
    Rear power window
    LED Interior Swap - DONE
    Strengthen front skid - DONE
    LCA skid/transmission skid -DONE
    Mount compressor inside engine compartment
    Blue Sea Fuse Block - DONE
    Fix/make stronger bedside mounting - DONE
    Rear Bumper - DONE
    Front Bypasses - DONE
    Cage... :) -DONE
    http://s577.photobucket.com/albums/ss212/blackhawke88/?action=view&current=1ad67646.mp4
  2. Jun 19, 2011 at 7:31 PM
    Special_K
    Special_K o_o
    Eddie
    Alameda, CA
    2014 Subaru STI hatchback
    Tuned by Snail Performance, 305WHP/350TQ on E85, Corsa Pro Series black tip CBE, Perrin CAI, Perrin ELH, Invidia catless DP, ID1000 injectors, Turbosmart Dual Port BOV, Turbosmart IWG Actuator, Cobb FPR, Perrin motor and tranny mounts, Moroso dual catch cans, Cobb AP V3, Grimmspeed turbo heatshield, Grimmspeed EBCS, Perrin pitchstop mount, Kartboy bushings, battery tiedown, oil cap, Perrin reverse lockout leaver, Hella Supertones horns, GT-Spec flat bottom steering wheel, Rally Armor mudflaps, Pioneer 4600BT HU, JL Audio door speakers, sub, and amp, Weathertech floormats, Grimmspeed LWCP, Perrin front license plate delete and relocator, Perrin alternator and radiator shrouds, Grimmspeed master cylinder brace, TWM Gunmetal M1 Abrams shift knob, Defi boost and oil pressure gauges, SMY Clustermaker dual gaugepod, JDM black side badges, Greddy magnetic oil drain plug
    subbed!
  3. Jun 19, 2011 at 7:39 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    So you're 2WD assuming?!
    Nice looking truck, new wheels & tires would finish it off nice :thumbsup:
  4. Jun 19, 2011 at 7:45 PM
    vitang
    vitang Well-Known Member
    diamond bar
    07 TRD Sport 4wd
    Engage Front Long Travel, Giant Rear Long Travel, KR Fab rear bumper, tire gate and Jerry Can cage.
    That's your truck I saw at Engage. Nice
  5. Jun 19, 2011 at 10:41 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    Sweet!! Looks good. I need to pick up some of those fenders.
  6. Jun 19, 2011 at 10:48 PM
    bluetaco80
    bluetaco80 Well-Known Member
    Rob
    fullerton ca
    06 prerunner dc sb longtravel
    Full engage longtravel front and rear
    Saw ur truck at engage..lookin good man
  7. Jun 20, 2011 at 12:22 AM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    Sweet truck, did you install the bedside yourself or did Engage install them?
  8. Jun 20, 2011 at 8:34 AM
    SoCalRoadie
    Jim
    Burbank
    I had Engage install them. Between their schedule and mine we kept pushing back the delivery date... so I kept adding more parts... :cool: I'm very happy with the result and how well the glass fits all around.
  9. Jun 20, 2011 at 8:37 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    Damn :drool: nice truck bro!!! :D
  10. Jun 22, 2011 at 7:31 PM
    SoCalRoadie
    Jim
    Burbank
    Fedex delivery today... Now I just have to wait for Grabbers to come back in stock... :)
  11. Jun 22, 2011 at 7:42 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Off to good start!
  12. Jun 28, 2011 at 7:47 PM
    Socalrunner
    Glendora
    Icon Coilovers
    Hey man can you do me a favor and measure the front fender where it mounts to the body to where it come out the furthest. I have the 4 inch flare glassworks but i would like to get ones like yours. Im building a bumper and want make it the correct width to make it look nice. Thanks in advance man i appreciate it.
  13. Jun 28, 2011 at 7:53 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    this trucks gonna look good subbed
  14. Jun 28, 2011 at 8:01 PM
    OneJay
    OneJay that non tacoma guy
    Brian
    Blackhawke's big spoon
    No tacoma. :(
  15. Jul 1, 2011 at 8:41 AM
    SoCalRoadie
    Jim
    Burbank
    From the hood to the widest part of the flare is 12-12.5".
    IIRC the front is now 91" wide with the flares.
  16. Nov 14, 2011 at 11:58 AM
    SoCalRoadie
    Jim
    Burbank
    Rear shocks and bumps ordered... :)
  17. Nov 14, 2011 at 12:16 PM
    SoCalRoadie
    Jim
    Burbank
    Working with Engage. They have a pile of parts waiting for me when I get home.
  18. Nov 14, 2011 at 5:12 PM
    Fiolo
    Fiolo Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
    Sick taco,the glass looks great
  19. Dec 19, 2011 at 9:26 PM
    SoCalRoadie
    Jim
    Burbank
    Finally home after 6 months... swinging by Engage on Thursday... ;)
  20. Dec 29, 2011 at 2:19 PM
    SoCalRoadie
    Jim
    Burbank
    Truck is at Engage getting the rear LT done. I have a Cobra 75 and Kenwood 281 on its way. Rigid Duallys Flood pattern are ordered. 35" Dynapro ATMs are sitting in the garage. 4.56s are waiting for the group buy to finish.
    Am I missing anything? Or should I be good for bit? 0:)
