Soft Bouncy front end problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by RolesG, Nov 12, 2023.
  1. Nov 12, 2023 at 9:42 PM
    RolesG
    RolesG [OP] Member
    '00 Base 5MT
    Hi -
    New poster here, although I've lurked for a while without posting
    I've got a 2000 2wd tacoma (base model) that I've had for a few months now. It's always had a problem where the front end was super soft and bouncy. I've seen a few posts around the internet about the same problem, but not with the base model truck, so I figured I'd post something here.
    2 months ago, I replaced front and rear shocks with KYB Excel-G replacements, which solved my rear end bounce but the front end remains bouncy as heck. I have no clue what could be happening.
    I'm going to do upper and lower ball joints soonish, so I figured while I'm at it I might try and tackle the bounciness too, but I have no idea where to start.
    Any ideas?
  2. Nov 12, 2023 at 11:28 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Tire pressure and load rating.
  3. Nov 13, 2023 at 12:29 AM
    RolesG
    RolesG [OP] Member
    '00 Base 5MT
    I have checked both of those things already
  4. Nov 13, 2023 at 12:33 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    how many miles on the truck. Maybe it's time for new coil springs up front.
  5. Nov 13, 2023 at 12:44 AM
    RolesG
    RolesG [OP] Member
    '00 Base 5MT
    Yeah that's what I was thinking too, I'm going to measure ride height when I get some time later this week. ~190k on the truck currently
  6. Nov 13, 2023 at 10:03 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If new front shocks didn't improve things then it's probably normal. Those little 5 lug trucks are basically a Camry with a truck bed
  7. Nov 13, 2023 at 10:32 AM
    RolesG
    RolesG [OP] Member
    '00 Base 5MT
    That's what I thought 2 months ago but I've recently noticed some cupping in my front tires which is a telltale sign of bad shocks. Now I'm questioning the integrity of my springs and shocks up front
  8. Nov 13, 2023 at 10:36 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    rocknbil likes this.
  9. Nov 14, 2023 at 3:07 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Agreed, bouncy is probably coilovers. Shocks control the speed at which the suspension move, springs and leafs control how much the suspension moves. Hit the people up at suspensionlifts.com, they are quick to respond via email and after a lot of searching had the best price on assembled coilovers. They can set you up with a set that is stiffer than stock.
  10. Nov 14, 2023 at 7:50 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    While my truck was not "bouncy", it would pitch and roll when I drove over dips in the road. It was especially bad on the interstates.
    When I replaced my tires with Michelins, all that went away.
    Problem is, the tires I replaced were also Michelins...
    I had a lot of cupping on my tires because I kept them inflated to the pressure stated on the door jamb (28 psi) and that was severely understated for the tires I was using.
  11. Nov 14, 2023 at 8:15 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I wouldn't spend money on springs, if they were bad the truck would be sagging and riding lower than normal in the front. Thats really the only way they can fail.
    You've already replaced the shocks, and KYBs aren't a crappy brand. It's possible you got some defective shocks right out of the box but I doubt it.
    You've only had the truck a few months, I'll bet you're just not used to how squishy and basic the suspension is. Suspension wise, it's got more in common with a 90s Buick LeSabre than a 6-lug Tacoma
  12. Nov 14, 2023 at 9:35 AM
    RolesG
    RolesG [OP] Member
    '00 Base 5MT
    I took my truck to both my shop teacher (he teaches steering and suspension) and another shop, they both agreed the shocks weren't working correctly. I'll be taking my truck in to get new shocks put in, and AutoZone agreed to refund me for the defective ones. Really surprised about the KYBs being broken but I guess they're not perfect.
    I'd do it myself but I don't have the time at the moment, and the shop will also give me a warranty on the new ones.
  13. Nov 14, 2023 at 2:09 PM
    rocknbil
    Bill
    The consensus here is Bilsteins are the closest to stock replacements, have a co-worker who bought a new Taco and I guess they are stock now.
  14. Nov 14, 2023 at 2:58 PM
    RolesG
    RolesG [OP] Member
    '00 Base 5MT
    I'd buy Bilsteins but they're just too dang expensive for me.
