Soft brake fix ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smcgill, Jul 10, 2017.
  1. Jul 10, 2017 at 4:04 AM
    smcgill
    smcgill [OP] Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Ok
    My brakes are soft or I have to push almost to the floor to get them to work.
    What should I look for , Yes the brake fluid is full ?
  2. Jul 10, 2017 at 4:08 AM
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    Did this just start, or has it been happening for a while?
    Start by bleeding the brake lines to ensure you do not have air in the lines.
    boogie3478 likes this.
  3. Jul 10, 2017 at 4:19 AM
    Clearwater Bill
    Billy
    Largo Florida
  4. Jul 10, 2017 at 4:36 AM
    smcgill
    Sean
    Funny I guess it's been happening for while , and I noticed how much it took to stop yesterday.
    Is the seals easy to replace , any write ups?
  5. Jul 10, 2017 at 4:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    I've rebuilt before, but for the time/effort I think a new master might be a better choice.
    BTW, I agree w/others that bleeding/adjustments are the first step.
    Free, easy, and you need to do them anyway, even if the master is ultimately the problem.
    taco2010trd likes this.
  6. Jul 10, 2017 at 5:02 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Clearwater Bill likes this.
  7. Jul 10, 2017 at 5:28 AM
    DallasTX
    2015 4x4 AC
    If you decide to bleed the brakes, suggest making sure you have clean fluid in the reservoir. Seems like replacing the brake fluid is frequently overlooked and it absorbs moisture over time. The fluid should be almost clear.
    Some folks use a turkey baster to remove the fluid from the reservoir, but I like to use a spray bottle as I think it makes less of a mess. Then fill the reservoir and bleed each line until it runs clear. You can buy a power bleeder, or get somebody to pump the brakes, but it is just as easy to do letting it gravity drip. Takes longer, but works and only cost is for the fluid and short length of tube....and any beverage you drink while letting it drip.
    smcgill[OP] likes this.
