Soft brake pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brad67, Oct 18, 2024.
  1. Oct 18, 2024 at 4:40 PM
    brad67
    brad67 [OP] Member
    Robin
    2005 Indigo Blue TRD Sport
    I have a 2005 Tacoma Access cab with 195K on it, I recently had a problem with the front brakes dragging so I replaced the flex lines , front and rear, which did not solve the problem, replaced the calipers, no more dragging but brake pedal was soft after repeated bleedings, replaced master cylinder, pedal feels firm without engine running but as soon as I start it pedal will slowly go to floor while putting pressure on it, have tried bleeding them several times to no avail, don't know what to try next.
  2. Oct 18, 2024 at 5:28 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    You most likely have air in the ABS lines. You will need to have the dealer bleed it.
    Springsboy and inwood customs like this.
  3. Oct 22, 2024 at 2:58 PM
    brad67
    brad67 [OP] Member
    Robin
    I bought a Foxwell NT630 Plus scan tool ( currently 119.00 on Amazon ) as it was advertised to do the ABS Auto Bleed , which it doesn't on my truck, may work on newer models , but I was able to activate the pump motor on the ABS Module and flush the air out of it after which I bleed the system with my Motive pressure bleeder and now have a firm brake pedal again, hope that helps others having the same problem.
    Micbt25 likes this.
  4. Oct 22, 2024 at 3:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    Method you used to accomplish that?
    Good job!
  5. Oct 22, 2024 at 5:07 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I also got the same Foxwell model. I have a 2015, I haven’t had to use the Foxwell to activate the ABS, assuming that function will work. I’ve used the Motive bleeder to bleed my brakes successfully. I’d also be curious on the method you used to activate the ABS. Thanks
  6. Oct 22, 2024 at 10:35 PM
    brad67
    brad67 [OP] Member
    Robin
    Used the OBD2 button and from there you can get to the ABS system and cycle the motor.
    Micbt25 and mit88 like this.
  7. Oct 23, 2024 at 12:19 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Good job in finding your solution rather than pay the stealer :spending:doing it.
  8. Oct 23, 2024 at 8:19 AM
    brad67
    brad67 [OP] Member
    Robin
    Thanks, would rather spend the money on a tool that I can use and not just throw it at the dealer .
  9. Oct 23, 2024 at 8:35 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Just replaced that stupid star adjuster apparently it was siezed.
    Made the breaks pedal 60% better.
    instead of stepping on a cake, I’m stepping on a spring.
  10. Jan 1, 2025 at 3:14 PM
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    This the best budget scan tool!
