soft clutch pedal
Discussion in 'X-Runners' started by dice804, Jun 25, 2011.
  1. Jun 25, 2011 at 9:56 PM
    dice804
    dice804 [OP] New Member
    Paul
    scv
    06 X runner
    my clutch seems to have gone soft on me for some reason :confused: not sure wat it could be it started happening after some hard driving today it has happend before but this time doesnt seem to go away
  2. Jun 28, 2011 at 11:20 AM
    bram
    bram Well-Known Member
    Bram
    belgium
    08 x-runner
    bedlid. custom made intake ... dt shorties and a flowtech warlock mufler lpi install and some music
    get a performance clutch kit when myne started to go soft it died soon
  3. Jun 28, 2011 at 10:22 PM
    dice804
    Paul
    scv
    06 X runner
    its odd tho because the feeling comes back to normal after a while then it goes soft again and my clutch grabs fine still
  4. Jun 28, 2011 at 10:24 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    maybe try and bleed the clutch?
    just a thought
  5. Jul 7, 2011 at 5:14 AM
    bram
    Bram
    belgium
    08 x-runner
    it will be the trowoutbearing u best get it replaced and upgraded before the complete clutch and pressure plate will be destroyed
  6. Jul 7, 2011 at 10:23 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Really?? How do you figure that?
    I would say its most likely the hydraulic system, either the clutch master or the slave cylinder, the TB would make noise, not cause a soft pedal.
    One way to check it is to depress the pedal for about one minute, if it feels like it has lost pressure at that point you have a bad seal in the slave or clutch master. I replace this stuff all the time, however it seems that I replace the masters more often than the slaves...just my .02.
  7. Jul 15, 2011 at 3:51 PM
    bram
    Bram
    belgium
    08 x-runner
    my truck is sitting in repair. now ive had a soft feel to the pedal when driving it to the limit and after a while (2 monts) it started to make noise then it died on me letting me sit beside a highway towtruck came and the guy from toyota let me see what happened. ive ordered an new clutchkit and flywheelcombo and also the upgraded tb from urd i hope this will be the last one ive got to buy causse clutches arent the best part (killed 2 oem and one upgraded kit ) on my toyota
  8. Jul 16, 2011 at 12:50 AM
    rnu7634
    rnu7634 Active Member
    Way Bax
    NC
    2013/2006 Tacoma 4.0 4x4
    Ironman 4x4 lift/Light Racing control arms/wheels/tires/handmade Satoshi Grill
    Try Bleeding the system
