Soft Rev-Limiter Delete
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mambojohn, Jan 18, 2025.
  1. Jan 18, 2025 at 11:14 PM
    mambojohn
    mambojohn [OP] Active Member
    SoCal
    2020 TRD OR Prerunner
    Was wondering if anyone knew about a tune/modification available to remove the engine shutoff switch that occurs when you hit the rev limiter.
    Hit the local sand dunes here and there and would find it advantageous to have the same sort of hard rev-limiter in the second gen. and prior pickups. Like this:
    https://www.instagram.com/reel/DEWKLwRCIje/?igsh=NjZiM2M3MzIxNA==
    It seems that this can partially be achieved in the third gens, but only when you mash on the gas shortly after the engine shutoff occurs:
    https://youtu.be/erkrFDIeHRg
    FYI: I don’t care about repeatedly smacking the rev-limiter on the 2GR-FKS. My engine is not gonna blow up. It’ll just make cool noises and get me up a dune without the potential to bog because of a stupid “safety” feature.
    Kodiak420 and soundman98 like this.
  2. Jan 18, 2025 at 11:18 PM
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    I'm confused as what the point is here
    hoodwinked and Chew like this.
  3. Jan 18, 2025 at 11:29 PM
    mambojohn
    SoCal
    Taco go bang bang bang bang
    SoonToBeOn39s[QUOTED] likes this.
  4. Jan 18, 2025 at 11:31 PM
    SoonToBeOn39s
    My catless taco makes loud bang bang bang bang
  5. Jan 19, 2025 at 12:18 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Subbed because i'd love this in my wifes built manual trans 2017. Been a pain when wheeling sand or snow and you bump into the rev limiter only for it to pull power and drop the RPM. A quick clutch dump and floor it again does the trick but sometimes in that short bit of time you loose enough momentum that you fail to make it through or up what you were trying to. 2nd gens will sit on the limiter all day if you want it to. :biggrin:
  6. Jan 19, 2025 at 2:07 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i'm definitely interested in this as well. it's one of my bigger annoyances with the truck. just let me bounce off the rev limiter and hold it!
    Kodiak420 likes this.
  7. Jan 19, 2025 at 3:22 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i assume one of the tuning companies can do something about this? or is it the traction control system overriding the throttle inputs
  8. Jan 19, 2025 at 4:06 PM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Can't a tune do this?
    I have bumped off the rev limited a couple of times, sometime when I forgot I left it on S1...
    Trucks rev limit was also raised to 7k also.
    Never had a engine shutoff, but I have been tuned since 2018 so...
    mambojohn[OP] likes this.
  9. Jan 19, 2025 at 4:37 PM
    mambojohn
    SoCal
    I don’t think it’s the traction control system, as I have it turned off completely when driving in the sand. The only thing that cannot be turned off completely by “normal” means is the ABS system, but that wouldn’t seem to be the issue either.
    soundman98 likes this.
  10. Jan 19, 2025 at 5:38 PM
    devinzz1
    devin
    2023 aclb trd or mt
    it can never be turned off fully. you can hold down for 10 seconds or whatever and it can be most of the way off but never fully off and it cant be tuned off. or atleast it couldn't be when orange virus tuning (vftuner) was trying around the time they were building their turbo kits. that part of the ecu could cut throttle inputs and even apply the brakes on its own no matter what they tried
    mambojohn[QUOTED][OP] likes this.
  11. Jan 19, 2025 at 10:34 PM
    StreetSr5
    StreetSr5 Well-Known Member
  12. Jan 19, 2025 at 11:44 PM
    mambojohn
    SoCal
    Sounds very nice :D
    Seems that the driver had the automatic transmission and was using the “‘S’ shifting” feature. But beyond that, I’m lost on how the fella was able to ride the limiter too
  13. Jan 20, 2025 at 6:11 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    With a long press of TC button, it absolutely does turn off TC and VSC completely.
  14. Jan 21, 2025 at 11:29 AM
    devinzz1
    devin
    2023 aclb trd or mt
    for the most part yes but not "completely". the system is still active in a way and is the part of ecu responsible for cutting throttle in specific instances like when speed governor is hit. which is why im wondering if its also responsible for cutting throttle when rev limiter is hit.
  15. Jan 21, 2025 at 12:04 PM
    black3rdgen
    black3rdgen Well-Known Member
    STL
    3G on 35s, 5.29s
    YW E30 tune, 5.29s, equal length dual exhaust, 2000w audio system
    Have tried figuring this out with yotawerx, seems like nothing can be done unfortunately. Thats my YT vid, just gotta hop on and off the gas super fast.
  16. Jan 21, 2025 at 12:55 PM
    SoonToBeOn39s
    I was about to say. In snow I would do the same thing. It sounds like it's constantly on the limiter but you have to hop on and off
  17. Jan 21, 2025 at 2:09 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Regardless of the details of operation, a rev limiter is a nanny. I suggest learning to control the engine rpm yourself. Once you master that skill, you can move on to the manual transmission. Yes I’m trolling you guys. :)
    soundman98 and SoonToBeOn39s like this.
  18. Jan 21, 2025 at 6:03 PM
    soundman98
    NW Indiana
    agreed.
    i can confirm at harder angles and higher wheel speeds, the traction light definitely still comes on. doing snow donuts in a parking lot and then trying to exit the donut while maintaining revs, but countersteering to offset the rotation is usually enough for the tcs light to start blinking.
    #know your vehicle limits!
  19. Jan 21, 2025 at 6:03 PM
    soundman98
    NW Indiana
    that sucks. thanks for saving me the time and effort though.
  20. Jan 21, 2025 at 6:37 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I dont know about the "rev-limiter" part.
    I was talking about TC and VSC, long press shuts those two off completely.
