Soft tonneau cover recommendations?
Discussion in 'Tonneau Covers, Caps and Shells' started by spach, Oct 21, 2020.
  1. Oct 21, 2020 at 10:54 PM
    TacoLad
    TacoLad Member
    Bronson
    Fenton, MI
    2016 Tacoma SR5 Double Cab LB
    1.5" Level, 33" Mickey Thompsons, "wEiGHt REduCtiOn"
  2. Oct 22, 2020 at 1:46 AM
    Scarab
    Scarab Well-Known Member
    2017 White Tacoma TRD Pro
    I have the Diamondback. I like it because it provides a little more security for items I store in the bed. Mine is water tight and haven’t had any leaks.
  3. Oct 22, 2020 at 4:39 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
  4. Oct 22, 2020 at 9:36 AM
    Qmobile
    Qmobile Well-Known Member
    McClure, Oh
    '18 SR AC 4X4 Utility package
    Current: LED interior, plate and reverse lights Bedmat Hitch Interior rubber cupholder mats LED headlights Fog lights (LED of course) Hidden LED bumper bar Upgraded Speakers Tailgate inserts Blacked out 4x4 emblem Tuffskins glovebox inserts Pro Grill Bedcover OTT Tuned Future: Front Skid plate ????
  5. Oct 22, 2020 at 9:38 AM
    Naszero
    Naszero Well-Known Member
    2021 Cement DCSB TRD OR 4x4
    I just ordered a Lomax tonneau cover due to its low profile and excellent user feedback on the forums. It's also affordable at under $700 shipped.
    Taco_mike73, Woodylz and Qmobile like this.
  6. Oct 22, 2020 at 9:38 AM
    Rapidfire1
    Rapidfire1 Well-Known Member
    Shaun
    York Pa
    2016 Black TRD Sport DCSB MT
    I had a bakflip vip( similar to mx4) that lasted about 4 years before before starting to come apart but I think they were discontinued for that reason, replaced it with the revolver and I'm very happy with it
  7. Oct 22, 2020 at 9:47 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I have the same cover and have been happy with it for about a year and a half now. IMO its the best looking one out there.
  8. Oct 22, 2020 at 10:40 AM
    TacoBoutNothing
    TacoBoutNothing Well-Known Member
    2019 White TRD Pro
    I've had both Bak Revolver and now a Truxedo Sentry CT. So far, I prefer the Truxedo. The Bak was replaced once under warranty, as the glue started to fail and the cover literally came apart. Also note that it was not a full replacement...I had to pay 50%. This truck was also parked in my garage. It did not do well with California sun and heat. The Bak was more secure of the two, as it had full length latches into the bed rail. The Trux only has a front, mid, and rear latch. The Bak had a bed length water seal and worked pretty good. The Trux uses velcro on the edge which works great, but you have to remember to mash it down along the edge of the bed after you unroll the cover. I prefer the Truxedo convertible top (CT) material over the black vinyl of the Bak, but that's just opinion. I don't remove the cover very often, but if you do it's hard to beat the Trux mounting system. You can remove it from the truck in short order. The Bak was a little more involved and harder to re-align properly. Both covers can be broken into, with nothing more than a stout flat blade screwdriver. I think "out of sight, out of mind" applies here. Neither of mine have been broken into that I'm aware of, but between a Pop Lock and a hardcover I feel pretty good about leaving stuff back there.
  9. Oct 22, 2020 at 11:00 AM
    holvey
    holvey Well-Known Member
    Brian
    Portland, OR
    2020 DCSB TRD OR
    I also have the Sentry CT, and after my initial problem with a damaged seal and poorly installed end caps on the rails, I have been happy with it. I also think it is the cleanest looking cover out there. When it's closed, it looks seamless, and doesn't stand up off the bedrails that much. When it's rolled up, you can still see out of the top half of the back window.
  10. Oct 22, 2020 at 11:15 AM
    Westsideott
    Westsideott Well-Known Member
    Ottawa, ON
    2020 DCSB OR
    Are those taillight covers or tint? Look sharp. Do they reduce light output significantly?
  11. Oct 22, 2020 at 11:27 AM
    JP3
    JP3 Well-Known Member
    JP
    2020 SR5 /DCLB /MGM//////B7 Audi RS4
    285/70/17 Falken WildPeak on Stealth 6 Eibach Lift
    I really like the Extang Encore I picked up on FB marketplace. Has yet to disappoint. Doesn't stick up a lot like other covers I've seen and has nice rounded edges.
    mallege likes this.
  12. Oct 22, 2020 at 11:51 AM
    mallege
    mallege Well-Known Member
    George
    SW Idaho
    2019 Tacoma SR Gray SB Auto V6
    Extang tonneau cover, variable speed wiper stalk, hood struts, ScangaugeII.
    I am satisfied with my Extang Solid Fold. Easy to install in a few minutes. Can simply fold back and secures to a single stack. I have taken mine off twice for carry taller objects and reinstalled easily.
  13. Oct 22, 2020 at 11:54 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    I almost got one of these and probably will unless I find a heavy discount on the retrax ones. I dont like the idea of a trifold on a 5ft bed.
  14. Oct 22, 2020 at 11:56 AM
    ptothegdotcom
    ptothegdotcom Well-Known Member
    P
    SOCAL
    2020 TRD OR PREM DCSB
    There is nothing like the Retrax Pro XR. I had the OEM Tacoma cover but moved to this about 2 months ago and I love it. Highly recommended. Been trying to find a Tacoma owner close to me (Socal) that wants my OEM one but its complicated in COVID times. Taking up space in my garage and my wife said to get rid of it.
  15. Oct 22, 2020 at 12:05 PM
    #35
    Punkface
    Punkface Well-Known Member
    Colorado
    2020 Tacoma TRD Off-Road DCSB 4x4
    Our family has used two of the Tyger rollup ones on Amazon for $200-ish. No problems here.
  16. Oct 22, 2020 at 12:28 PM
    #36
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I like the roll-up.. its a little more work to get secured (few seconds to adjust the velcro sides tight) but it can be rolled completely out of the way where the tri-fold cannot with my RTT on.... I roll mine up to access the Fuel and water Jerry cans at the front passenger side of the bed..
  17. Oct 22, 2020 at 1:14 PM
    #37
    maximum
    maximum Well-Known Member
    LoMax aluminum. Going on 2 years. BB53C44D-2900-4690-8F81-662A71123DB9.jpg 22BAF351-B514-45E7-91CC-0265AD2ECE36.jpg
    Taco_mike73 and Woodylz like this.
  18. Oct 22, 2020 at 5:13 PM
    #38
    Noveske777
    Noveske777 Well-Known Member
    Will Metcalfe
    2020 Tundra OR
    Stock
    fmb likes this.
  19. Oct 22, 2020 at 6:14 PM
    #39
    eclane
    eclane Well-Known Member
    2020 Black TRD OR DCSB
    Lomax +1
    Woodylz and Taco_mike73 like this.
  20. Oct 22, 2020 at 6:25 PM
    #40
    Spidicus
    Spidicus Well-Known Member
    Nevada
    19' DCSB TRDOR 4x4
    Lomax all the way. Removes in seconds with no tools.. and allows more clearance between the bed floor.
