Soft Topper
Discussion in 'Product Reviews' started by roughnready62, Feb 23, 2009.
  1. Jul 1, 2011 at 10:01 PM
    #41
    drive.n.surf
    drive.n.surf Well-Known Member
    Seattle, WA
    2007 DCSB 4x4 OR
    Bilstein 5100's all around, front @1.75", rear AAL 1.5", TRD CAT-back exhaust, Pop n' Lock, Smittybilt nerfs, Toyota roof racks, Spyder LED tail lights, LED third brake light, Undercover Classic tonneau, color-matched grill, debadged and replaced with Sockmonkey decals
    If you use the Soft Topper to sleep in like a tent, I would recommend getting the optional screen window. The ventilation inside the Soft Topper is not like a tent and eventually moisture will develop if you use the standard vinyl windows. The screen window is great and no moisture develops when I use it. However when it is raining I had problems with water entering from outside. I made an awning out of nylon tarp and PVC pipe and problem solved.
    dirtnsmores, yis4yimmy, msfit and 8 others like this.
  2. Jul 8, 2011 at 3:56 AM
    #42
    spranger85
    spranger85 Member
    Iowa
    TRD sport 4x4
    No one has answered if you can open the "front" window on the topper for access to the cab.
  3. Jul 8, 2011 at 2:23 PM
    #43
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    NO it doesn't open. Its kind of a bummer but I really like my softopper.
    Note mine does leak ever so slightly even after sealing the seams.
  4. Jul 8, 2011 at 2:49 PM
    #44
    spranger85
    spranger85 Member
    Iowa
    TRD sport 4x4
    That sux, I need something that opens for dog in the summe. Thanks
    mahaloTaco likes this.
  5. Jul 9, 2011 at 2:10 PM
    #45
    Piratefish
    Sebastopol
    Sadly None
    You can however remove the entire front panel. I have never done this though. I think it might balloon up with air when driving.
  6. Jul 18, 2011 at 11:31 AM
    #46
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    I ordered my Softopper today with a "doggy door" in the front panel, for only $10 more. I got it in black with a gray roof panel. If you call the manufacturer, they can sometimes do some minor changes like that.
  7. Jul 22, 2011 at 9:29 PM
    #47
    jrb737
    jrb737 Member
    Jeff
    Colorado
    Softopper, Kenwood Stereo, Xtant amp, Boston acoustic Sub and speakers. Spray on Bedliner.
    Hello all, new to the forum and wanted to say I have had my Softopper for several months now. I am very happy w/ it even though it leaked at the seams when I first got it. The company sent me 2 tubes of "Seam Grip" (not the "Seam Sealer" they initially give you) and I put this stuff on every seam and it has not leaked since! http://www.mcnett.com/Seam-Grip-Seam-Sealer-Outdoor-Repair-P133.aspx
    The topper is great. I can fold it forward and get my atv in the bed, take it off and load firewood in the bed, or leave it up and camp in it. It also keeps all of the dust off of your things in the bed when going camping.
    I have no problem with the topper flapping while driving 80mph down the highway. It is a very snug fit.
    I've attached a few pics.
    Jeff
    Taco Addiction and TacoHilux like this.
  8. Jul 30, 2011 at 5:46 PM
    #48
    blatant
    blatant Well-Known Member
    3yr report. I have the 6ft bed. Two long mile trips, 70-80mps, no problems at all.
  9. Aug 6, 2011 at 7:36 PM
    #49
    TomHGZ
    Installed mine the other day. Wanted a 2-tone just for something different. The black looks nice on the sides, but the white will keep the contents cooler in the South. Softopper did this for no additional cost.
    Am satisfied by the quality for the most part, though some of the hardware seems a little flimsy for a product designed to go on the back of an otherwise very "abusable" truck.
    Will go to the metal shop on Monday to have some of the plastic hardware replaced by metal instead. Even some of the metal parts need an upgrade.
    This is not a waterproof design. It will keep the rain off, but unless you elevate your cargo off the bed floor, it will probably not stay dry.
    Also, get those convex side-view mirrors to help with the lack of visibility.
    All that said, I am happy I went with Softopper over Bestop, for the reasons mentioned by previous posters. The lines of this top look really good in person, and it will take very little work to upgrade the weaker components to expedition quality. The versatility Softopper provides over a hard top, a naked bed, a tonneau cover, or even Bestop (which no longer offers mesh windows), is well worth it.
  10. Aug 6, 2011 at 8:35 PM
    #50
    blatant
    great stuff
  11. Aug 7, 2011 at 6:13 AM
    #51
    donanoyus
    donanoyus New Member
    Scott
    De Pere, Wi
    08 Blue TRD Sport
    This is a great thread.. I looked at the softtopper awhile back and didn't get one because I couldn't tell if you have to take the whole contraption off the truck when you collapse it.
  12. Aug 7, 2011 at 7:03 AM
    #52
    blatant
    you don't need to take it off when collapsed. You can leave it at the back of the cab folded down. They even provided a bag to slip around it if so desired. Or you can remove the whole thing by removing two cotter pins.
  13. Aug 7, 2011 at 3:20 PM
    #53
    TomHGZ
    Hi blatant, I didn't say "isn't working right" or "shitty".
    I did use the word "abusable": something I want in a truck. The plastic cradles that secure the bar at the bottom of the rear flap could easily be broken with heavy use or loading/unloading heavy equipment from the bed or the contractor's rack soon to be installed over this topper.
    I'm also going to replace the metal clips that fasten into those cradles with beefier ones from the hardware store, because I can't tell you how many of those I have overloaded and bent or broken on luggage.
    As I said, I am satisfied with my purchase of the Softopper. I think it's a great product. I wholly recommend a Softopper to anyone who needs versatility, and I would buy one again. But I rarely leave anything unmodified, and the Softopper is not an exception. My truck is being purpose-built for disaster relief, and I don't want anything breaking and slowing me down in the middle of a disaster zone.
  14. Aug 7, 2011 at 8:28 PM
    #54
    blatant
    post up pics of your adjustments/mod's when you're done. If it betters the product i would certainly add it to mine as well! Good luck!
  15. Aug 7, 2011 at 10:03 PM
    #55
    bboynowee
    bboynowee Well-Known Member
    Riverside
    17 TRD 4x4 Tacoma OR, 18 4Runner TRD, 18 TRD 4Runner
    Stage 4 Icon, Icon Rebound Wheels, DeMello Hybrid Sliders, Prinsu roof rack
    Me likey!
  16. Aug 7, 2011 at 10:57 PM
    #56
    drive.n.surf
    Seattle, WA
    2007 DCSB 4x4 OR
    Softoppers are the best!
  17. Sep 20, 2011 at 1:56 PM
    #57
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Wow, glad I found this thread. I've been wanting to get a Bestop, but it's looking like the Softoppers could be better suited to my needs. One question: The company website says that you can drive with the side/rear panels rolled up. Anyone have any experience with this? I assume it would be fine for city speeds, but how about highway speeds?
    EDIT: Another question. According the the product video, the sides snap onto the rail. How does the back flap attach the top of the tail gate?
  18. Sep 21, 2011 at 12:12 PM
    #58
    Piratefish
    Sebastopol
    Sadly None
    ^ They supply you with Velcro. I didnt use it and was considering sewing magnets into the back flap...but never did. It dosent flat or anything like that but it may leave wear marks on the paint if you leave it on for a long time. I love mine.
  19. Sep 26, 2011 at 1:18 PM
    #59
    Okkine
    Alberta
    Good to know! Thanks.
  20. Oct 9, 2011 at 11:36 PM
    #60
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    I had a tan one on my white '99. I loved this top. It was a great top. The only downside is, you may see some reduced MPG due to wind drag. I have a Leer top for my truck now and am looking to sell it for a new Softopper. May just wait till April or June.
    If you are concidering a top, concider this one.
