Soft Topper
Discussion in 'Product Reviews' started by roughnready62, Feb 23, 2009.
  1. Jun 11, 2012 at 8:10 AM
    #121
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    @ Grund. I was able to stick the 3M velcro on the top tailgate protector and my soft topper aligned perfectly. This allowed me to avoid putting anything sticky on the painted portions of my truck. Good luck
  2. Jun 11, 2012 at 12:35 PM
    #122
    Grundletaint
    Grundletaint Well-Known Member
    Austin
    2012 crewmax tundra 4x4
    Debadged, derped, weathertech visors, antennax, tinted, need more money
    i had put it there initially. it kind of works but the bottom edge is all scrunched up as you can see in this pic. does yours fit without having to do that? for all intents and purposes, it works. it's just a little goofy looking and compromises the corners a tad.
  3. Jun 14, 2012 at 10:22 AM
    #123
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    You may want to mount the rails closer to the front of the truck to eliminate the scrunch. I have mine about half inch from the front of the bed and everything aligns perfectly. Now, I still have a little wiggle room on the corners but its a $500 soft topper not a $3000 hard shell.
  4. Jul 5, 2012 at 10:36 AM
    #124
    tellicomoto
    tellicomoto Member
    Michael
    Tellico Plains, TN
    2012 Dbl Cab, Off Road
    Just purchased, armor on order
    Based on the reviews in this thread, I ordered a Tan soft topper today. Putting it on a 2012 Green Dbl Cab. Will post pics when I get it put on.
    mike
  5. Jul 5, 2012 at 11:02 AM
    #125
    Nightwar
    Nightwar .....
    Nick
    Webster, Tx
    11 SR5 V6 4X4 Silver
    Avid sliders & Lightbar, Front 5100s/Eibachs, Rear OME Shocks/Alcan 2" AAL, LR UCAs, Debadged, ProComp 7089s, BF Goodrich All Terrain T/A KO, Wet Okoles, Sockmonkey decals, 2x Kicker CompVR 10s, Pioneer P4300DVD, BHLM
    I am going to get one of these. Any suggestions on where to order it from?
  6. Jul 5, 2012 at 11:06 AM
    #126
    RattleSnake44
    RattleSnake44 Well-Known Member
    SoCal
    06 DCSB PreRunner TRD Offroad
    OME 3" Lift, Dakar Leaf Packs, ARB Front Bumper, Warn M8000 winch
    Softopper.com
  7. Jul 5, 2012 at 11:50 AM
    #127
    Grundletaint
    Austin
    Mine is scrunched because I put the Velcro on the top of the tailgate rail rather than on the face of it. I may extend the plastic arms out and see if I can get by without velcroing it at all.
  8. Jul 5, 2012 at 1:12 PM
    #128
    RattleSnake44
    SoCal
    I ran the rails a little farther back (maybe 1/2") and did not put any Velcro on my tailgate. Just the bar and the little things it pops into. ImageUploadedByTapatalk1341519085.759700.jpg
    Works fine. No flapping at highway speeds and no leakage.
    dirtnsmores likes this.
  9. Jul 5, 2012 at 5:57 PM
    #129
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    Looks good black on silver. I use the velcro to keep dust out, especially needed since we sleep in the bed camping. Just play with both the rails and tabs and you'll find the sweet spot.
  10. Jul 5, 2012 at 6:07 PM
    #130
    Grundletaint
    Austin
    I just noticed that the clamps on mine are different than a couple of others I've seen in the past day or so. Mine go over the rail and clamp on rather than into a hole in the side of the rail like the one above.
  11. Jul 10, 2012 at 3:16 AM
    #131
    prerunner11
    prerunner11 Well-Known Member
    MD
    2011 Magnetic Grey Prerunner Dbl Cab Sport
    Softopper
    Where are you guys putting the snaps for the front flap? I went the velcro route and just put 3 strips of velcro along the top-side of the bed (behind the front accessory rail).
    I normally leave the softtopper up, but with the back and sides rolled up. It worked out great for a while but I'm finding myself pulling over on the highway often because the velcro is coming loose and the front flap is banging against the back window of the cab. Not fun...
  12. Jul 10, 2012 at 7:27 AM
    #132
    CVYota
    CVYota Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    I found a place that cost the same as softopper but had free shipping, I think it was truck candy.
    I ended up putting the velcro on the paint, I didnt want to but it worked best there. I didnt want the flap rubbing on the paint and I figured the glue will come off.
    I used the velcro and the snaps on the front, screwed the snaps right into the front wall of the inside of the bed. It holds very tight, no movement at all.
  13. Jul 10, 2012 at 7:56 AM
    #133
    Grundletaint
    Austin
    I did the same thing with the velcro on top of the rail. That's when I had major problems with the wind pulling it off.
    To fix it, I pulled it down as tight as possible on the inside, put a line of velcro on the wall of the bed, and then followed ag4892's advice and added the snaps. Solid as a rock now. The only bummer is that the snaps aren't spaced in line with the bed ridges so it looks weird when the top isn't on. But I'm just weird about symmetry....
  14. Jul 10, 2012 at 8:06 AM
    #134
    prerunner11
    MD
    Softopper
    Yeah the wind is the cause for me as well.
    Did you remove the front accessory rail? When I set mine up, it got in the way and I don't remember the snaps coming down far enough past it.
  15. Jul 10, 2012 at 8:37 AM
    #135
    Grundletaint
    Austin
    No mine pulls down a good 6-8" past it, nearly halfway down the front of the bed (guessing from memory).
  16. Jul 10, 2012 at 9:36 AM
    #136
    undecided
    undecided Well-Known Member
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    CAI, CB radio, Double Din Stereo, Aero Exhaust, Softopper, BHLM, KODE Push Button Start, Bruteforce Fab Rear bumper, Weathertechs
    My sister has had a soft topper on her first gen for a few years now. I always liked the look and utility. I found a sweet deal on CL for $350 that i just could not pass up. It took me all of 20mins to install and i could not be happier.
  17. Jul 10, 2012 at 6:02 PM
    #137
    Nightwar
    Nightwar .....
    Nick
    Webster, Tx
    Thanks!
  18. Jul 10, 2012 at 8:44 PM
    #138
    Numbnutz
    Numbnutz Well-Known Member
    Oregon
    Slow work in progress
    I ordered mine through lakelandgear.com and also got free shipping. Ordered on a Tuesday and it showed Friday of that same week.
  19. Jul 20, 2012 at 5:52 AM
    #139
    tellicomoto
    tellicomoto Member
    Michael
    Tellico Plains, TN
    Put it on last night. Took about an hour. No problems except the dogs wanted to help. If the tail gate is down, they want to be in the back of the truck.
    VagabondDoc and Taco-Obsessed like this.
  20. Jul 20, 2012 at 10:34 AM
    #140
    RattleSnake44
    SoCal
    Damn, that looks good. Loving the color contrast.
