Soften my RIDE PLEASE
Discussion in 'Suspension' started by Tacoma97Toyota, May 9, 2011.
  1. May 9, 2011 at 11:56 AM
    Tacoma97Toyota
    Tacoma97Toyota [OP] Member
    Los Angeles
    97 Tacoma Reg 2WD
    HELLO,
    I'm new here and recently bought a 97 Tacoma reg cab, 2wd and 2.4l 4cyl engine(wanted something I could lift but still get better MPG than my SUV). Has a 3" body lift as of right now and stock exhaust. I rarely go off road, although the streets of Los Angeles may as well be like minor off roading because they don't know how to make a flat road here. I can't go over 60mph before it becomes too unsafe to drive, too bouncy!!
    Initially it had a FABTECH lift on the front and removed because I HATED the ride. There was absolutely no bounce, aside from the tires so I replaced with stock springs and it has improved the ride by 30%. The previous owner had recently installed Heavy duty KYB shocks in the front and am thinking to replace those to even soften the ride. It's still pretty stiff on the front and rear. Currently running 265/70-15 on it.
    Right now my choices are Monroe sensa-trac OR mid to heavy duty shocks by Gabriel. Price is a factor, I don't have $50-60+ to spend on every shock so my price range is around $30-35 a shock. Any personal experience with either of these shocks or recommend another brand that's not too expensive, I'd appreciate? please include the part number if you know it. Thanks!
  2. May 9, 2011 at 12:59 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Dump the body lift, go back to stock... all the way around, or buy a car.. it is a truck after all :notsure:
  3. May 9, 2011 at 3:24 PM
    lvlytaco
    lvlytaco Well-Known Member
    Allan
    Hawaii
    Got Lip?
    6" procomp basic lift, alpine dbl din, 9" headrest screens, mb quart components, jl amp, yellow top battery, wet okole seat covers all around
    drop psi in the tires and or add weight to the truck to soften the ride
  4. May 9, 2011 at 9:43 PM
    Tacoma97Toyota
    Los Angeles
    97 Tacoma Reg 2WD
    There was almost 36 psi in the tires, I've lowered to 30 now. It helped, much better. Thanks
  5. May 9, 2011 at 10:08 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Well you could go alll out and get king coilovers :D
  6. May 10, 2011 at 9:42 AM
    Tacoma97Toyota
    Los Angeles
    97 Tacoma Reg 2WD
    I might be able to afford a set of Bilsteins on the front. Any recommendations of which model??
  7. May 10, 2011 at 9:43 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    5100s set at 0
  8. May 10, 2011 at 9:48 AM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    What's your tire pressure? This is a huge factor!! Go check and follow up.
    ....Damb, already posted...READ FIRST MJOHN!!!
    When I first got my new rims and tires back from a local tire shop, I put them on myself with a lift kit at the same time. The guys at the shop filled the tires to 60PSI!!! They were following the maximum load psi on the side of the tire. Took me like a month the figure out, I thought the rock hard effect was from the new lift.
  9. May 10, 2011 at 9:54 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
  10. May 11, 2011 at 11:36 AM
    Tacoma97Toyota
    Los Angeles
    97 Tacoma Reg 2WD
    The PSI now is around 28-30psi. What should I set it at?
  11. May 11, 2011 at 11:37 AM
    Tacoma97Toyota
    Los Angeles
    97 Tacoma Reg 2WD
    5100 set at 0, got it - THANKS!
  12. May 11, 2011 at 11:40 AM
    Tacoma97Toyota
    Los Angeles
    97 Tacoma Reg 2WD
    ha, thx for the candy
  13. May 11, 2011 at 11:43 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    yeah thats your best bet. body lifts are always a bad ride.
