Soften my ride
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lucifer1, Jul 3, 2018.
  1. Jul 3, 2018 at 10:11 PM
    Lucifer1
    Lucifer1 [OP] Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    Took the wife Mall crawling today I have 14000 miles on my 2016 Access cab TRD sport At.
    she seldom complains about the vehicles I drive, but today as we went slowly over the speed bumps on the mall parking lot in the 100+ degree heat, these rear shocks have almost no give to them, they feel extremely hard , I think they are Hitachi, any suggestions for a more user friendly rear shock ?
    RobP62 likes this.
  2. Jul 3, 2018 at 10:12 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    5160’s
  3. Jul 3, 2018 at 10:15 PM
    Bishop84
    Bishop84 Well-Known Member
    TRD yellow offroad shocks if you can find a set of take-offs on Craigslist.
    I actually bought a 16 offroad because of how it was softer than the sport or SR5 models.
    vitistop, hiPSI and RobP62 like this.
  4. Jul 3, 2018 at 10:17 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    5160's you mean Bilstiens? are they not also very harsh ?
  5. Jul 3, 2018 at 10:18 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    For very little money you could switch up to the OEM Off Road Bilstein version shocks. Everything I've read say it's a much softer ride than the Hitachi shocks. A lot of guys sell them here on the forum cheap when they upgrade to more expensive shocks. Couple hundred bucks and you're done.
  6. Jul 3, 2018 at 10:19 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    Bishop 84 good to know, T Y
  7. Jul 3, 2018 at 10:21 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    Thanks Robp62
    RobP62 likes this.
  8. Jul 3, 2018 at 10:21 PM
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    Absorbs bumps better and settles quicker than stock. My stock off road shocks were soft but I was bouncing a lot.
  9. Jul 3, 2018 at 10:23 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    Can this just be the rears ? the fronts seam fine to me ?
    Socialrafa and RobP62 like this.
  10. Jul 3, 2018 at 10:27 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You're welcome. @Bishop84 and I are basically saying the same thing.
    Also, and this is a little more dramatic but if you remove the sway bar, going over speed bumps (or similar obstacles) at an angle will stop that sharp, harsh rocking motion that makes your heads bob back and forth. Some guys do it too for more articulation. It will cause a little more body roll at higher speeds. Especially in turns under severe breaking situations. You won't flip though at normal speeds.
  11. Jul 3, 2018 at 10:28 PM
    IllTrucko
    IllTrucko Well-Known Member
    If you decide to go with the stock off road suspension, shoot me a PM. I live down in GP and have a set in my attic with less than 200 miles on them. Should be able to make a deal. Although, based on my personal level of pickiness, I'd recommend you find somebody with whatever suspension you're thinking about and go for a ride with them.
    RobP62 likes this.
  12. Jul 3, 2018 at 10:51 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    The fronts seem fine because the weight of the engine, the cab and the occupants help the front shocks cycle through the full travel distance. The rear weighs less so the leaf springs are providing the additional support, or basically working properly too.
    Try this, go buy like 5 bags of quickcrete cement. Those 80 lb bags. Put them as far back in the bed as possible. Then go over those bumps.
    It will be night and day.
    Just keep in mind, and explain to your wife that it is a truck, and is designed to haul heavy loads. It can only do that if the suspension components, the shocks & leaf springs are built to withstand additional loads. Without those loads though, it's going to ride rougher than most cars.
    It doesn't have to be that way though. It depends how important a cushy ride is to you. If you're not going to haul full loads all the time then try the inexpensive route and get those Bilstein take offs. If you think you're going to haul some weight more often, then run the 5100s and go with an add a leaf and stronger front coils. Then you'll have a softer ride than stock and more ability than stock as well. However you'll start to approach that rougher ride again. Not as bad but.......
    It's hard to have the best of both worlds without spending some moderate money though.
    Thefear87 likes this.
  13. Jul 3, 2018 at 10:54 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    He can buy his wife whatever she wants at the mall
    Load the bed with newly bought stuff
    Ride home nice and cushy
    OR
    Find a new woman, who speaks only when spoken to and doesn’t complain.
    sdsurfer, itsmermf, honda50r and 2 others like this.
  14. Jul 3, 2018 at 10:54 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    This is an excellent idea on both counts. Plus take a ride in his truck to get a sense of what a higher end suspension is like assuming that is why @IllTrucko has the take offs in his attic.
  15. Jul 3, 2018 at 10:55 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    True.
    PROseur[QUOTED] likes this.
  16. Jul 3, 2018 at 11:13 PM
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    I got a set of the Bilstein OR takeoffs and installed it on my Sport. Made a big difference in the ride. The sport suspension was firm and felt more sporty, the Bilsteins are softer and less jarring over the speed bumps. For me, it made the ride better.
    Socialrafa, Lucifer1[OP] and RobP62 like this.
  17. Jul 3, 2018 at 11:16 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I bet she'd like a full long travel suspension.
    Lucifer1[OP] and Mr-Paul like this.
  18. Jul 3, 2018 at 11:19 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Who wouldn't :notsure:
    Lucifer1[OP] likes this.
  19. Jul 3, 2018 at 11:20 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    My wife. She knows enough to know $$$
    RobP62[QUOTED] likes this.
  20. Jul 3, 2018 at 11:26 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That's a good thing right? :thumbsup:
