softer leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sydwayz04, Apr 27, 2012.
  1. Apr 27, 2012 at 5:37 PM
    sydwayz04
    sydwayz04 [OP] Well-Known Member
    Dustin
    belgrade
    11 acc. cab sr5 white
    stero system, couple subs, dwreck sliders, shackel flip, long travel air bags, h.i.d.'s, and some other cool stuff
    so i was woundering if anybody knew of a softer rear leaf pack for out taco's that arent lift springs, i just got done doing my shackel flip to maintain stock ride height and love it but was wanting a softer spring now, but not the stock non tsb ones, was hoping for something like the deavers with more and thinner leaves ? but no lift, thanks
  2. Apr 27, 2012 at 5:41 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Stock is softest. I guess you could takeout a leaf.
  3. Apr 27, 2012 at 6:08 PM
    sydwayz04
    Dustin
    belgrade
    ya thought about that, might give alcan a call on monday and see what they say
  4. Apr 27, 2012 at 6:51 PM
    drsus
    drsus Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    Deaver makes any kind of leaf you want, and they will out-soften the stocks easily.
    If you want to retain stock hight and plusher ride, they'll make you a pack for that if you specify that.
    they run about $600 but they are the best by far.
    heres a great write on them
    http://www.expeditionswest.com/equipment/tacoma/deaver.html
  5. Nov 15, 2016 at 7:07 AM
    Solution.45
    Solution.45 Well-Known Member
    Chase
    Redding CA
    2011 White 4x4 double Cab
    I know this an old ass post but did you ever get the softer leaf spring kit you wanted? if so what kind did you get to maintqin the stock ride height? im looking to do the same thing in the rear. how big of a change does that shackle flip kit do you as well?
  6. Nov 15, 2016 at 7:11 AM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    How much softer can you get mine was bottoming out over a marble size rock!
    bluezzy likes this.
