Softer Ride What Do I Do
Discussion in '1st Gen. Tacomas (1995-2004)' started by clayrb, Jan 21, 2014.
  1. Jan 21, 2014 at 6:53 AM
    clayrb
    clayrb [OP] Well-Known Member
    Oakwood, Ga
    2004 Prerunner SR5
    NA
    I have a 2004 Toyota Tacoma Pre-Runner 2.7 engine and it does have a life kit. My question is what do I need to do to get a softer ride as I don't haul a lot and do not go off road. I'm going to go to road tires but what about shocks?
    Thanks,
  2. Jan 21, 2014 at 9:18 AM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    What kind of lift kit? Is it a top plate spacer?
  3. Jan 21, 2014 at 11:20 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Only way to change the ride quality is with different springs/shocks. A good starting point is to determine what suspension is currently on the truck. You can make decisions after that.
  4. Jan 21, 2014 at 11:20 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Oh and you can lower the air pressure in your tires a little
  5. Jan 21, 2014 at 3:35 PM
    clayrb
    Oakwood, Ga
    2004 Prerunner SR5
    NA
    Thanks guys I will look at it...........................
    The Old Man
