Softer ride
Discussion in '1st Gen. Tacomas (1995-2004)' started by Benk98, Jul 26, 2022.
  1. Jul 26, 2022 at 7:05 PM
    Benk98
    Benk98 [OP] Member
    Ben
    Massachusetts
    2004 Reg cab 2.7
    Everything.
    Hey everyone new to the forum here, just bought a 2002 regular cab Tacoma as a daily. I don’t intend to go off roading anytime soon, just looking for advice for a more comfortable ride on New England pothole ridden city roads. Currently have stock old shocks and worn out tires. Any shocks/struts and tire recommendations? Thank you!
  2. Jul 26, 2022 at 7:07 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If you're not hauling loads or doing anything intensive like towing, maybe get some P rated tires, if you are doing light truck work regularly then perhaps C load tires. That's a good start for comfort after that I'd consider refreshed suspension, some Bilstein 4600 go a long way to making things feel new.
  3. Jul 26, 2022 at 7:15 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Why buy a Tacoma if you wanted a soft Ride?
    Will you be hauling lots of cargo?You can build some custom leaf springs but you lose weight carrying capacity .
    shocks just control the bounce my last set were cheap Monroe`s.
    Tires shop for more of a car tire then a truck tire with a very stiff sidewall run tire pressure on the lower side.Trial and Error
    The difference in ride between my 4Runner and Tacoma I think something is broke on the 4Runner it rides so soft .
    Good Luck >
  4. Jul 26, 2022 at 7:18 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Like stated, tires make a big difference. I would suggest p rated tires. Or sl load. And keep them around 30 psi. Lots of shops inflate them to 38psi, and that’s way too much.
    you can get bilstein shocks, but they are digressive valved. So stiff on the road untill they hit some bumps. Not sure of progressive shocks for cheap, but king and fox shocks are.
  5. Jul 27, 2022 at 1:58 PM
    Benk98
    Benk98 [OP] Member
    Ben
    Massachusetts
    2004 Reg cab 2.7
    Everything.
    Great advice guys thank you so much! I know an old Tacoma isn’t the most comfortable daily in the world but it’s just so dang cool you get it
  6. Jul 27, 2022 at 2:28 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    This…lower the PSI and it will make for a less bumpy ride. You may lose some mpg’s but it’s not like gas is that expensive nowadays. Pick your poison.
  7. Jul 27, 2022 at 3:07 PM
    pahaf
    paul
    NorCal
    Lol had a co worker install $4000 suspension on his tundra and he was still complaining how rough it was. Asked him what psi he is running….50psi.
    “Isn’t the new suspension supposed to make it more smooth?”
  8. Jul 28, 2022 at 5:00 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I feel ya, rough Milwaukee roads have been killing me too.
    Can anyone confirm if Monroe quick struts are smoother in ride compared to Bilstein 4600s? I have quick struts up front that the previous owner put on.
  9. Jul 28, 2022 at 9:38 PM
    Benk98
    Benk98 [OP] Member
    Ben
    Massachusetts
    2004 Reg cab 2.7
    Everything.
    So I found a set of affordable TRQ shocks already installed in the strut assembly with coil overs. Which that i know I can install myself, the bilstein 4600s seem to come as only the shocks, not pre-assembled. I got a very similar set for my 05 Tundra and they provide a very smooth ride, but they are very different trucks… has anyone tried TRQ?
  10. Jul 29, 2022 at 9:10 AM
    Bivouac
    It is really hard to compare how vehicles ride my smooth ride could be beyond rough to the next person.
    I have the Monroe assembled Coilovers I think the ride is all right for a empty 1/2 ton pick up.
    I have yet to drive a Tacoma with a suspension using struts so I can not say how they might ride.
    ztwatson[QUOTED] likes this.
