Softer Shocks & Coils for Lifted Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gordon224, Mar 2, 2020.
  1. Mar 2, 2020 at 8:42 AM
    gordon224
    gordon224 [OP] New Member
    Jay
    2010 Tacoma Prerunner Xtra Cab
    Hi all, I lifted my 2010 Prerunner Xtra cab a few months ago using the Pro Comp K5075B lift (2") and paired it with BFG AT KO2's (white letter out) on stock rims. The truck looks amazing and is exactly the look I was going for. All that being said, the ride is pretty brutal. I feel every wrinkle in the road and get almost no travel out of the front coils/shocks. I've aired down the tires to roughly 30PSI and that helped some, but still not much. I know the E rated tires arent doing me any favors, but the front shocks and coils just seem WAY too stiff/heavy duty for my truck. (The rear AAL actually feels OK).
    I'm at the point where I'm considering swapping out the front coils and shocks and wanted to see if anyone had any suggestions on a much softer setup. I do mainly street driving with some forest road travel once per month. Obviously the Pro Comp was a budget option to begin with, so keep that in mind with your suggestions! Trying not to break the bank on this! Thanks for any insight and assistance!
    Jay
  2. Mar 2, 2020 at 8:51 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Contact @HeadStrong Off-Road. They can probably suggest some new coils to try. I went 5100s with OME 887 coils from them and couldn’t be happier. They’re very knowledgeable, I called and talked to them on the phone before placing my order to make sure it was what I needed.
  3. Mar 2, 2020 at 2:18 PM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    Hi Welcome to TW
    You'll probably get a lot of suggestions for Bilstein 5100 shocks paired with some type of lift coil -- but almost all the lift packages setup for 2nd Gen Tacoma's are for a Double Cab Short Bed (DCSB). My point is that your Pre-Runner has a curb weight 400 lbs lighter than a DSCB so what works for *most* people may not be good for you.
    I went through this same scenario a few times with my regular cab 4x4 and ended up with a pair of Dobinson coils with a light spring rate, paired to some Bilstein 5100's. You could message @Crikeymike (Dobinson's rep on this forum) or you can email Dobinsons USA: david@dobinsonusa.com . David is helpful and responds quickly.
    I'll also reccomend Marie @HeadStrong Off-Road as well because they are straight shooters and good to work with!
    GL!
    Crikeymike likes this.
  4. Mar 2, 2020 at 3:30 PM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    Yeah, I'd bet it's maxed out in the front and you just don't have any down travel and can't compress the front coils with the lighter vehicle
  5. Mar 2, 2020 at 3:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    You should just use a spindle lift.
    Reinstall your OE coils and some decent shocks, like 5100s on 0 setting
    Marie @HeadStrong Off-Road can help you get the right bits.
    08BajaBoy likes this.
  6. Mar 2, 2020 at 5:07 PM
    gordon224
    Jay
    Thanks for all the feedback. Unfortunately my OE shocks were toast so they had to be thrown out.
    CrikeyMike you hit the nail on the head that there’s no down travel. Any suggestions on what coils would be a better option? I went on the Dobinson website and there are several different coil options. Would you recommend new shocks as well?
    Thanks again for all the help!
  7. Mar 2, 2020 at 5:10 PM
    gordon224
    Jay
    ‘14RC - what tires are you running? Any heavy bumper/winch up front? Thanks!
  8. Mar 2, 2020 at 6:58 PM
    '14RC
    '14RC WA State
    Seattle
    Just some 32" Cooper's and no armor.
