Softer Suspension???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jpowers24, Apr 25, 2019.
  1. Apr 25, 2019 at 2:49 PM
    #81
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Definitely agree.
    Would verify the U bolts are fully threaded through those nuts - since now the distance has increased. Want at least a few threads showing
    Area51Runner likes this.
  2. Apr 25, 2019 at 2:55 PM
    #82
    Jpowers24
    Jpowers24 [OP] Well-Known Member
    Jake
    1999 Toyota Tacoma 2.4L
    Okay. I will keep an eye on that when I start the process. Thank you for that note.
  3. Apr 25, 2019 at 2:56 PM
    #83
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Thanks man :thumbsup:
  4. Apr 25, 2019 at 2:57 PM
    #84
    Jpowers24
    Jake
    Im sorry but I am lost as far as what I need to do about the shackles?????
  5. Apr 25, 2019 at 2:57 PM
    #85
    RedManRocket
    Red
    2002 Double Cab LT
    Nothing, theyre good
  6. Apr 25, 2019 at 2:59 PM
    #86
    Jpowers24
    Jake
    Okay, great! Thank you. Also thank you everyone for all your help. This was amazing to learn. Cannot wait to start the process!
  7. Apr 25, 2019 at 3:03 PM
    #87
    RedManRocket
    Red
    2002 Double Cab LT
    Glad that you're eager, just let us know if you need anything else
  8. Apr 25, 2019 at 3:03 PM
    #88
    Jpowers24
    Jake
    Thank you will do for sure!!!!
    RedManRocket[QUOTED] likes this.
  9. Apr 25, 2019 at 3:50 PM
    #89
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Welcome to TacomaWorld. Surrender your wallet.
    :spending:
    RedManRocket and Area51Runner like this.
  10. Apr 25, 2019 at 5:19 PM
    #90
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    Okay, time to chime in....
    Body lifts will NOT make the suspension harsh or softer.. It's all in your suspension. It does contribute to moving the COG ( center of gravity ) higher; and if you combine that with worn bushings, springs, and struts - it does magnify the feeling of your suspension...
    just start replacing what looks rotted and old with new and it'll be come better....
  11. Apr 25, 2019 at 5:49 PM
    #91
    RedManRocket
    Red
    2002 Double Cab LT
    You're right the suspension won't be harsh because of it, but it makes the body stiff which in turn makes everything else in the cab stiff, giving that same feeling the op is trying to get rid of
  12. Apr 25, 2019 at 5:57 PM
    #92
    RedManRocket
    Red
    2002 Double Cab LT
    Our trucks cabs are bushing mounted and when you remove those it definitely makes everything inside the cab feel stiff because there's no bushing to absorb anything.
  13. Apr 26, 2019 at 6:41 AM
    #93
    Thebubble
    Southern California
    2006 GX470
    Arn't all tacomas bushing mounted????
    On my old second gen, I replaced the stock rubber bushing with ES Polys and did NOT feel any differences except for a piece of mind.....
  14. Apr 26, 2019 at 6:41 AM
    #94
    Thebubble
    Southern California
    2006 GX470
    AND that's including a 1" body lift on top of them....
  15. Apr 26, 2019 at 7:50 AM
    #95
    RedManRocket
    Red
    2002 Double Cab LT
    Well to each their own, it is proven many times it increases the stiffness of the cab, across all vehicles
  16. Apr 28, 2019 at 8:04 PM
    #96
    Jpowers24
    Jake
    Hello again. Quick question, but when buying a coil for my suspension, and then also buying Bilstein shocks, I know I am going to need a tool to put them together. So is there any new coil and shocks set that is already put together that you guys can recommend me?
  17. Apr 29, 2019 at 4:16 AM
    #97
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Your truck does not use a shock and coil combo (called a strut or coilover)
    Your truck uses a shock that is mounted inside of where the coil sits, the two are completely separate and must be installed separately. The only thing that keeps the coil in there is the fact that it's sitting in the upper and lower bucket.
    zztaco likes this.
  18. Apr 29, 2019 at 5:41 AM
    #98
    zztaco
    zztaco Member
    FL
    1st gen 5 lug
    That fabtech coil and UCA is part of a 6” kit they discontinued. That coil and UCA give 3” lift, but a spindle gives the other 3”.
    From what I have read, the UCAs were prone to bending, so they do not make them anymore. However, they still sell just the spindle. (~$300-400)
    I’m betting the coil is not sitting right because you don’t have the ‘right’ spindle. It mounts the lower ball joint in a different way than the stock spindle.
    Taking apart the suspension to get to the coil spring, cake. Getting the spring back in is a bitch and a half.
    I would suggest getting this spindle and dropping the body lift. That way won’t need new tires just yet... and you won’t have to mess with the spring either haha
  19. Apr 29, 2019 at 5:52 AM
    #99
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    How has nobody paged @Sperrunner in here yet? He probably knows these 5 lug suspensions better than most on here. But that spring is whacked no doubt.
    Sperrunner likes this.
  20. Apr 29, 2019 at 6:37 AM
    #100
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    If you remove the body lift the largest tire you can have us 28”
    There is a fee lift options but not much. No way to soften the rear other then some better shocks. Up front you can soften a v6 5lug by swapping 4cyl coils in. Ut you will lower the truck a little.
