Softer Suspension???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jpowers24, Apr 25, 2019.
  1. Apr 29, 2019 at 6:52 AM
    #101
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Oh you already have a fabtech 3” lift.but looks like stock length shocks. Of you remove the body lift you will still have 3” of lift and can probably run 30s no issue really.
  2. Apr 29, 2019 at 6:53 AM
    #102
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Also dibs on the fabtech stuff if you take it off
  3. Apr 29, 2019 at 7:27 AM
    #103
    zztaco
    zztaco Member
    FL
    1st gen 5 lug
    I’d be interested in fabtech stuff too if u take it off :anonymous: like I said they don’t make em anymore haha
  4. Apr 29, 2019 at 9:28 AM
    #104
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    The coils aren't too bad to get off. Just put a jack under the lower arm to support the spring load and then when you unbolt the spindle you release the jack slowly and the spring comes out pretty easy. ChrisFix has a video on it.
  5. Apr 29, 2019 at 10:14 AM
    #105
    Jpowers24
    Jpowers24 [OP] Well-Known Member
    Jake
    1999 Toyota Tacoma 2.4L
    Thank you all for the info. I am gonna keep the fabtech on their. I just wanna replace what is needed to soften the front. So from what I understand, I need to buy two struts in replacement of the ones I have in their? Or...someone suggested I get them serviced..???? Still kinda lost sorry
  6. Apr 29, 2019 at 10:27 AM
    #106
    RedManRocket
    Red
    2002 Double Cab LT
    Not struts, a new shock, and a new coil spring.
  7. Apr 29, 2019 at 10:34 AM
    #107
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Lol nah i wish. Trust me its alot more work then that in a 5lug
  8. Apr 29, 2019 at 10:35 AM
    #108
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Get new shocks all around
  9. Apr 29, 2019 at 10:36 AM
    #109
    RedManRocket
    Red
    2002 Double Cab LT
    Damn lol
  10. Apr 29, 2019 at 10:36 AM
    #110
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Fabtech doesnt make those lift coils any more. Replacing coils means go back to stock height or buying a doestech lift kit
    zztaco likes this.
  11. Apr 29, 2019 at 10:43 AM
    #111
    RedManRocket
    Red
    2002 Double Cab LT
    Right, I think that's what he's going for will be somewhat stock height
  12. Apr 29, 2019 at 1:24 PM
    #112
    Jpowers24
    Jake
    Okay. So I will buy new shocks and coil springs for my front end. Any ideas where you guys suggest I can buy them where they are already put together? Maybe more popular brands???
  13. Apr 29, 2019 at 1:32 PM
    #113
    RedManRocket
    Red
    2002 Double Cab LT
    They won't already be put together, that's a strut. The shock will go in and then the coil spring, they don't bolt together like a strut
  14. Apr 29, 2019 at 1:33 PM
    #114
    Jpowers24
    Jake
    Okay. Just realized that's what was said.....duh. Sorry about that. I am going to need a special tool in order to fit the shock in the coil, correct?
  15. Apr 29, 2019 at 1:59 PM
    #115
    RedManRocket
    Red
    2002 Double Cab LT
    No, you'll just do one at a time, shock then coil I believe
  16. Apr 29, 2019 at 3:02 PM
    #116
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Shocks come out with 3 bolts and can be replaced without jacking the car up. Coils require alot of work to change
    zztaco likes this.
  17. Apr 29, 2019 at 4:40 PM
    #117
    Jpowers24
    Jake
    Awesome. Thank you all. Any brands you guys suggest? Or websites I could visit to get a package if possible?
  18. Apr 29, 2019 at 6:35 PM
    #118
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    as others have now mentioned, definitely AAL that adds height and stiffness
  19. Apr 30, 2019 at 11:49 AM
    #119
    greenEFSI
    greenEFSI TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
    I work at Fabtech and figured I'd chime in. The body lift definitely needs to come off to see if that is at least part of the drive-ability issues that the op wants to address. The shocks on there now look to be KYB's which could very well be one of the problems since we don't know the extended and collapsed dimensions of those shocks. The older style coil spring and uca lifts rode rougher than stock by nature due to the stiffer spring rate. We have since redesigned a kit that includes a 3" lift spindle that uses factory coil springs, factory upper control arms, and our shocks. This new kit brings the ride quality back to factory since the coil spring rate isn't as stiff as our old replacement springs.
    If the op wants replacement shocks for the kit that is on there now the part number is FTS7078
    ThunderOne likes this.
  20. May 2, 2019 at 7:38 AM
    #120
    Jpowers24
    Jake
    Thank you for this info. I looked up that part number and it brings up the website 4wheelparts.com. I found what they call Fabtech Performance Twin Tube Shock Absorber. Is this correct? Is this all I need in addition to removing the body lift, in order to make the ride quality back to a stock feeling?
    https://www.4wheelparts.com/p/fabtech-performance-twin-tube-shock-absorber-fts7078/_/R-BKBN-FTS7078
