Softer Suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by always-entropy, Feb 9, 2023.
  1. Feb 10, 2023 at 8:38 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    K I N G S ! ! !
    Superdave1.0 likes this.
  2. Feb 10, 2023 at 12:31 PM
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    My old Toytec lift was harsh with 700lb springs and an AAL. New leaf pack and went to Fox DSC and I am stoked on the ride on and off road. Soaks up the bumps like crazy. The adjusters are legit once you figure out the right settings. Cost a lot of money to figure it out though. Buy once cry once seems to be the motto. Ha
    jackn7 likes this.
  3. Feb 10, 2023 at 6:16 PM
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
  4. Feb 10, 2023 at 6:44 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Don’t know if anyone said this. Icon, bilstein and some other shocks are digressive…so they are pretty stiff untill you hit a big bump, and that’s when they comply.
    fox, kings and some others are progressive. So they are soft and get firmer as the shock compresses.
    mind you, it also matters what spring rate and how much preload you have. I had bilstein 6112 with 650lbs springs on the highest setting. Truck was pretty stiff for me.
    I installed 600lbs springs on the 2/3 setting and it got better. More softer.
    I’m waiting untill my bilstein fail, and I want to try fox shocks. I hope they will ride softer on the road….they pretty expensive
  5. Feb 11, 2023 at 5:05 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    If you are on E rated tires (KO2s or similar) that will contribute to your stiff ride as well. What tires are you rolling on and at what pressure?
    @rnish asked earlier and OP never responded so I'm asking again.
    908tacoma likes this.
  6. Feb 11, 2023 at 7:15 PM
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    Some things might be overlooked here: please post a part number found on your Icon springs, how much thread is showing on your coil over, measured in inches, what tire rating are you running, and what your tire pressure is. After I get that info I can help you out here.
    You should be on a 600lb spring, however Icon notoriously uses a 13” spring whereas King and Fox use a 14” 600lb spring. King valving with the external reservoirs rides excellent on a stock 3rd gen at about 2.75” of lift. If you are on C loads with no extra weight try 35 psi, E loads 32 psi.
  7. Feb 11, 2023 at 7:37 PM
    bullpen58
    bullpen58 Well-Known Member
    Peoria, AZ
    2021 Tacoma PRO 4x4
    Lift, wheels, tires, sliders, and skidplates...so far.
    I'd recommend upgrading the shocks to something revalved by Accutune. They know their stuff.
