Softopper Flaw for Waterproofing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBrute, Jan 20, 2017.
  1. Jan 20, 2017 at 10:39 AM
    TacoBrute
    TacoBrute [OP] Member
    2016 Inferno Tacoma TRD Sport 4x4
    -TRD Pro Wheels w/Terra Grappler G2s -BAMF Sliders
    IMG_2802.jpg IMG_2806.jpg IMG_2807.jpg Hey all,
    I just installed my Softopper last night on my Tacoma. It's awesome. However, there seems to be a waterproofing flaw that I've noticed with respect to the nylon straps that are used to hold the sides up. They are sewn into the canopy material itself. The little exposed nylon there is soaks up water and then transfers to the inside of the compartment.
    Has anyone else noticed this? If so, what did you do about it? I was thinking of applying a waterproofing sealant to the exposed nylon? Thoughts?
  2. Jan 20, 2017 at 11:58 AM
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    Wonder if you can spray the entire cover with the Water proofing stuff people use on camping tents... I will be purchasing a soft topper in a couple months I hope.
  3. Jan 20, 2017 at 12:03 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Does it not say it needs to be waterproofed and/or sealed at the seams to be water resistant?
    That's a seam.
    Seal it.
    gunn_runner and ramonortiz55 like this.
  4. Jan 20, 2017 at 12:05 PM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    Mine came with seam sealant and I applied it the first day. Did yours not? If so, just use that. Mine stays dry.
  5. Jan 20, 2017 at 12:05 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    I never used the seam waterproofing and mine only leaks at the front corners where the front flap doesn't fully seal against the bed.
  6. Jan 20, 2017 at 12:54 PM
    TacoBrute
    I'll apply the seam sealant. As stated though, it's the straps themselves that are soaked. I can't see any visible leakage around the seams. So I'll waterproof the outer portion of the straps and see if that resolves the issue. Have to wait till it drys up.
    San Diego hasn't gotten rain like this in years...
  7. Jan 20, 2017 at 1:17 PM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    The sealer that came with your soft top, is it a spray on sealer? I was thinking about getting a soft top for my bed rack. Might have the local canvas guys make one for me.
  8. Jan 20, 2017 at 9:34 PM
    TacoBrute
    It is not a spray on. It has a brush applicator, but I plan on putting it in a small cup and using a paint brush to be more precise with it.
  9. Jan 26, 2017 at 2:51 PM
    Citizen Rob
    Sacramento, CA
    If you are really feeling ambitious, you could always wax the seams. A little linseed oil and some beeswax. Heat them both until they are melted together, swirl the mixture with a paint stick and then brush it on.
