Softopper vs Bestop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NJMevec, Dec 6, 2020.
Softopper or Bestop
  1. Softopper
    87.9%
  2. Bestop
    12.1%
  1. Apr 23, 2021 at 2:35 PM
    #281
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    You're probably not going to get anything much bigger than a luggage lock to fit through one of those zipper pulls, and there's pretty much no chance of getting something remotely weather-resitant in that size. Not to mention that someone with a key-chain sized multi-tool or decently strong metal pen could pop them in under a second without looking suspicious to anyone not watching closely.
    That said, it'd be pretty easy to just run a loop of something like 1/8" steel rope under the mounting rails in a few spots to create a point to lock them to.
    With or without any locks, the real security is just due to whatever might be in the bed not being in clear view.
  2. Apr 23, 2021 at 3:20 PM
    #282
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I can check where they fall by comparing dimples to your picture.
    tonered[QUOTED] likes this.
  3. Apr 23, 2021 at 3:21 PM
    #283
    RushT
    North Texas
    Rago Fabrication front bed tie downs. I don’t think they make them any more?
  4. Apr 23, 2021 at 3:28 PM
    #284
    RushT
    North Texas
  5. Apr 23, 2021 at 9:13 PM
    #285
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is what I was thinking. I just couldn't see them in your pic. The front flap goes down further on the SBs.
  6. Apr 24, 2021 at 8:09 AM
    #286
    RushT
    North Texas
    Looks like they might overlap by 1/2”-1”. Nothing an extra snap couldn’t solve.
  7. Apr 24, 2021 at 8:24 AM
    #287
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice!
    :cheers:
  8. Aug 16, 2021 at 5:03 PM
    #288
    Vjtrey1
    Vjtrey1 Well-Known Member
    Richmond, Tx
    2018 Super White Tacoma TRD OR DCSB
    Simple mods
    Is this gray or black color?
  9. Sep 9, 2021 at 9:36 AM
    #289
    TacoTruckCO
    TacoTruckCO Well-Known Member
    Joel
    Portland, OR
    Voodoo Blue 20 OR DCLB
    Read the whole thread! Lots of great ideas in here. Can someone explain which 303 product is the best to use for the ST? I went looking and found there are about 7.2million variations haha
  10. Sep 9, 2021 at 9:41 AM
    #290
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just the basic Protectant:
    https://www.amazon.com/gp/product/B00L4TF32G
    I bought the gallon size when it was a lot less expensive (like $45?). It was certainly the best value because it also preserves any of the bare black trim also. The stuff on the rear bumper was starting to fade on mine. Great for the black roof trim also.
    doublethebass and dilbert like this.
  11. Sep 9, 2021 at 10:20 AM
    #291
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I use that same type of 303 on everything that is unpainted plastic/vinyl on the truck, including the interior. I have over half of the gallon left I bought back in 2017 ($35).
  12. Sep 9, 2021 at 10:22 AM
    #292
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not a good price trend. Might need to horde invest in some for the coming apocalypses? Better than TP?
  13. Oct 13, 2021 at 10:05 AM
    #293
    Yán92
    Yán92 Member
    Ian
    2011 White Regular Cab Tacoma 4WD
    Softopper, Aftermarket Headlights, Taillights, and Grill.
    I am looking to buy one of these soft toppers for a camping setup! Can anyone who owns one answer a few questions I have? 1) on either the Softtopper or the Supertop, can you close and zip up the back window and talegate from the inside. I have been searching all day scouring videos and photos and can’t seem to figure out if the zippers are double sided. 2) on te Supertop, can you open the back window without opening the talegate first? The videos I have seen make it look like the metal bar is tucked in such a way that you would need to open the talegate before you could open the back window.
    I have been leaning toward getting the Supertop for my camping setup, but depending on the answers to these questions, I may have to pull the trigger on Softtopper. Thanks!
  14. Oct 13, 2021 at 10:25 AM
    #294
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I can speak to the bestop as thats what I have.
    Zippers. They are single sided, so while you can zip them from the inside, there is no zipper pull so you have to try to grab the zipper block thingy.
    Rear panel. You can remove it without opening the tailgate. That bar you see holds the bottom of the panel, but it does not need to move to take off the rear panel.
  15. Oct 13, 2021 at 10:26 AM
    #295
    bmgreene
    Brian
    L.A. Westside
    The Supertop I have doesn't have dual-sided zippers, but they may have updated the design in the 8+ years I've had it.
    The back window can be worked loose with the gate up, but I've never tried to do it from inside the bed.
    I don't have any experience with the softtopper, but would imagine that sleeping under one would be a problem if you're claustrophobic at all since there's no light coming through the sides.
    That said, for what I do, if I could go back I'd probably buy the softtopper instead of the supertop, but I'm not looking to do a lot of sleeping in the back of the truck. I'm happy with my supertop, but the way the sides roll up on the softtopper would be easier when folding down the top than having to remove and stow the side windows of the supertop.
  16. Oct 13, 2021 at 11:01 AM
    #296
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The softopper has double pulls on their zippers. You can close and open it from the inside.
    Alternatively, either topper can take one of those "topper tents," which would be infinitely easier for those late night fumbling pee runs.
    tonered likes this.
  17. Oct 13, 2021 at 11:35 AM
    #297
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Crediting @dilbert for this handy strap:
    Getting in and out of the Softopper has been great for me.
    A bit of lighting really sets the mood (more credit to @dilbert for the shrink wrap idea):
    Rock Lobster, bmgreene and dilbert like this.
  18. Oct 13, 2021 at 4:26 PM
    #298
    Yán92
    Yán92 Member
    Ian
    Thanks for all the help! I pulled the trigger on the softopper… mostly because of the zipper thing and the ability to use a mesh screen making ventilation a lot easier than the Bestop. Although I would have like side windows. Oh well.
    tonered and bmgreene like this.
  19. Oct 13, 2021 at 4:42 PM
    #299
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    A thought occurs to me: I once took a rectangular mosquito net and draped it over my bed rack to make a impromptu tent.
    I bet if someone were to put a similar net between canvas and frame, you could roll up the sides and get all the windows/ventilation you wanted.
    Yán92[QUOTED] likes this.
  20. Oct 13, 2021 at 4:47 PM
    #300
    retrofive
    retrofive Well-Known Member
    I used a DAC on my LC for years. Great little truck condom. Never thought to use it with softopper.
