Softtop Question (dropin bedliner)
Discussion in '1st Gen. Tacomas (1995-2004)' started by camelot142, May 29, 2019.
  1. May 29, 2019 at 1:54 PM
    camelot142
    camelot142 [OP] Well-Known Member
    Brandon
    Southern California
    2002 Black Tacoma TRD
    Total Chaos Upper Arms, Kings Shocks
    Looking to purchase soft top. Wondering if I can install it with out 1st gen drop in liners. If so, what brands?
    Thanks in advance
  2. May 29, 2019 at 2:50 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    It might be a better question for the people over at softopper but I suspect thats not gonna be a problem even with an above the rail liner (I disposed of my oem liner long ago).
    The only hang up could be because the softopper rails need to be clamped to the bed. I doubt the liner would specifically cause any issues. Even my softopper rails don't sit completely flat against the bed rail and my softopper works perfectly.
  3. May 29, 2019 at 2:52 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Are you talking about a Softopper or a soft tonneau cover? My Softopper installed perfectly fine without a drop in bed liner.
    Softopper mounts to your bedrail with clamps like a hardshell, never installed a soft tonneau cover, but I can’t imagine it requiring a drop in bedliner. You should be fine either way
    camelot142[OP] likes this.
  4. May 29, 2019 at 2:55 PM
    camelot142
    Brandon
    Southern California
    I'm talking about a softtopper camper shell type. my drop in goes over the bed rails so I guess ill have to cut hole to clamp to the rail. pics would be nice when you get the chance. (on how you cut the holes) thanks
  5. May 29, 2019 at 2:59 PM
    OneWheelPeel
    Phoenix, AZ
    You would have to do that with any topper....
  6. May 29, 2019 at 3:03 PM
    camelot142
    Brandon
    Southern California
    really? who would have thought...
  7. May 29, 2019 at 3:31 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    I don’t have a bed liner so no holes to cut for me, the clamp snaps on the top of the Softopper rails then hooks underneath the bed rail. It’ll make sense when you’re looking at the clamps. I took my Softopper off so none of my pics would help anyway.
    Just mark and cut a slot for each clamp, pretty straightforward
    :cheers:
  8. May 30, 2019 at 9:44 AM
    OneWheelPeel
    Phoenix, AZ
    I'm not the one asking obvious questions
