Software upgrade problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HoboDave, May 25, 2018.
  1. May 25, 2018 at 8:58 AM
    HoboDave
    HoboDave [OP] Homeless Prius Dweller
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    For the past few days every time I drive the taco I get a "mandatory software upgrade available" but when I try to download it just sits there for awhile and says "Download Unsuccessful" Then it just keeps popping up and is annoying. I thought maybe it was a busy server problem so I waited until late at night to try again. Still no luck. Anyone else have this problem or know a solution? It's the premium JBL system.
  2. May 25, 2018 at 9:19 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Took three tries to do mine.
  3. May 25, 2018 at 9:22 AM
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    Mine did the same. I finally figured out that the process started in front of my house while my phone was connected to wifi. I started to drive away and the phone switched to cellular which caused the update to time out. I fixed it by turning off wifi to my phone before I started the truck which forced the download to happen through the cellular connection. Once I did this everything worked.
    HoboDave[OP] likes this.
  4. May 25, 2018 at 9:27 AM
    HoboDave
    David
    2023 Toyota Prius
    Tried this and it worked. All good now. Thank you!
  5. May 25, 2018 at 10:03 AM
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    Got this message this morning and it worked first time. Maybe a connection issue to the webs for you...
  6. May 25, 2018 at 10:43 AM
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    I did the update yesterday and started it at the office on wifi then took off and it switched to cellular just fine even with driving trough a couple of dead spots.
  7. May 25, 2018 at 10:58 AM
    petr321
    petr321 Well-Known Member
    Petr
    San Diego
    2018 DCSB OR
    Any idea as to what is new in the update?
  8. May 25, 2018 at 10:59 AM
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    I believe it added some destinations but other than that I don't know.
