Sokietech bolt-on hood struts/lift review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheSt|G, Apr 17, 2020.
  1. May 23, 2022 at 12:09 PM
    #121
    DeepFriedTaco
    DeepFriedTaco Well-Known Member
    Teddy the Taco
    2021 MT OR Taco
    Thanks! Are you happy with the spot for this? I was thinking of running Baja S2 Pro combos in clear.
  2. May 23, 2022 at 12:46 PM
    #122
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
  3. Feb 17, 2024 at 7:27 AM
    #123
    Robskino
    Robskino Well-Known Member
    Robert
    23 MGM sport
    So let me bring this page back to life some and ask the ones who installed these.....still work, any problems, any unusual wear or tear?! Looking to get these since there is no drilling required. Huge plus. But i want to hear some longevity storys first! TIA!!!
  4. Feb 17, 2024 at 7:46 AM
    #124
    AmpLid
    AmpLid New Member
    Installed the sokietech struts a couple weeks ago and already noticed some flex when closing the hood on the lower bolts. I really didn’t like that the drivers side using the grounding location. Sheet metal is fine but I went ahead and just removed them for piece mind. Ordered the redline tuning elites and putting them this weekend instead.
    RedlineTuning likes this.
  5. Feb 17, 2024 at 8:07 AM
    #125
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    Not sure if you’re the same person in the TacomaWorld FB page but as I stated there, I have had these installed since December 2020. I don’t open my hood much but absolutely no issues since installing them. I think if you were opening your hood very frequently the flex might be a concern? But the trade off of a no-drill solution, especially for me not getting under the hood much, is worth it. My biggest issue with the other kits is that they require rivets which would be an absolute nightmare to remove.
    Robskino[QUOTED] likes this.
  6. Feb 17, 2024 at 8:22 AM
    #126
    Robskino
    Robert
    23 MGM sport
    I am not. Facebook is the cesspool a meeting place of the worlds most ignorant and uneducated folk this planet has to offer......nonetheless, i dont open the hood frequently, just want the times that i do, to be as easy and carefree as possible.
    Irons and Davox like this.
  7. Feb 17, 2024 at 8:55 AM
    #127
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Why would you remove them ? I have Redlines and open my hood about every week. No issues just glad I did it.
  8. Feb 17, 2024 at 8:55 AM
    #128
    poopshute
    Colorado
    That’s exactly my use case. This kit is doing the trick for me. I’m always so giddy when I open the hood and realize/remember the hood struts. Definitely makes it much easier to deal with engine work.
  9. Feb 17, 2024 at 8:57 AM
    #129
    poopshute
    Colorado
    It’s more if you have to remove it (for whatever reason) or have an issue. Rivets are a PITA to deal with. That was the primary reason I stayed clear.
  10. Feb 17, 2024 at 9:21 AM
    #130
    SpikerEng
    SpikerEng Well-Known Member
    Leon
    Portland, OR
    They're pretty easy to remove. Grab a 3/16" drill bit, and drill the center of the pop rivet top hat. The hole at the top acts as a guide, and as soon as you drill through the aluminum top hat, it comes right off. Easy peasy.
    Kodiak420 and SmartyMcFly like this.
  11. Feb 17, 2024 at 12:32 PM
    #131
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I've had the solkie tech ones since July 2020 when I got my truck. I've have no issues with them. I only open my hood like once a month to check the oil and washer fluids or when I change the oil or do routine maintenance. I have no reason to open the hood every day or week it's a Toyota after all its not a Ford.
    They sure make the heavy hood easier to handle not that it was a problem as I'm a big boy but I'm not getting younger. Plus it lifts it a bit higher than the prop rod.
    Bronxguy likes this.
  12. Feb 17, 2024 at 12:47 PM
    #132
    Bronxguy
    Bronxguy Well-Known Member
    Frank
    New York
    2021 Off Road
    Had mine installed since 2021, open hood at least monthly to check, no problems and actually forget that they are there.
  13. Feb 17, 2024 at 1:30 PM
    #133
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Zero issues over nearly 4 years of usage on a high mileage Sport
  14. Feb 17, 2024 at 4:35 PM
    #134
    oostroma
    oostroma (Boomer)
    Ontario
    I've had mine installed for a few years now.
    No issues to report.
  15. Feb 20, 2024 at 10:38 AM
    #135
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    Since it’s been a couple years since the install, has there been any issues with these good struts for the few that have used and installed them? I’m looking at getting some.
  16. Feb 20, 2024 at 11:41 AM
    #136
    canuck guy
    Alberta
    23TRDOR
    Huh ?
    Read the posts previous to yours for the answers.
  17. Feb 20, 2024 at 12:08 PM
    #137
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    For some these are not that popular back then. Got mine around $25 and it has been 4 1/2 years now.. No issues :thumbsup:
    baboltin likes this.
  18. Feb 20, 2024 at 2:42 PM
    #138
    wayne0
    wayne0 Well-Known Member
    All the naysayers that don't have them. How can you judge a product you haven't tried? "Oh, they will bend the hood" "The struts will corrode"
    Give me a break.
    I put mine on 2 years ago with zero issues.
    Easy install. No different in operation than ones costing twice the price that require drilling.
    My$.02
    baboltin and oostroma like this.
  19. Feb 20, 2024 at 6:35 PM
    #139
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    Had mine on since 2021 with no issues. Open the hood a minimum of twice a month to change the batteries in my rodent repellents.
  20. Feb 20, 2024 at 9:55 PM
    #140
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    All good here. No ragerts
