SOL or Buy a buffer
Discussion in 'Detailing' started by double dee, May 22, 2011.
  1. May 22, 2011 at 11:25 AM
    double dee
    double dee [OP] Well-Known Member
    Arizona
    So did a little off roading yesterday and have a lot of scratches from trees and brush. Most of them are on the clear coat but I can't seem to get them off. I've tried using Meguiars Scratch X 2.0, Polish, Wax and one of those little buffers you put on a drill. It helped but there still there. If I get a actual Buffer/Polisher will that work a lot better or am I just SOL? Hope not since my truck is only 3 months old!:eek:
  2. May 22, 2011 at 11:37 AM
    DCW
    DCW Well-Known Member
    David
    Reno, Nevada
    2011 TRD DC Off Road
    TRD exhaust, front skidplate,5100s@1.75
    You should use a high speed buffer but you need to be careful and not burn the paint. Check the detailing threads they will give you some more info on how to take the scratches out and what products to use. The orbiter buffer can't provide you with enough speed to polish out the scratches.
  3. May 22, 2011 at 11:39 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Post up a pic or two of said scratches.
  4. May 22, 2011 at 11:59 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Are you going wheeling again?
    Scratch removal removes paint. If you do it too often, you'll go through your paint.
    Personally, I polish out my superficial scratches, and leave the deeper ones.
  5. May 22, 2011 at 12:02 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    this! be careful!
  6. May 23, 2011 at 5:52 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Agreed. I received quite a few pinstripes on my truck and have seen the same on many others. I usually tell people 'I can make this look 80% better'.
    Shoot for that...otherwise, you take too much paint off. For most people, its not the last time they'll scratch it up and it will need to be polished again.
  7. May 25, 2011 at 6:58 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Keep in mind, Toyota's don't have much clear on them. As a rule of thumb, you can run your finger nail over the scratch. If your nail grabs the scratch, it's likely too deep to polish out. If your nail just goes over the scratch, you can probably polish it out.
  8. May 26, 2011 at 4:18 PM
    Gooch
    Orange County CA
    No vehicles have much clear on them anymore!
    Good advice on the fingernail trick.
  9. May 26, 2011 at 4:32 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    I personally would not recommend using a rotary buffer because it takes just seconds to burn paint. I have seen it personally and our trucks do not have alot of clear coat to begin with. Find a good random orbital and use that. It will take longer, but its cheaper than a trip to the paint shop.
