Solar Battery Tenders
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wulf, Jan 10, 2016.
  1. Jan 10, 2016 at 3:22 PM
    Wulf
    Wulf [OP] no brain just damage
    rock raisin
    My truck is going to be parked for the next few months and I'd like to throw a solar battery tender on it to keep the battery fresh(ish), especially considering the freezing temps.
    Can anyone recommend one? I searched and it didn't turn up too much
    edit: I can't use a traditional battery tender because I have to park on the street
  2. Jan 10, 2016 at 6:08 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    keeping it on a charger is really not needed for just a couple months but just take the battery out and put it in the shed or workshop on a charger. if you don't have a place like that then just have someone go start the engine once every other week and let the engine warm up, that will keep it charged and you don't need to do anything to it.
    pretty sure if you leave a solar charger on it parked out by the street, somebody is gonna grab it and run off with it
  3. Jan 11, 2016 at 8:30 AM
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
    I have this http://www.amazon.com/ALLPOWERS-Por...=UTF8&qid=1452529642&sr=8-3&keywords=5w+solar
    which runs off the cig socket, so its not going to charge if your socket isnt on when the key is off.
    I dont use it as a battery tender, but its such small current that it would probably do fine. I would keep a close eye on the voltage these things are like 20V at 0.2 amps. Also, grab on of those ammeters and check current flow while car is sitting out of the terminal just so you know the draining current.
  4. Jan 11, 2016 at 10:02 AM
    Wulf
    rock raisin
    Unfortunately I don't have either. I guess I could pull the battery and leave it on the back patio or something. After a month of sitting the battery is already too weak to start the truck, so I probably also have some kind of electrical drain I'll need to sort out later.
    I'll look into this a bit more, thanks. my cig socket isn't on with the key.
  5. Jan 11, 2016 at 10:05 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Dmonkey, Wulf[OP] and jaunty like this.
  6. Jan 11, 2016 at 2:26 PM
    keakar
    karl
    louisiana
    yep, if its dead after sitting a month then you have something draining power or the battery itself is bad.
    to test this you can pull the battery terminal off and see if it stays charged that way, or just bring the battery in to be load tested, that should tell you if its bad but if its a bad cell, sometimes they can still test good.
  7. Jan 11, 2016 at 3:16 PM
    Wulf
    rock raisin
    Hopefully it's not dead, it's less than 2 years old.
