Solar panel battery charger.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by base1375, Nov 14, 2012.
  1. Nov 14, 2012 at 8:19 AM
    base1375
    base1375 [OP] Member
    Does anyone use these things or does anyone have any recommendation. Going to be living out of the back of my truck for a month on a road trip and would like to have something like this incase i run the battery dead overnight using my laptop or phone or other things.
  2. Nov 14, 2012 at 9:12 AM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    Interested also, bump
  3. Nov 14, 2012 at 9:21 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I made a small one that put out 12V 500mW. I was using it for my UTV. Just 4 12V cells and a schottky diode. Easy and cheap to make, but I have also built solar powered cars...
    If there is an 12V outlet that is always on, you can get the type that plugs into the cig lighter.
  4. Nov 14, 2012 at 9:27 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I guess he means if he runs the battery over night and the n charge it the rolling morning :notsure:
    Subd interested of what you guys use
  5. Nov 14, 2012 at 9:33 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Truck batterys are not really designed for that kind of use/drain. You might damage your battery but putting it under that kind of stress. What you need is a deep cell/cycle battery that is designed for that kind of use(constant draining and recharging).
  6. Nov 14, 2012 at 9:36 AM
    bullaculla
    Da big big island!
    Even if you had a deep cycle/marine battery, If you drained it completely, you'd need a pretty big panel to recharge it in a timely manner.
  7. Nov 14, 2012 at 9:38 AM
    ssmith29440
    ssmith29440 Well-Known Member
    2012 Tacoma TxPro Trd
    You can purchase a decent jump box for around $60.00. Plug it into your recepticle in the bed during the day to keep a peak charge on it. A lot of these units have a built in air compressor. You could purchase a tire plugging kit and along with the compressor fix flats if they occur while on your trip. Just an idea.,:notsure:
  8. Nov 14, 2012 at 9:39 AM
    Hairy Taco
    North of Hell
    08 TRD
    yes, this too. A small portable solar panel is not likely to create a lot of charge power.
  9. Nov 14, 2012 at 9:42 AM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Saw a foldable solar panel just for this purpose... Was either in offroad or 4wd magazine. Can't seem to find it online right now though. Maybe when I'm back at my apartment I'll see if i still have it
  10. Nov 14, 2012 at 9:52 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    what are you going to be running off it? 12v accessories? cooler? inverter?
    What kind of battery do you currently have?
    I have a sears platinum marine 31M AGM - its a re-branded odyssey battery and holds 100 amp/hr of charge
    This gets me easily 48 hours parked with ARB 50 qt cooler running an other small accessories.
    Before looking at solar - I would look into a National Luna power Pack:
    http://www.nationalluna.com/PPPack.htm
    This can hold another 31m for you giving you a total of 150 amp/hr of use (assuming you are keeping you main battery at no less than 50%). This is a neat kit, has dual battery charge controller built in - portable also.
    The alternative would be to not get the NLPP and get a panel. After you get a good battery the rule of thumb is get a panel rated at ~ the same wattage as your batteries amp/hr capacity. So for my with a 31m @ 100amp/hr I should get a 75-120 watt panel - hard panels are cheaper. You can get good 100watts for $200-300. A foldable 60watt panel will run you $600-$700 alone. (http://www.amazon.com/PowerFilm-F15-3600-Foldable-Solar-Charger/dp/B001QKWTJ8)
    Then you need to get a nice charge controller so you don't fry your battery ($50 for cheapo and $200+ for nice ones that follow charge specs for AGM batteries) To do it right I would budget $600-$1000 for a panel, wiring and charge controller.
    This is why the NLPP is a nice option $550 for the power pack and then another $250 for a battery and you can drop in an additional 100 amp/hr that will charge when you car is running.
    dziner likes this.
  11. Nov 14, 2012 at 9:56 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    curious..what is gonna put you in the wilderness for a month? work? play?
    i would invest in a great generator. a honda EU1000 or 2000.
  12. Nov 14, 2012 at 10:01 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    :popcorn:
    I'm looking into a 250 watt, 12 volt unit. about 3'x5'. Pricey units, but it's hopefully coming to me no charge after being used on one of my projects for 6 months.
    was going to get two, for a total of 500 watts, but another member on the design team has expressed interest in the second one.
    I'm going to dual wire mine, with a switch on each circut. one hookup will be straight power to the batter. The second circut will run through a trickle charger, to just maintain. both will be on indevidual switches, so i can pick one or cut power from the panel all together.
  13. Nov 14, 2012 at 10:03 AM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
  14. Nov 14, 2012 at 10:04 AM
    Wicked 2007
    Bay Area, CA
    This too, Yes - I love my EU2000i. under 50lbs and quiet. but also $1000 bucks
    wow - that's a lot of power for a truck battery don't you think? A good charge controller will charge and maintain for you automatically.
    you can get tiny 100w for under $300:
    Pmax = 100 watts @ maximum power​
    Vmpp = 17.7 volts @ maximum power point​
    Impp = 5.7 amps @ maximum power point ​
    Voc = 21.2 volts @ open circuit​
    Isc = 6.10 amps @ short circuit​
    Length = 40.8" (1037mm) 3.4'
    Width = 20.7" (527mm) 1.7'
    Depth = 1.38" (35mm)​
    Weight = 14.5 lbs. (6.6kg)​
  15. Nov 14, 2012 at 10:16 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's only about 20 amps.
  16. Nov 14, 2012 at 10:28 AM
    Wicked 2007
    Bay Area, CA
    that per hour. It really depends on what your using per day.
    My arb uses less than 25 amp/hr a day.
    if you have 250 watts and get 6 hours of good daylight that 1500 watts or or 125amp/hr
    this is more energy than my battery capacity. I think this is why people use the rule of thumb to match your battery capacity and I dont know what your battery capacity is or your daily usage so maybe 250w is needed :)
    If I run a 100w panel for 6 hours I get 600 watts or 50amp/hr back into my battery which is more than enough for daily juice since the ARB only takes 25 amp/hr per day. with 100w I could run my equipment indefinitely in theory.
  17. Nov 14, 2012 at 10:42 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    It really depends on the scenario at the time. most of the time won't need that kind of power, but the one time i do, it'd be very nice to have.
    with a set of jumpers, you could even run accessories from multiple vehicles off of it at once. I've run full size fridges off a 5000 w inverter hooked to the truck. it would be nice to not have the engie constantly on for that duration, as well as be able to recharge quicker. along with the panel, there would also be a second battery added in.
  18. Nov 14, 2012 at 11:00 AM
    Wicked 2007
    Bay Area, CA
    wow you run some big stuff! :)
  19. Nov 18, 2012 at 8:23 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    I agree with Aficianado, renting a quiet portable gas generator will be a whole lot less expensive and more reliable that trying to buy a solar/deep cell battery/inverter system for your dry ("off grid") camping, especially for one month. 5 watt solar panels and below are designed to maintain a full charged car or power sport (motorcycle) battery at 100% State-of-Charge to prevent sulfation. For more information on solar/deep cell battery/inverter system sizing, please see Sections 7.9 and 7.10 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
  20. Nov 18, 2012 at 3:02 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it also runs the small welder I take wheeling. VERY helpfull to have on the trails.
