Solar Panel deal at SolarBLVD
Discussion in 'Deals & Coupons' started by anonemoose, Feb 22, 2017.
  1. Mar 4, 2017 at 6:57 AM
    anonemoose
    anonemoose [OP] Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    A PMW or MPPT controller takes care of charging issues:
    Absorption mode/Normal operation
    Nominal battery charge and supplies power to appliances
    Bulk mode/Charge mode
    Fast battery charge and supplies power to appliances
    Float mode/Trickle charge
    Trickle battery charge during storage
    Absorption Mode: During this mode, the controller output is in the
    13.6 Vdc range. This is the normal operation mode. This mode provides
    the 12 Vdc and current required by the 12 Vdc RV appliances, as well as
    slow charging the battery.
    Bulk Mode: In this mode, the output voltage of the controller will switch
    to 14.4 Vdc range for a maximum of four hours. If the controller cycles
    between “Absorption and Bulk mode,” there could be a shorted battery
    cell or other issues.
    Float Mode: In this mode, the controller is charging the battery with a
    trickle voltage of 13.2 Vdc range. When the controller senses a demand
    (by turning on lights), the controller automatically returns to the
    “Absorption mode”.
  2. Mar 13, 2017 at 9:41 AM
    quickanddirty
    quickanddirty Well-Known Member
    Stephanie
    Santa Clara, CA
    2010 White ACLB 4x4
    2012-15 face lift, upgrade to OR edition, Pro Comp AAL, Bilstein 5100's, XD rims, N FABS
    Hey guys, just did a quick search... It appears the website/page is up and running again, here's the link: https://www.solarblvd.com/products/solar-cynergy-flexible-bendable-120-watt-12-volt-solar-panel/ I'm looking into one of these, but I don't have any experience with truck electrical systems, only home solar design... Do you need an inverter or do you just wire straight to the battery? I read that people are using a charging controller to avoid over charging and distribute the charge between batteries. I'm looking for a relatively cheap setup, but I'd favor an inexpensive, longer-term solution over something cheaply made.
  3. Mar 14, 2017 at 8:22 AM
    gnardoggie
    gnardoggie Well-Known Member
    How did you mount that on the cross bars?
  4. Mar 14, 2017 at 8:25 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Ghetto style mounted to the snowboard rack! Drilled holes in the aluminum frame and put bolts through.
  5. Mar 14, 2017 at 8:35 AM
    gnardoggie
    Got it - I've got a 100w flex panel and I'm trying to decide if I tape that to my topper or get a rigid panel and mount it to my roof rack. Can't decide which would be a better way to go.
  6. Mar 15, 2017 at 11:38 PM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Go flex and line the entire back with Scotch 414 extreme duty mounting tape. I did a 1" perimeter mounting a flex to the contour of my roof. Other than it lifting the wrap i have on the roof, its holding decently since end of January.
    Dont ever expect to remove it though. Stuff has very high pull strength. Almost folded a Windex bottle in half trying to pull a 1"x1" piece straight off.
    Car solar is very simple. Two wires from the panel go to your charge controller. Power wire from controller to battery with Fuse. Ground wire from controller. That's it for a extremely basic battery hook up. There is an output on most charge controllers to add a light or aux connection (nothing too power-hungry).
    The charge controller is where you'll want to spend the money. I spent almost $100 for that alone. Plus wiring, extra connectors, crimp tool and mounting tape. All in all, about $280ish.
  7. Mar 16, 2017 at 5:15 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I disagree. For the amount of wattage and number of panels a simple PWM controller is all you need on a truck, rv or boat or house sure go with MPTT. If you plan to mount it in the elements get a sealed one like the LS1024epd.
  8. Mar 16, 2017 at 1:26 PM
    gnardoggie
    I'm thinking I might want to remove it someday though.
    What kind of fuse would you recommend between the controller and the battery?
  9. Mar 27, 2017 at 11:41 AM
    toryt
    toryt Active Member
    tory
    Layton Ut
    2014 silver tacoma
    Bilsteins 6112's and rear Dakar leaf springs, BMAF rocker guards, Relentless bed rails
    this deal must be over the panels are gone or off the web site? anyone know if we can still get these?
  10. Mar 27, 2017 at 11:48 AM
    quickanddirty
    Stephanie
    Santa Clara, CA
    2010 White ACLB 4x4
    @toryt
  11. Mar 27, 2017 at 4:41 PM
    SAC-CA-Runner
    SAC-CA-Runner Well-Known Member
    Go to post #22. The link is there. They are $139 now tho and not $119
  12. Apr 4, 2017 at 6:59 AM
    toryt
    toryt Active Member
    tory
    Layton Ut
    2014 silver tacoma
    thanks I picked up 2 panels I hope they work well
  13. Apr 6, 2017 at 3:50 PM
    cwhet10
    cwhet10 IG: badassbrunette
    Cristin
    2015 Barely Stock TRD Sport
