Solar powered fan will this work to charge?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Newtacoma19, Dec 15, 2024.
  1. Dec 15, 2024 at 6:26 PM
    Newtacoma19
    Newtacoma19 [OP] Well-Known Member
    SSM utility 19
    Looking at getting a fan for my truck bed.. preferably not wired to truck. Would this would to simply hook up to a fan and or any recommendations for a solar powered fan? Or recommended chargeable usb fan?
  2. Dec 15, 2024 at 6:53 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  3. Dec 15, 2024 at 6:56 PM
    MGMDesertTaco
    Take beano, they'll be no gas. :cookiemonster:
    RIX TUX likes this.
  4. Dec 15, 2024 at 7:03 PM
    Newtacoma19
    SSM utility 19
    CB350G likes this.
  5. Dec 15, 2024 at 8:43 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    that wont work at night :anonymous:
    get a battery bank, usb powered fan
    can be charged when you drive
  6. Dec 15, 2024 at 8:47 PM
    RIX TUX
  7. Dec 15, 2024 at 9:28 PM
    MGMDesertTaco
    RIX TUX[QUOTED] likes this.
  8. Dec 15, 2024 at 9:57 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
  9. Dec 16, 2024 at 8:42 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    My wife loves this mini fan when we camp. I used it one weekend too. Its personal sized but you can charge it via USB.
    https://www.amazon.com/gp/product/B08YWVJNNV?ie=UTF8&th=1
  10. Dec 16, 2024 at 9:11 AM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
  11. Dec 16, 2024 at 10:00 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    No but I have used them in sailboats a lot. They aren’t designed to do a lot of cooling, mainly just to keep air moving and control moisture/humidity build up. Depending on where you live it may work as long as the side windows are opened to allow a source of fresh air to be pulled up and out.
    AZPhys13[QUOTED] likes this.
  12. Dec 17, 2024 at 8:34 AM
    dirt clod
    dirt clod Active Member
    Greg
    2023 Tacoma
    If the fan is for an enclosed area, you may want to check cfm or cfh. Except for the marine solar mentioned earlier, most solar fans push a dismal amount of air and most don’t state the cfm.
    In an open area, your guess is as good as anyone’s as to the fans air movement capabilities. In an enclosed area, you may want to be looking at how many “air changes per hour”.
    AZPhys13 likes this.
  13. Dec 17, 2024 at 9:32 AM
    AZPhys13
    Luckily the cap already has screened windoors so I'll have a source of fresh air. Hopefully something like this is strong enough to push out a sufficient amount of hot air.
  14. Dec 17, 2024 at 9:42 AM
    AZPhys13
    The marine fan linked above has a state CFM of around 17. Based on my installation of bathroom fans at home, this seems sufficient for the smaller volume in the back of the truck.
