Sold - 05-23 OEM Tacoma Spindles with Gussets
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Captainskidmark, Sep 30, 2023.
Thread Status:
Not open for further replies.
  1. Sep 30, 2023 at 7:40 PM
    Captainskidmark
    Captainskidmark [OP] Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Set of OEM Tacoma Spindles w/ Dirt King Gussets.
    Spindles sandblasted, mig welded, masked and painted w/ Black Steel-It. Removal of sway bar required.
    $425 shipped in cont USA.
    Located in St Charles Illinois.
    If you want to save on shipping, pick up is also welcomed.
    20240329_151013.jpg 20240329_150959.jpg 20240329_150939.jpg 20240329_150927.jpg
    Tatts521 likes this.
  2. Oct 18, 2023 at 3:14 PM
    r34p3r666
    r34p3r666 Well-Known Member
    Diamond Bar, CA
    6-Speed Tacoma Baja T/X, TRD Supercharged
    Soldarino!
  3. Oct 21, 2023 at 3:04 AM
    B3RM4N
    B3RM4N Well-Known Member
    SF - Bay Area, CA
    2013 Tacoma TRD Offroad 4x4
    Still available?
  4. Mar 29, 2024 at 1:17 PM
    Captainskidmark
    Northern Illinois
    Bump, have a 2nd set for sale.
    caliburrito likes this.
  5. Mar 29, 2024 at 1:20 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Man I really should get a set of these
  6. Mar 29, 2024 at 1:50 PM
    Captainskidmark
    Northern Illinois
    What's stopping you? Lol
  7. Mar 29, 2024 at 1:51 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    Already spent too much money on my truck recently combined with some laziness (don't feel like installing them lol)
  8. Mar 29, 2024 at 2:54 PM
    Captainskidmark
    Northern Illinois
    Assembly time is a fraction of what it normally is if you have the welded up set ready to go. As long as yours are in good condition, all threads good, not bent or beat up with a hammer from removing ball joint or tie rod I would buy the cores back from from you.
  9. Mar 29, 2024 at 2:55 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    I will have to keep that in mind!
  10. Mar 31, 2024 at 8:25 AM
    Captainskidmark
    Northern Illinois
  11. Mar 31, 2024 at 8:28 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  12. Mar 31, 2024 at 2:05 PM
    r34p3r666
    Diamond Bar, CA
    Mine are installed and loving them! Scoop 'em up, you won't be disappointed!! :cheers: BUMP!!
    Captainskidmark[OP] likes this.
  13. Apr 1, 2024 at 5:08 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    What are the advantages to these?? I’m still a noob!
    :anonymous:
  14. Apr 1, 2024 at 5:17 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Huge increase in strength. Spindle is a weak point when taking a hard hit on the suspension and the gusset shores that up.
    Argann and Captainskidmark[OP] like this.
  15. Apr 1, 2024 at 5:22 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Wiggle on price if I send you mine back to do another set?
    edit: just kidding I’m reading on ifs off-road there is some difference in taper where upper ball joint connects spindle, not sure it will work out for me.
    TegoTaco likes this.
  16. Apr 1, 2024 at 8:11 PM
    Captainskidmark
    Northern Illinois
    If you spend time off roading, then reinforcing your spindles is a good way to prevent them from bending. You can probably look on YouTube for bent spindles. Most folks modify suspension for off road, but don't think of the weak links, which are the spindles
    Gussets do not interfere with upper ball joint mounting, not sure what you are referring to.
  17. Apr 1, 2024 at 8:12 PM
    T4R_hereforbearings
    WA
    08 4Runner
    I have a 4Runner not a taco and I think there is a slight difference. Not that the gusset would interfere with anything but bolting in my ball joint from UCA has caused others problems trying to use 2nd gen taco spindle on 4th gen T4R.. so I’ve read anyways…
  18. Apr 1, 2024 at 8:15 PM
    Captainskidmark
    Northern Illinois
    Gotcha, what gen? My son has a 3rd gen and I have a 5th gen...
  19. Apr 1, 2024 at 8:18 PM
    T4R_hereforbearings
    WA
    08 4Runner
    4th!
  20. Apr 1, 2024 at 8:25 PM
    Captainskidmark
    Northern Illinois
    No problem, let me know if you want them done.
Thread Status:
