Sold - 05-23 OEM Tacoma Spindles with Gussets
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Captainskidmark, Sep 30, 2023.
Thread Status:
Not open for further replies.
  1. Apr 2, 2024 at 7:42 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Can confirm, need the right spindle and UCA pairing or you are going to ruin both parts.
  2. Apr 2, 2024 at 8:07 AM
    Captainskidmark
    Captainskidmark [OP] Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    For the record, I wasn't attempting to pass these off to fit a T4R, there are model specific gussetts available for the T4R and would be willing to weld up a set if both the spindles/gussets are provided. From the searches I have done they do not look to interfere with upper ball joint mounting so I am not certain what that is all about.
  3. Apr 2, 2024 at 8:09 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    From what I know the 4runner and the tacomas use different tapers for the upper ball joint
    SUMOTNK and BabyBilly like this.
  4. Apr 2, 2024 at 8:10 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I wasnt stating that you were, just confirming the fit on a 4R. And the issue is with the taper in the spindle, the gusset has nothing to do with it, a stock taco spindle will not fit properly on a 4R UCA.
  5. Apr 2, 2024 at 8:10 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Correct.
    SUMOTNK likes this.
  6. Apr 2, 2024 at 8:20 AM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Thanks for info, I also read and said that about taper quickly after I asked yesterday but OP nice work regardless!! ​
  7. Apr 2, 2024 at 8:20 AM
    Captainskidmark
    Northern Illinois
    Thanks guys.
  8. Apr 6, 2024 at 3:19 PM
    Captainskidmark
    Northern Illinois
  9. Apr 15, 2024 at 4:15 AM
    Captainskidmark
    Northern Illinois
  10. Apr 20, 2024 at 3:47 PM
    Captainskidmark
    Northern Illinois
Thread Status:
