SOLD --- 08 Tacoma Sport AC, 4x4, Supercharged, 63k miles - Las Vegas,NV -- SOLD
Discussion in '2nd Gen Tacomas For Sale (2005-2015)' started by 5678ta, Feb 13, 2021.
  1. Feb 13, 2021 at 5:36 PM
    5678ta
    5678ta [OP] Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Moved into a ZR2 nearly two years ago, which I’ve since poured my heart and soul into. The Tacoma has sat and watched that entire process. Truck was originally from Hawaii and is named “BRUZER”. Disclosed below are all the positive and negatives of this truck, so we will start with the negatives as no one likes surprises. My plan was to address most of these, but I have had absolutely zero interest in this truck with the ZR2 build going.
    Everything listed as New was done within the last 3k miles at just over 60k miles.
    CARFAX REPORT PDF IN ATTACHMENTS
    Link to Pics
    Basics:
    • 2008 Tacoma TRD Sport
    • Access Cab
    • Indigo Ink Blue
    • 63k miles
    • 4.0L/Auto/4x4
    • URD Stage 2 Supercharger
    • Detroit TrueTrac LSD (not an e-locker truck)
    • No traction control or ATRAC
    • 3" lift on Bilstein 5100's
    • Averages between 12-16 mpg, depending on your driving style and speed.
    Negatives
    • Part throttle under load can misfire on occasion
    • If you can figure this out, it will run flawlessly
      • Throws occasional P0101 code for MAF sensor
      • P2196/P2198 for upstream bank 1 O2 sensor (either exhaust leak or sensor(included))
      • Can sometimes produce an abrupt jerk when letting off throttle quickly(rolling off helps)
    • Exhaust
      • Truck is catless and the muffler is likely blown out so it is a bit LOUD
      • Does rasp between 2300-2800 rpm under light/mild load
      • Passes OBD emissions with no issues
      • Exhaust leak, likely just needs tightening (new header gaskets included)
    • Truck was used primarily for offroad/overland adventures so paint could use some love and has spots of bad clear coat.
    • Passenger headlight is cracked but not broken
    • HVAC Recirculation motor occasionally flaps/grinds (new motor included)
    • Airbag light just recently came on
    • Lower ball joints need replaced (new Moog BJ’s and bushings included)
      • Needs alignment
    Performance
    • URD Stage 2 supercharger (installed at approx 15k)
      • Inline boost controller (~4psi/~9psi)
    • URD cam gears
    • APR X1 Piggyback EMS system
    • CravenSpeed FlexPod gauge mount (behind steering wheel)
    • AEM digital boost gauge
    • AEM digital UEGO wideband
    • ScanGauge 2
    • Doug Thorley long tube headers
    • Doug Thorley pipe-bomb Y-pipe
    • URD 3” Catback exhaust
    • Magnaflow muffler
    • Tailpipe cut after axle
    • Denso IKH24 plugs
    Interior
    • Seats are like-new - They were covered their entire lives until recently
    • Some panels have scratches from holding gear
    • Custom gauge overlay
      • Carbon Fiber look
      • “BRUZER” label
    • Bird Dawg Industries Tech Deck X-treme duty accessory dash mount
    • Ram mount ball 1” (including 1 short arm, no mounts)
    • Superbright LED map lights (white)
    • MesoJDM LED Dome light (white)
    • Console organizer
    • Glove Box organizer
    • Weather Tech floor liners front and rear
    • Ceramic tint(50% windshield, 20% sides and back)
    • 100W solar system (currently disconnected)
      • Suaoki flexible panel on roof
      • Victron solar controller in console
    • Always hot drivers side cigarette lighter
    • Passenger side cig lighter converted to two USB ports
    • Upgraded speakers
    • Basic single DIN Kenwood deck
    Exterior
    • “Ultimate” Headlight upgrade
      • 90w/100w bulbs
      • H4 standalone harness from Rally Lights
    • TRD Sport smoked headlights from 2010 Tacoma (passenger side lens crack)
    • New OEM style Foglights
      • Always on mod (does not turn off with highbeams)
    • 886 Reverse light upgrade
    • Custom built Aluminum camper with side doors and pop top (not fabric enclosed)
    • KB VooDoo steel bedrail caps
    • Total Chaos Bed Stiffeners
    • Toyota Bed Matt
    Misc
    • Mesh grill
    • Redline Elite hood supports
    • Singer Electric voltage booster
    • NEW 27F battery
    • ARB Twin Compressor
      • bumper mounted air chuck
      • 20ft coil hose
      • ARB inflator
    • 1” Spidertrax Wheel Spacers
    • 4Runner Trail wheels (17x7.5”)
    • Nitto Terra Grappler G2 tires (~8k miles/~80% tread)
      • 285/70r17
      • Fullsized spare
        • Old torn up G2, but still good
    • RTMR fuse/relay box
      • 5 fused hots
      • 5 relayed circuits
    • Interior switches
      • “Flux Capacitor” - boost controller
      • “Fridge” - 10awg lead under driver’s seat
      • “Compressor” - two relay circuits setup for ARB Twin
      • “Traction” - tricks 4x4 ECU for front diff ADD disconnect delete
    Front end (everything listed as new, has less than 3k on it)
    • NEW Bilstein 5100
    • NEW OME 885 coils
    • NEW KYB top hat assembly
    • NEW Wheel bearing assemblies by 05Taco4x4
    • NEW Moog Inner tie rods
    • NEW Moog Outer tie rods
    • NEW East Coast Gear Supply needle bearing upgrade bushing
    • NEW Timken front diff seal
    • NEW PowerStop extreme drilled/slotted rotors
    • NEW Akebono Performance Ceramic pads
    • Total Chaos Uniball upper control arms
      • NEW ICON Delta Joint upgrade
    • FJ full time front axle upgrade (No ADD to fail)
    • Wheelers Superbumps front bump stops
    • 1” diff drop
    Rear end
    • NEW Bilstein 5100 “B110” extended length
    • NEW Moog Superduty rear driveshaft U-joints
    • NEW Archive Garage Hammer Hangers (HD leafspring hanger)
    • OME Dakar leafpack
    • Extended brake lines
    • Timbren U-Bolt Flip with Timbren Bumpstops
    • Detroit TrueTrac diff
    EXTRA PARTS, INCLUDED WITH TRUCK
    • 6ft ARB 2000 Awning
    • Factory front sway bar (missing one bushing bracket)
    • Sway bar drop kit
    • Baja Designs Squadron fog light brackets
    • UCON EMS system
    • Spare factory ECU
    • Spare MAF Sensor
    • Spare Throttle Body
    • New Supercharger oil, filter and Serpentine belt (for 50k mile supercharger maintenance)
    • New HVAC blend door motor
    • New Denso upstream O2 sensor
    • New Driveshaft carrier bearing
    • New Moog Lower control arm bushings and ball joints
    • New Energy Suspension polyurethane steering rack bushings
    • New Wix air filter (49350)
    • New fuel filter
    • New Wix XL oil filter (51516)
    • New Exhaust/header gaskets
    • New Y-pipe gaskets
    • New Deatschwerks 255LPH fuel pump
    • New set of 61# injectors
    SOLD
    Geeves77 and tortoise_taco like this.
  2. Feb 14, 2021 at 5:44 AM
    04TrDtAcO4x4
    04TrDtAcO4x4 Well-Known Member
    2004 Lunar Mist TRD Tacoma
    Nice truck!
    5678ta [OP] likes this.
  3. Feb 14, 2021 at 10:25 AM
    5678ta
    Hogan
    Henderson, NV
    Pics and Carfax report added
  4. Feb 17, 2021 at 6:49 PM
    5678ta
    Hogan
    Henderson, NV
    Bump. Very motivated seller. All offers considered.
  5. Feb 18, 2021 at 2:27 PM
    virvak2
    virvak2 Well-Known Member
    Kyle
    Castle Rock
    '13 TRD Off-Road
    Can confirm, this truck is ALOT of fun to drive
  6. Feb 19, 2021 at 10:50 PM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Ill start the bidding at 14k! Nice truck, glws ;)
  7. Mar 4, 2021 at 1:59 PM
    5678ta
    Hogan
    Henderson, NV
    Bump.
    Updated post with Extra parts list, cleaned up redundant lines and added link to pics.
    TWENTYCO likes this.
  8. Mar 18, 2021 at 9:26 AM
    5678ta
    Hogan
    Henderson, NV
    Still got this. Bunch of flakes reaching out.
  9. Mar 22, 2021 at 2:48 PM
    virvak2
    Kyle
    Castle Rock
    '13 TRD Off-Road
    Monday Bump
  10. Mar 25, 2021 at 10:49 PM
    5678ta
    Hogan
    Henderson, NV
    Bump.
    Got a new fuel pump, injectors and Y-pipe gaskets to include with the truck.
  11. Mar 28, 2021 at 1:23 PM
    5678ta
    Hogan
    Henderson, NV
    SOLD SOLD SOLD
