SOLD: 100% Aluminum offroad camper trailer
Discussion in 'Northern California' started by FloTaco, May 29, 2023.
  1. May 29, 2023 at 3:34 PM
    FloTaco
    FloTaco [OP] Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    Never thought I’d sell it but we have a baby on the way and I just don’t see having the time to use it. This trailer is so well built and very light weight. Located near San Francisco International. $14k.
    • 2021 Weeroll Wrangler-X. 5’ wide, 8’ long box, 4’ interior height, 7’ track width. Factory powder coating, roof racks, blackout package, and 31” offroad tires. About 5000 miles and used about 14 nights total. Always ceramic coated between washes. Always stored with fresh Damprid inside when not used.
    • Registered and plated in FL as that is my state of residency.
    • 100% 6061 T6 aluminum construction. No wood and no steel. The roof is a 1 piece pressed sheet of thick .090” aluminum that runs the full length of the trailer, and down the nose to the frame with a built in drip edge. Lifetime leak proof roof warranty from Weeroll. The exterior is 3M industrial bonded .068” aluminum, the interior walls are .040”. Walls are 1” thick with insulation.
    • Weighed 870lb new from the factory, now weighs about 1100lb. It can be towed by just about any vehicle.
    • The entire frame is built with 6061 T6 structural hardened aluminum. The chassis and tongue are 1/4” thick. The main frame is 2x3” and the wall/roof frames are 1x2”. This is the last year that Weeroll built their trailers with square tube main chassis and triple tongue before moving to C-channel construction.
    • Dexter Torflex 2500lb axle. Hubs re-greased 1000 miles ago with “Red N Tacky”. The axle is tracked out super wide making the trailer extremely stable on and offroad.
    • Driver and passenger side doors, and double rear barn doors, all are heavy duty and double weather stripped. Sliding side windows with privacy glass and screens. Front removable portal for a fan, AC, or heater.
    • Full size memory foam mattress on lightweight platform frame.
    • Rubber protective flooring over 1/8” aluminum solid plate floor.
    • Renogy solar 100w and AGM 100amp. Puts out a ton of power. Runs the trailer and a DC fridge indefinitely. Has 30a external shore power AC receptacle. Interior AC/DC outlets.
    • Roadshower/Yakima 4.5 gallon aluminum solar shower.
    • Wheels are Jeep lug pattern, can be adapted to Toyota. Spare wheel with new tire included.
    • Extra 1/4” aluminum axle hangars included from the factory for any future modifications, such as Timbren axles.
    • Rear stabilizer jacks.
    • Lock N Roll hitch, always greased. Including the trailer and vehicle sides of the hitch with the sale.
      3E826C7D-4BDE-42C2-B3AB-5DADE8569777.jpg B154FA76-5420-42B1-B75A-F8B095926CCF.jpg 2A815BFF-1B2D-485C-8EE0-B4A4FC172E9C.jpg 31920CA6-6D83-4E3B-8C61-A50FB10B83CD.jpg 2DF7D713-82F9-4D8C-A35A-9666840D739A.jpgBCD4F1C4-6F93-445F-94C9-240913526279.jpg5BEB2BF1-B81F-44F4-B7C3-6F5A7E8C9C54.jpgDE6488D6-B4F1-492A-ACA1-6BB16E854D2B.jpg8F329F3F-73A2-432D-B1BA-6285E6EBEB2A.jpg820FDDBE-AE3A-4045-9938-A1325FAD5E7A.jpg911699FE-E3E6-4048-BF83-40A89D03339A.jpg
    essjay and loyaltothetaco like this.
  2. May 29, 2023 at 3:57 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Didn't see it in the description. Price?
  3. May 29, 2023 at 4:06 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  4. May 31, 2023 at 8:33 PM
    HellTaco
    HellTaco Well-Known Member
    2017 4x4 TRD OR
    Congratulations on the baby! Very nice trailer GLWS
    FloTaco[OP] likes this.
  5. Jun 1, 2023 at 9:22 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    what suspension is on that thing?
    and that would change my kayak fishing life...nice!!
  6. Jun 1, 2023 at 11:42 AM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    It has a 2500lb Dexter Torflex which uses a straight axle tube but with independent wheel torsion. The axle hangers are long enough to put a 1” lift block in as well, if you ever want more clearance. It’s real nice…
  7. Jun 1, 2023 at 2:13 PM
    aficianado
    back to bone stock.
    ah, i see it now!! thanks.
