Sold - 1996 Toyota Landcruiser (FJ80) sadly for sale
Discussion in 'Buy / Sell / Trade - Other' started by Techoma, Mar 28, 2018.
Thread Status:
Not open for further replies.
  1. Mar 28, 2018 at 5:16 PM
    Techoma
    Techoma [OP] This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    The 1996 Toyota FJ80 Landcruiser 4x4 Currently 297k Miles (I paid $9500 01/17 but unexpectedly got laid off 3 mos after buying home 12/17... Must go)
    280 K Previous owner took apart the engine. New seals and gaskets in the whole engine. All new hoses and belts, New plugs and wires. New Radiator, New battery, Trans was torn down inspected and installed new gaskets. Axles were torn down cleaned and repacked with grease Including birfs. 4" Old Man Emu lift kit and coils with upgraded suspension from Desert Tools the premier Land Cruiser Shop in the valley. New bump stops. Fan was juiced for better A/C performance. Front bumper is after MKT Metal Tech. Rear Bumper is 4x4 Labs custom with Spare tire swing and Gas Can Basket swing. Interior was completely gone through and all seats recovered. Shifter boot was recovered. Dashmat. Double Din Kenwood aftermarket Stereo w\remote. Weather Tech Front, Mid and Rear Cargo mats. CB radio and antenna. The suspension is VERY sweet!
    Including the following “stuff”:Rear speaker covers, Drop hitch, Mid door speaker cover and mounting bracket, Extra Radiator cover, Extra Gas Cap, Extra Belts
    I added (Approx $6K)
    - 5 35/12.50R17 Toyo Open County RT tires ($1966.15)
    - 4.88 Gears and Locked Front and Rear diffs with Harrop E-Locker (wiring still in box!) Work done by ZUK!
    - New Windshield
    - Trailer Brake (7 wire)
    - Traction pads
    - Custom Center console cup holder
    Options:
    - PrinSu Rack brand new in Box ($1100) for $500
    - Puma Compressor with an Inline fuse holes and the custom mounting brackets for rear fender well. $200
    The Bad:
    - Power seats are a mess operationally. Drivers side works pretty well. Passenger side gear is bad. Both reasonably easy to fix.
    - I bought new calipers and pads as one was squeaking. When I was putting them on, I realized the old pads were still good. More investigation and I discovered the bottom bolt on both calipers was stripped, and the loose caliper was causing the brake squeal. I wasn't sure if I should go HeliCoil or JBweld... or what... so it sits needing that figured out and then brakes being bled.
    - AC is good and cold until true AZ heat kicks in! It’s a big cabin… will not cool it!
    - Head unit is great, speakers are either unplugged, not in, or sound like crap.
    - Big Power steering leak from rotted line
    - The Belt will squeal on a cold start. I believe it is power steering oil on pulley
    - Power Sunroof works great but interior plastic trim is sun rotted and cracked badly
    - Passenger front fender well off but still have
    Easily passed emissions when I purchased, no engine lights on.
    So, 15 K into it, driven less than 3 k miles... 8.5K will take it. As soon as I get access to Pirate 4x4 again, I'll be posting it for sale there.
    $8,500
    480-422-6069
  2. Mar 28, 2018 at 5:24 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  3. Mar 28, 2018 at 5:27 PM
    Techoma
    Alta Mesa, AZ
    I know....
  4. Mar 28, 2018 at 7:39 PM
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    :drool: :(
    Sad to see this being the reason, so much want!
    GLWS
  5. Mar 29, 2018 at 2:55 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  6. Mar 31, 2018 at 8:34 PM
    CaliDevilDoc
    CaliDevilDoc Well-Known Member
    San Diego, CA
    2016 Barcelona Red TRD Off-Road 4x4. 1995 FZJ80
    OME nitrochargers, 886, and Dakars
    Chief, this is exactly what I'm looking for. How soon are you looking to sell it?
    Techoma[OP] and fatfurious2 like this.
  7. Apr 2, 2018 at 7:30 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  8. Apr 3, 2018 at 12:38 AM
    h5863emtmatt
    h5863emtmatt Well-Known Member
    San Diego
    17' TRD OR 4x4 DCSB
    Method Vex311, Toyo Open Country AT, 2.0 Fox Performance Coilovers/Reservoir, Total Chaos UCA, Pelfreybilt, Prinsu Cabrac
    Will the Prinsu rack fit tacoma 3rd gen DC?
  9. Apr 3, 2018 at 3:18 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Good deal but i already have 2 locked FZJ80's.
    fatfurious2[QUOTED] likes this.
  10. Apr 4, 2018 at 8:43 AM
    CaliDevilDoc
    San Diego, CA
  11. Apr 4, 2018 at 10:09 PM
    Techoma
    Alta Mesa, AZ
    It is for sale. A guy from the east coast is looking at flying out next month if it is still avail.... many pics on my FB page Sorry I haven't posted... been absent. Been very ill. Hopefully turning the corner on a string of bad juju these past 2 months.
  12. Apr 5, 2018 at 6:48 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    :amen:
  13. Apr 5, 2018 at 9:19 PM
    Techoma
    Alta Mesa, AZ
    Sold to one of my East Coast TW ballers!
  14. Apr 5, 2018 at 10:46 PM
    Tacomamike mike
    Michael
    Very happy for you !! Get well and a new job now :). I like others are routing for you !!!
Thread Status:
