Sold! 2.7 Reg cab stainless exhaust parts (NJ)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by JL8Jeff, Sep 11, 2021.
  1. Sep 11, 2021 at 11:33 AM
    JL8Jeff
    JL8Jeff [OP] Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Sold! I have some leftover exhaust parts that will fit a 2.7 regular cab truck. There is a 2-1/2" flange piece with the gasket that fits the 2.7 cat pipe, a section of 2-1/2" stainless pipe that is a slip fit to the flange pipe (overall length of flange plus slip fit pipe 20.5"), A Dynomax 17289 stainless 2-1/2" muffler and a 2-1/2" stainless clamp for the slip fit to flange pipe. The muffler is 25" long overall with the body being 20" long. The muffler is used, everything else is new. The muffler inlet and outlet could use a little more expanding to get the pipes in easier but you can wiggle the pipes into the muffler. I was going to add the Dynomax 54669 tailpipe and 36427 hanger/clamp to build my own system. This muffler is longer than the muffler that comes with the 39447 exhaust system so you would need to shorten the tailpipe a little or the 20.5" intermediate pipe I have here. There are 2 flange gaskets included. If you can find a longer intermediate slip fit pipe, then it would also fit the access cab or quad cab. $90 local pickup, shipping is possible if I can find a large enough box but with the weight/size, it might not be cheap
