SOLD 2001 3.4L TRD Off Road Access Cab MT 164k miles
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by RyanL, Jul 4, 2024.
Thread Status:
Not open for further replies.
  1. Jul 4, 2024 at 4:56 PM
    RyanL
    RyanL [OP] Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    2001 Tacoma TRD Off Road with 164k miles. Well maintained, mostly used by my dad for the occasional Home Depot run. Selling because grandpa wants a newer truck now.
    5-speed manual transmission with 4-wheel drive and rear diff lock. Access cab, bed liner, lots of tread on tires.
    AC blows super cold. Drives straight, starts right up and runs strong like a Tacoma should. 4WD and rear locker work perfectly.
    Maintenance in the last 5k miles:
    New timing belt, water pump, spark plugs, master clutch cylinder, rear bearings and seals and axle, rear brake shoes, front and rear differential fluids, transfer case fluid, new windshield, battery, starter, both front lower ball joints, alignment, oil change.
    Solid frame with some surface rust as is common on these. The truck lived in SoCal its first 8 years and has been in Utah / Idaho since. Has had a couple accidents in its life that were repaired nicely, clean title, looks good overall. Washer fluid works but the gauge always says it’s low. Engine temp gauge also doesn’t read right so we have an UltraGauge to read that.
    $15k. Located near SLC Utah.
    09 Redneck, Jim727386 and 23MGM like this.
  2. Jul 4, 2024 at 4:56 PM
    RyanL
    Indiana
    IMG_1843.jpg IMG_1844.jpg IMG_1845.jpg IMG_1847.jpg IMG_1848.jpg IMG_1848.jpg IMG_1850.jpg IMG_1851.jpg IMG_1854.jpg
    ztwatson likes this.
  3. Jul 13, 2024 at 3:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Nice looking truck. and seems well maintained. A bit of rust but hopefully it is only surface rust. Is that the original suspension? How are the springs holding any weight thats put in back?
  4. Jul 14, 2024 at 8:12 PM
    RyanL
    Indiana
    Sold
Thread Status:
