SOLD 2001 Tacoma doublecab TRD 4x4
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by aru, Aug 5, 2017.
Thread Status:
Not open for further replies.
  1. Aug 5, 2017 at 10:17 AM
    aru
    aru [OP] Well-Known Member
    Sarasota Florida
    TRD DC 4x4
    King Coilovers, TC UCA's, OME rear leafs with shocks, Tundra brake upgrade with stainless brake lines, ECGS 4.88 front/Rear ARB&TRD locked, 285/70/17 BFG KO2, TRD 2nd Gen S/C, URD 7th, 2.1 & crank pulley, TRD headers, TRD air filter, PLX gauge built into my rear view mirror with boost, AFR, EGT, Trans Temp and TRD Trans Cooler....love this truck
    http://s350.photobucket.com/user/alexruiz6/slideshow/
    I hope this goes through, it's time to sale my tacoma and go back to a bigger truck. I know I will regret this. I bought this truck stock a few years ago and added everything you see here. The previous owner pretty much owned it since new even though I'm the 3rd owner. Truck has always been in Florida, no rust issues. The truck cosmetically isn't perfect but looks great and everything works as it should.
    Lunar Mist
    4x4 with e-Locker
    3.4 auto
    ECGS 4.88 front and rear gears 2016
    Dakota Digital Dash SGI-5 speedometer signal interface
    ARB front locker 2016
    ARB air compressor 2016
    King coilovers
    Total Chaos UCA's
    New LCA's 2016
    Timing belt, tune up 2016
    Dakar leaf pack with nitro charger shocks 2015
    Timbren rear bump stops
    All-Pro Greasable lift shackles
    Stainless steel IFS Skid plate
    Sequoia 17" wheels
    2 months old BFG Ko2's 285/70/17 (with a full spare not mounted)
    Tundra brake upgrade 2015
    Deckplate mod
    TRD Airfilter
    TRD oil cap
    TRD radiator high pressure cap
    Gray wire mod
    Napa lifetime warranty CV's 2016
    Napa lifetime warranty tie-rod ends 2016
    Napa lifetime warranty inner ball joints 2016
    I purchased the firestone lifetime alignment so it get aligned every 4 months whether it needs it or not.
    Stainless steel brake lines (extended) 2015
    Snug topper with roof rack
    Inside bedrug cover (used but not installed) has plastic bed liner
    Projection headlights with turn signal halos 2017
    Ceramic tint with windshield tinted (it's hot in Florida)
    Front and rear Hitch and transmission cooler
    Weather tech floor mats
    Tacoma limited from seats -super comfortable and way better than factory, electric lumbar
    This has been my baby and has always been maintained with synthetic fluids.
    CARFAX report is available
    Moving back to a full size diesel.
    Truck is located just outside of Sarasota, FL
    Sold -the truck or packaged with below TRD supercharger. I'm not desperate to sell and may consider leaving it my property in the woods of AL.
    Also available with or with out truck-
    Please call/text me because I'm not on here very often. Asking $3700, selling because I'm buying a full size truck, I have collected all this over the last year. Turn-key supercharged solution. The supercharger and accessories are currently listed in TW classifieds for pic references.
    TRD Supercharger, purchased used with brand new TRD nose cone installed. Great shape, unknown miles. Comes with belt and 2 TRD tensioners
    URD 7th injector bought brand new. Never installed, 7th injector is installed in supercharger-pic for reference. No fuel pump, misplaced it and can't find it.
    URD 2.1 and 2.2 pulley with tensioner pulley, needs bearing to be pressed into it. Not hard to do.
    2- TRD 160 degree thermostats
    TRD headers, comes with a 2 bolt flange, so if yours is 3 bolt you will either need to replace or add the correct flange.
    Used PLX gauges DM-100 & SM-AFR & SM-Fluid Temp
    All great shape, won't last long. This is a package deal will not separate. You may have to source a few little parts for install, gasket, dip stick extension (easy to make something)...not a lot and it will not be expensive.
    2004TacoBill and nikeballs7 like this.
  2. Aug 5, 2017 at 5:54 PM
    nikeballs7
    nikeballs7 Active Member
    Brealon
    King, NC
    2004 Tacoma Double Cab SR5 4x4
    Toytec BOSS Coilovers Toytec AAL Trail Gear Rock Assault Bumper SCS Ray10 Maxxis Razr MT 285/75/16
    Dang, I want that snugtop
  3. Aug 6, 2017 at 4:55 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Willing to separate the truck? I'm just looking for the right pass door.
  4. Aug 6, 2017 at 5:13 PM
    aru
    Sarasota Florida
    TRD DC 4x4
    Yeah, $13,900 and the door is all yours bud.
    tony2018, v5ensx and Beee1985 like this.
  5. Aug 12, 2017 at 4:52 PM
    aru
    Sarasota Florida
    TRD DC 4x4
    Ttt
  6. Aug 14, 2017 at 3:25 PM
    aru
    Sarasota Florida
    TRD DC 4x4
    Sold but the TRD Supercharger and accessories are available for sell in TW classifieds
Thread Status:
