SOLD: 2001 Xtra Cab V6 4x4 5-speed SR5 TRD
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by scocar, Oct 5, 2015.
Thread Status:
Not open for further replies.
  1. Oct 5, 2015 at 11:28 PM
    scocar
    scocar [OP] Patron of the Farts
    An increasingly rare find in excellent condition: California rust-free truck.
    I just got this truck pretty much how I wanted it last year before an adventure to Utah. Only selling it, very reluctantly, because I needed a larger vehicle for a growing family and already bought a 2015 DCLB.
    I'm the second owner, purchased at 100,000 miles in October 2009 from original owner. All original owner manuals included.
    150,618 miles, clean title, no lien, no accidents. Registration with smog certification renewed August 2015. Smog is good for 2 years in California.
    Truck is located in Sacramento.
    • Options: rear differential e-locker, power windows and mirrors, air conditioning, cruise control, power steering, etc.
    • Toyota 4Runner Limited 5-star alloy wheels (same specification as original Tacoma TRD alloy wheels). Michelin LTX AT2 tires 265/70-16 (tread depth coming), installed March 2010 @ 105,000 miles
    • Class 3 trailer hitch receiver and 7-pin harness
    One mechanical issue: split CV boot fin on driver side. It has been driven only about 40 miles in this condition on dry, paved roads. The CV joint/axle itself is fine and just needs to be rebooted. I include an OEM spare that can be rebooted in advance for R&R.
    Accessories and Modifications
    • Snugtop Supersport cap
    • Hidden Hitch Class 3 hitch receiver installed by me
    • 7-pin trailer harness electrical system installed by me with marine-grade wiring and all soldered connections and self-resetting circuit breakers. Brake controller wiring in place except for in cab (no controller installed). Military style battery connectors installed.
    • Pilot brand auxiliary backup lights installed on hitch receiver
    • Redline gas-lift hood struts
    • Weathertech laser-fit floor mats (front only)
    • Rubber bedmat
    • Spray-on bed liner (by original owner, type unknown, excellent shape)
    Old Man Emu (OME) offroad lift suspension
    (approx. 2 inches lift over stock ride height)
    • OME 881 coil springs, OME 90004 Nitrocharger Sport shocks (installed May 2011)
    • OME 95PF5 Driver side 5mm trim spacer
    • OME CS046RA/BDakar leaf springs (installed September 2014)
    • OME 60062 Nitrocharger Sport shocks (installed May 2011)
    • OME GS12 greasable leaf spring shackles
    • OME SB88 greasable bushings
    • OME FK21 tailpipe hanger extension
    • Wheeler’s Offroad braided stainless steel extended rear brake line (TF Bline 04X 19-inch)
    • Bay Area Metal Fabrication brake proportioning valve (BPV) relocation bracket
    • Rear differential free-flow breather extension
    • Anti-swaybar currently removed (parts retained, included upgraded poly bushings)
    Preventative Maintenance Overview
    Records available from both owners (original owner partial).
    Previous owner records available:
    Timing belt replaced at 93,395 miles by Stevens Creek Toyota (by first owner). Service included spark plugs, throttle body and "major induction service", coolant change, motor and gear oil, air filter change. Also indicated previous services at 52,500 miles and 37,500 miles.
    All preventative maintenance service performed under my ownership using Toyota’s maintenance schedule:
    • Motor oil full synthetic either Mobil 1 or Pennzoil Ultimate, Toyota OEM filters. Blackstone Laboratory oil analysis reports available: "wearing beautifully @ 120,865 miles".
    • Redline MT90 full synthetic transmission and transfer case oil
    • Valvoline non-synthetic gear oil for both differentials
    • Coolant changes using Toyota OEM coolant only
    • Denso K16TR11 dual electrode plugs changed at 120,000 and 150,000 miles, retained for proof of combustion conditions
    • NAPA Gold or similar media filters
    • Tires rotated every 5,000 miles by me, all lugs hand-torqued to spec.
    Other Maintenance/Repair
    • Lower ball joint recall/replacement performed by Maita Toyota June 2010 @ 108,200 miles
    • Throttle body and IAF sensor cleaning and gaskets replaced with OEM parts @ 120,547 miles
    • Brake rotors and pads replaced @135,338 miles
    • Passenger-side CV replaced with EMPI new part (not remanufactured) at 136,351 miles because of split rubber boot (OEM CV/Birfield retained for rebooting and re-use as spare).
    • Fuel filter replaced with OEM part @ 140,883 miles.
    • Air-fuel sensor replaced with OEM Denso part @ 150,543 miles.
    • New battery installed @ 150,618 miles (October 2015)
    • Door window trim replaced with OEM parts.
    • Pop-out window latch hinges replaced with billet aluminum (original plastic notorious for breaking).
    • Cup holders refurbished with rubber flaps.
    • Temperature control bulbs replaced.
    • Driver side door check replaced with new OEM.
    $13,500
    Edit: Teardrop trailer not included, but I will throw in a new, really nice Heatshield brand windshield sunscreen.
    Soul Surfer, AR15xAR10 and JimBeam like this.
  2. Oct 5, 2015 at 11:31 PM
    scocar
  3. Oct 5, 2015 at 11:31 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    GLWS.
    scocar[OP] likes this.
  4. Oct 5, 2015 at 11:33 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Very NICE......GLWS
  5. Oct 5, 2015 at 11:46 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Glws bump
  6. Oct 6, 2015 at 12:00 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    All "For Sale" threads should be this good.
    GLWS.
  7. Oct 6, 2015 at 3:13 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Great ad for an awesome truck! GLWS.
  8. Oct 6, 2015 at 3:37 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Real nice truck but i gotta ask. Why are our 1st gens worth so much??? A 15 year old truck for almost $18000cdn. You can get equivalent rangers and dakotas in same shape for about $4000cdn
  9. Oct 6, 2015 at 4:20 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Anything is worth what others are willing to pay for it
    @scocar GL with your sale but I think the OP really needs a bit more detailed information on the truck and some more pictures. :p
    scocar[OP], T4RFTMFW and MQQSE like this.
  10. Oct 6, 2015 at 8:57 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    That's just there so it's a legit ad in craigslist when he copypastas everything.
    I think this truck is cleaner now than mine was when I got it in 2008..wtf.
    T4RFTMFW and scocar[OP] like this.
  11. Oct 6, 2015 at 8:59 AM
    scocar
    Quality, reliability, scarcity, and demand. And I think today, simplicity of systems.
    ^^^^ willingness to pay nails it.
    This is a business thread, not a BS thread...
    I appreciate the bumps, guys.
  12. Oct 6, 2015 at 10:11 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    BINGO!
  13. Oct 6, 2015 at 12:45 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    I'll give you $5 for the teardrop...and I'll come pick it up too. :D
  14. Oct 6, 2015 at 12:49 PM
    scocar
    Sorry, it is in the shop being fitted with a baby cage. I mean bunk.
  15. Oct 6, 2015 at 1:08 PM
    MTgirl
    Weesa
    Fine. $7, final offer and I don't need the bunk...a built in wine rack would be nice though...
  16. Oct 6, 2015 at 3:03 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    This is the exact same truck as mine minus the bumpers. Looks great!
    GLWS
  17. Oct 6, 2015 at 6:21 PM
    scocar
    Thanks, man. Actually, I do have a brand new Homeroshi in the box, never been installed. That will be up for sale, too...
    MQQSE likes this.
  18. Oct 7, 2015 at 6:03 PM
    mystik cabs
    mystik cabs Well-Known Member
    Brian
    North Stonington, CT
    '04 TRD DBL Cab
    I call First shot at the grill!
  19. Oct 7, 2015 at 9:54 PM
    scocar
    So yeah, who's going to buy my truck?
    Bring the boys in, Kari.
    T4RFTMFW likes this.
  20. Oct 7, 2015 at 10:15 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :) Kari
Thread Status:
