SOLD: 2005 DCSB Speedway Blue // 200k Miles // TRD Supercharged
Discussion in '2nd Gen Tacomas For Sale (2005-2015)' started by memario1214, Jan 29, 2021.
Thread Status:
Not open for further replies.
  1. Jan 29, 2021 at 11:55 AM
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    SOLD SOLD SOLD
    Okay, it's time for all of you who have been collecting your chicken tendies to buy something! :spending: One of the last taco owning mod holdouts has fallen!
    The quick and dirty:
    • 2005 DCSB in Speedway Blue
    • Just under 200k on the ODO
    • No major mechanical issues that I am aware of. I would have no issue jumping in it and taking on a long road trip
    • Panels are all straight!
    • Other than needing a fabric shampooing the interior is more or less new. Minimal wear and tear.
    • I am asking $15,000 OBO as is
    Mods - Quite a few, but I'll hit the highlights:
    • TRD Supercharger installed at 125k. TRD Nose Drive was replaced in Feb 2019 with a Magnuson nose drive so it's a Frankenstein S/C now.
    • URD 2.825" Supergrip Pulley
    • URD Walbro 255 fuel pump kit w/ external fuel filter
    • AEM boost and AFR digital gauges in A-Pillar mount
    • Doug Thorley long tube headers
    • Custom exhaust (aero turbine 2525 w/ 14" resonator). Personal tastes have changed I think it's too loud now, but it does have an epic idle!
    • TRD Gen 1 CAI with red oilable filter
    • URD O2 simulators as there are no cats (I do have a set of rear cats in a box though if wanted)
    • FX-R 3.0 retrofitted headlights
    • HomerTaco Raptor Grill
    • Baja Designs Squadron Pro fog lights in a wide cornering pattern
    • Morimoto XB light bar in lower valence
    • Rago Fab ditch light brackets (currently empty)
    • OME Sport suspension all around w/ Dakar leaf pack (started as heavy duty kit. Removed one leaf and put in small block account stiff ride). Suspension has about 60k on it.
    • SCS Ray 10 wheels purchased Nov '18
    • Falken Wildpeak AT3W 285/70/17 tires also purchased Nov '18. Load E so plenty of life left
    • 09+ LED Tails
    • BAKFLIP Revolver X2 bed cover
    • Bedrug
    • Color Matched Pop N Lock (meh)
    • Aftermarket Pioneer Head Unit
    • Scangauge
    • Tach/Speedo color changed to white w/ Blue Needles
    • Weathertech DigitalFit floor liners in rear. Weathertech all-weather floor mats up front
    • ImMrYo rearview mirror relocation kit (AMAZING if you're tall like myself)
    • Cab Mount Chop w/ BAMF plates welded in
    Maintenance:
    • New UCAs and LCAs in spring of 18
    • New Carrier Bearing and U-Joints in spring of 18
    • New OEM steering rack in fall of 16
    • The rest has just been oil changes, pulley/belt replacements as necessary, etc
    The bad (because there's always something, and I believe in full transparency):
    • ABS and Brake (!) lights are on. The front left speed sensor failed, and since I hate the ABS sensitivity and cycle time in these trucks I never got around to replacing it. Certainly can though!
    • AEM AFR gauge has been working intermittently. I am thinking the connection to its power supply has been broken. Can do some digging on my end to solve.
    • I don't use the A/C much, but I have had to recharge it every year as I have never really been happy with it when just sitting. It doesn't seem to be very cold unless you're cruising at which point it'll ice you out. It's fine, and probably normal, but I'm in the spirit of transparency here!
    • The paint on the Homeroshi Raptor grille started to have the clear coat fail just this year. If you want it to look GREAT it's going to need a repaint or a different shell. I am sure that @HomerTaco could put a new shell on it no problem (he did not approve this message :D).
    • The truck spent a couple of winters in the Minnesota salt belt. While I cleaned the underside of it religiously it still was a victim to the surface level rust on it. It has been undercoated by Toyota twice, but it does leave the unsightly surface rust on the under-carriage. I have been underneath there multiple times and have noticed nothing aside from surface rust.
    • Has a cracked windshield that does NOT impact the sight line of the driver
    • Many of the blacked out pieces are Plasti-Dip (DERP). The hood scoop especially has a section that has started to come up a little bit. Could use a redo or a pull entirely.
    • The fuel door's bottom bracket has rusted and broken. The door seats in just fine you've just got to be a little more delicate with it to make sure you don't rip the whole thing off when opening/closing. Top hinge looks good.
    • When temps are cold one of the headlights doesn't like to come on sometimes. You just have to drive and hit a few bumps sometimes. Cycle the headlights once or twice and it'll kick on and stay on! Just kind of a weird quirk.
    Truck is located in Missoula, MT, and will be posted up locally as well as on AutoTrader. Now for moar pics. Ask away!
    IMG_0386.jpg IMG_0381.jpg IMG_0385.jpg IMG_0395.jpg IMG_0396.jpgIMG_0399.jpg IMG_0398.jpg
  2. Jan 29, 2021 at 12:09 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Less mileage than mine... GLWS! :thumbsup:
    Taco4Jaco likes this.
  3. Jan 29, 2021 at 5:28 PM
    800bman
    800bman Well-Known Member
    Joshua
    I don’t hate it
    memario1214[OP] likes this.
  4. Jan 29, 2021 at 5:45 PM
    memario1214
    Colton
    Missoula, MT
    BUT YOU WANT TO! :D
    But thanks! :rofl:
  5. Jan 29, 2021 at 5:47 PM
    800bman
    Joshua
    Love the color and the wheels tires motor stuff, just not the front fascia mods.
  6. Jan 30, 2021 at 8:49 PM
    FlorinDelAlba
    FlorinDelAlba Taco Connoisseur
    Florin
    Eugene, OR
    05 Tacoma V6 TRD 4x4 Black
    She is glistening
  7. Jan 31, 2021 at 8:08 AM
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Sad to see her go. Such a clean truck especially with those mesocustom taillights. Those are the sickest 2nd gen taillights Iv ever and probably will ever see. I’m still holding out that he’ll make another set.
    GLWS
  8. Jan 31, 2021 at 8:11 AM
    memario1214
    Colton
    Missoula, MT
    Well... The MESO tails aren't currently on the truck, nor are they part of the sale so... YEAAHHHH :spy:
    TL;DR they'll probably be for sale eventually.
  9. Jan 31, 2021 at 8:24 AM
    TheBlueBeast15
    Kevin
    H-Town
    I did notice they weren’t on the description I just figured you might have let them go to a friend off script or something. I stand corrected. I will be patiently waiting and thanks for the heads up.
  10. Feb 5, 2021 at 11:39 PM
    PinktacoDM84
    PinktacoDM84 Well-Known Member
    Dan
    BC
    2015 trd OR/AC
    St Maxx on Trd pro wheels, mbrp exhaust, k&n cai, jba's, 887's over 5100's, medium dakars and 5125's.
    One of a kind taillights? Yes pweeze
    Whatever BlueBeast offers... I’ll double it! :bananadead:
  11. Feb 6, 2021 at 10:29 PM
    Antler addict
    Antler addict New Member
    Jesse
    I'm interested and live in darby mt. Text me when you can. Four o six 3sixoh twotwothreefive.
  12. Feb 7, 2021 at 7:28 AM
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    Do you have pics of these tail lights I know you're not selling them currently I just wanna know what the hype is about
  13. Feb 7, 2021 at 2:24 PM
    PinktacoDM84
    Dan
    BC
    2015 trd OR/AC
  14. Feb 7, 2021 at 2:33 PM
    MickDog13
    MickDog13 Well-Known Member
    Cortland NY
    2008 Speedway Blue TRD OR DCSB
    Nice truck & Nice dude!
    wish you weren’t a thousand miles away I’d trade you for your scoooop!
  15. Feb 7, 2021 at 5:04 PM
    lm546
    lm546 Well-Known Member
    Craig
    Tucson, AZ
    2015 dcsb OR, 2002 double cab, 1985 Toyota pickup
    If you were closer, I would be very interested.
    Nice truck and good luck with the sale.
  16. Feb 7, 2021 at 6:53 PM
    Antler addict
    Jesse
    How do I get a hold of you? I live about an hour away and want to check it out.
  17. Feb 8, 2021 at 8:52 AM
    memario1214
    Colton
    Missoula, MT
    It's FAKE NEWS! But since you asked...
    https://www.tacomaworld.com/threads/memario1214s-jafr-build.181165/page-86#post-16563753
    I did nothing. I was quiet as a church mouse!
    Haha SKEWPS for everyone! No ragrets.
    Fired you over a text
  18. Feb 8, 2021 at 11:26 AM
    PinktacoDM84
    Dan
    BC
    2015 trd OR/AC
    @memario1214
    wow. Those are way beyond what I thought they would be! I love the double signal light up. Did meso literally only ever make one pair or just not making them now
  19. Feb 8, 2021 at 9:39 PM
    Taco4Jaco
    Taco4Jaco Well-Known Member
    Jacob
    Sacramento
    White 2005 TRD OR
    glws @memario1214 i like it a lot i’m sure someone else will too
  20. Feb 14, 2021 at 11:23 AM
    memario1214
    Colton
    Missoula, MT
    AND SHES GONE :pout:
Thread Status:
