SOLD - 2008 Tacoma SR5 V6 6sp Access cab, lifted, 33"s, cap, stereo, 75,000 miles
Discussion in '2nd Gen Tacomas For Sale (2005-2015)' started by dullers, Jun 24, 2016.
Thread Status:
Not open for further replies.
  1. Jun 24, 2016 at 10:44 AM
    dullers
    dullers [OP] Member
    Burlington, VT
    08 Taco SR5 V6, lift, tires, etc.
    Moto Metal 951, 285/75r16, full spare, BHLM & tails, TSB AAL & OME AAL, OME coils & spacers, OME shocks, diff drop, driveshaft drop, TRD cat-back, Airaid intake, Leer 180cc, extensive stereo/carputer
    SOLD SOLD SOLD SOLD
    Located in Burlington, VT
    local craigslist ad: http://vermont.craigslist.org/cto/5651536440.html
    more pics: http://imgur.com/a/JOtoN
    Asking $19,995 or best reasonable offer
    *not interested in any trades*
    Please email: dullers (at) gmail [dot] com
    One owner - I bought it new from Heritage Toyota, Burlington in 2008. Selling because we're moving and it doesn't make sense to bring it with us. Otherwise I'd easily keep & drive this truck another 8-10 years. It's in amazing shape. I take very thorough care of it and keep detailed service records. Frame is in amazing shape (wax undercoating from day 1 and again in 2016). I keep it very clean, car-washes once a week in the winter. It was fully detailed recently, in & out, clay bar, wax, carpet/seat shampoo, etc. on 6/15/2016. It's an absolute blast to drive. I get plenty of compliments on it. The stereo sounds great, the intake/exhaust sounds mean. The 4.0L V6 has a surprising amount of pull given the tires and weight.
    It's really a perfect mid-size all-purpose truck; camping, hauling, road-tripping, you name it. I'll be sad to see it go; hopefully to another Taco enthusiast that'll treat it right :)
    Thanks for looking!
    Tires/wheels
    Brand new Goodyear Duratrac LT285/75R16 tires (33" x 11.25") - Tires only have 2,300 miles on them.
    Moto Metal MO951 Gloss Black Wheels (16x8"/6x139.7mm, 0mm offset)
    Full-size spare rim & tire
    3" Lift kit
    OME (Old Man Emu) Lift coils, 884s with top plate spacers
    Swapped in TRD spring pack
    Deaver add-a-leaf rear springs
    Driveshaft carrier bearing drop kit
    OME-N182 rear shocks
    OME-90000 front shocks
    Also added Firestone "Ride-Rite" air bags to help with added cargo weight. Can be inflated from 10-100psi. Roughly 40lbs per 1psi. I run them at about 50psi and it's a little stiff without a load.
    Stereo
    clarion EQS746 equalizer
    Boss Audio am/fm head unit
    Audiobahn A4002T amp (subwoofer)
    Kicker ZX350.4 (speakers)
    Polk DB6501 2-way crossovers with tweeters front speakers
    Polk DB651 2-way rear speakers
    Kicker CVR 12" subwoofer
    New wires throughout
    Engine/Drivetrain
    Amsoil cold air intake
    TRD Exhaust
    URD Stage 2 clutch & pressure plate
    ARP Flywheel bolts & Pressure plate bolts
    Re-surfaced flywheel
    URD Throwout bearing & sleeve kit (fixes Toyota's flawed stock throw-out bearing issue)
    Exterior
    Depo Blacked-out headlight housings
    Tinted tails (2nd set of non-tinted tails included)
    SYLVANIA SilverStar zXe Halogen Bulbs
    Leer 180 Fiberglass Cap with slider windows front & sides
    Yakima roof tracks on cap, with adjustable low-pro crossbars
    Reinforced roof rack with additional bolts & plywood
    Roof basket
    Camping/Cargo shelf built into bed (easily removable)
    4x Innovations swing-away rear tire carrier with built in Class 3 hitch and fold-down cook tray. Includes hitch ball & mount (I think it's a 2" ball & 5" drop). Includes 2x tow shackles. 4-plug trailer wiring
    Misc.
    Marlin Crawler shift knob
    3x original keys, master key, 2x key fobs
    Spare Deaver add-a-leaf included
    Weathertech Floor mats
    Recent Maintenance highlights
    Current mileage on 6/24/2016 - 75,001
    Toyota/OEM Wax undercoating applied at 0 miles
    Wax Re-applied (due to frame-rust recall) at 72,993 miles
    New Rear brakes & ebrake cable - 72,993
    AC system recharged - 72,993
    New Tires & Alignment - 72,620
    Oil changel Mobil 1 synthetic & Toyota OEM filter - 72,620
    Spark plugs, cabin air filter, drive belt - 61,415
    rear differential fluid change (Redline Synthetic) - 61,415
    new front OEM rotors & pads - 62,415
    Clutch, flywheel, throw-out bearing service/replacement - 58,972
    Changed transmission fluid (redline synthetic) - 58,972
    Changed front differential fluid & transfer case fluid (redline synthetic) - 39,634
  2. Jun 25, 2016 at 4:39 AM
    DropZone_727
    DropZone_727 Member
    Great looking truck. I'm hoping to get into something like this soon. Any pics underneath?
  3. Jun 26, 2016 at 11:12 AM
    dullers
    dullers [OP] Member
    Burlington, VT
    Thanks! It's a great rig. I really like it. I'll get some pics underneath later tonight when the sun drops. It's too bright to get a good shot right now.
    I'm in Vermont... so roads get salted. I don't drive on a dirt roads so it's not getting "sand blasted". But the salt does certainly affect it.
    For an 8 year old new england truck, though, the frame and undercarriage is in amazing shape. It's JUST starting to get superficial surface rust in places where the wax undercoating didn't cover or has worn away.
    I'll follow up in a few hours with some pics.
    Thanks for your interest!
    -Chris
  4. Jun 26, 2016 at 11:44 AM
    dullers
    dullers [OP] Member
    Burlington, VT
    Managed to get a few decent shots that aren't washed out.
    #1 and 2 are the engine bay. #1 you can see the wax (or whatever it is that Toyota offers) coating. #2 you can see some typical bolt head & seam rust starting. I have yet to experience a broken bolt. And everything gets copper-based never-seize whenever I do work on it.
    #3 you can see the undercoating underneath & where it's started to "wear" off. It's pretty rugged stuff. I'll continue to get the undercoat on all my vehicles.
  5. Jun 27, 2016 at 4:04 AM
    DropZone_727
    DropZone_727 Member
    Thank you. I work offshore, if it's still available in a couple weeks when I return I'll get in touch.
  6. Jun 27, 2016 at 6:30 AM
    dullers
    dullers [OP] Member
    Burlington, VT
    Cool just let me know!
  7. Jun 27, 2016 at 6:41 AM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
  8. Jun 27, 2016 at 6:45 AM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
    Hate to be the one to ask... But would you be willing to part out?
  9. Jun 27, 2016 at 6:47 AM
    dullers
    dullers [OP] Member
    Burlington, VT
    haha. All good. Unlikely I'll be parting it out. If I can't sell it in a few months... maybe. I don't have any of the stock parts (rim, susp., etc.) so it'd be hard. Only stock original parts I still have are the taillights :D
  10. Jun 27, 2016 at 6:05 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Hey @dullers, got to see your truck in person at Matt's Wash & Wax when dropping mine off! That's a solid build man. Makes me want to get mine lifted with 33's ASAP. I'm sure you'll be sad to see it go when the time comes. Best of luck with the sale.
  11. Jun 27, 2016 at 6:19 PM
    dullers
    dullers [OP] Member
    Burlington, VT
    ha! Thanks for the props Brenden! That's really funny. It's definitely bittersweet. I'll build another one someday...
    And How about Matt's Wash & Wax? How awesome are they? I'm super happy with the results. I'd absolutely go back there again.
    MadRiverTaco likes this.
  12. Jun 27, 2016 at 6:32 PM
    MadRiverTaco
    Brenden
    Waterbury, VT
    Yes, they are professionals no doubt. I've recommended them to quite a few people already.
  13. Jun 29, 2016 at 6:58 AM
    90goldtsiawd
    90goldtsiawd New Member
    Truck looks great. I have a pending sale on my T4R and will be interested in your truck when this goes through if it's still available.
  14. Jul 1, 2016 at 12:48 PM
    dullers
    dullers [OP] Member
    Burlington, VT
    SOLD TODAY!
    Sad day, but it went to another member. Great dude, glad it's going to another outdoor/tacoma enthusiast. Nothing worse than selling your prized vehicle to a bad home lol
    Thanks all for your interest!
    Cheers
    -Chris
Thread Status:
