SOLD - 2009 Access Cab TRD Off-road 4x4 Auto 4.0 with TRD S/C - VA
Discussion in '2nd Gen Tacomas For Sale (2005-2015)' started by spithead051, Aug 29, 2022.
Thread Status:
Not open for further replies.
  1. Aug 29, 2022 at 5:02 PM
    spithead051
    spithead051 [OP] Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    2009 Toyota Tacoma TRD Off-Road
    4x4 - Automatic V6
    TRD Supercharger
    74k miles
    Northern Virginia
    $23,000 - Negotiable
    DM me on here or email me at spithead051@gmail.com
    The time has finally come for me to let go of my Taco. I am the original owner and purchased this in June 2009 from a local dealer. This truck has been dead reliable and I have always stayed ahead of maintenance and addressed issues as soon as they occurred. The truck was garage kept for 12 of the 13 years I owned it and I have kept record of the service history as well as receipts for nearly all of the parts on the truck today. It is an absolute blast to drive with the supercharger. It drives completely normal until you give it some gas and then it screams.
    Title is clean, I have a few boxes of OEM parts, a 5th matching T/X pro wheel, and a few mods that were never installed that will all be included.
    She's turn key ready to go for the next owner. No upcoming maintenance or delayed repairs anytime soon.
    Mods:
    Performance:
    TRD Supercharger
    Upgraded coupler
    2.85" URD stealth pulley
    aFe Stage 2 si intake with aluminum TRD cover plate
    Gibson catback exhaust
    Walbro 255 LPH fuel pump with fuel regulator mod
    Other under hood mods:
    ARB CKMA12 air compressor mounted to power steering reservoir mount
    Wired into cab with OE-style switch under climate controls
    Redline hood struts
    Underhood LEDs
    Winch solenoid relocated under hood
    TRD oil cap
    TRD radiator cap
    Oversized oil filter and sandwich plate (for gauges)
    Bulletproof Fab cooling panel
    Fumoto oil drain valve
    Suspension:
    Icon 2.5 VS extended coilovers with CDC and 700 lb springs
    Icon 2.5 VS extended rear shocks with CDC
    Dakar leaf springs with angle blocks to eliminate driveline vibration
    Dirt King UCAs
    Dirt King LCAs
    Total chaos alignment cam tab gussets
    Total chaos spindle gussets
    U bolt flip kit
    Icon rear bump stops
    Wheelers front bump stops
    Extended brake lines on all 4 corners
    Wheelers carrier bearing spacer
    Exterior:
    All Pro Apex front bumper with black powdercoat
    All Pro bolt on sliders with black powdercoat
    All Pro front IFS skid plate
    Smittybilt x20 10k winch with synthetic line and Factor55 prolink
    Heretic design quad fog lights
    Phillips LED headlights
    OEM TRD Sport hood
    OEM TRD Sport grille
    Aluminum Toyota devil horns in silver
    TRD T/X Pro 16" wheels in black (Includes a matching 5th)
    BF Goodrich Mud Terrain KM2 255/85/R16
    EBC slotted rotors, plenty of life left
    Hawk LTS brake pads, 50% pad life left
    Blacked out OEM badges
    No cab mount chop or other items cut away for lift
    Shorty antenna (I still have the OEM one)
    2012+ Mirrors with sequential LED turn signals
    All exterior bulbs converted to LED with resistors as applicable
    Locks on bed storage bins
    Smittybilt hitch shackle mount with truck keyed locking hitch pin
    OEM bed rail hooks
    Front D-rings added
    OEM rubber bed mat
    Interior:
    Glowshift Oil pressure, oil temp, and boost gauges
    AEM wideband AFR gauge
    LCE performance OE look a-pillar gauge mount
    URD flexpod
    Scangauge II with transmission temp reading
    Kenwood DNX691HD head unit
    Alpine speakers in front doors
    Metra black head unit surround
    Blacked out climate control and shifter trim bezels
    LED backlit 4x4 dial
    Wet Okole seat covers with TRD Off Road stitching, passenger seat bottom has two small tears, underlying factory seat fabric is in excellent shape
    Weathertech FloorLiner floor mats with TRD Off Road emblems
    50% tint on front windows (legal limit in VA)
    Blackvue 650 2-CH dashcam with parking mode module
    Entire cab is sound deadened
    Maintenance items:
    Oil changed 9/1
    Aligned on 9/5, have the chart if desired
    Transmission fluid changed 15k miles ago
    Power steering 15k miles
    Coolant was done 15k miles, both loops
    Brake fluid was changed in the last two months
    Diffs/transfer case 15k miles ago
    Tires are four years old with ~20k miles on them
    AC was serviced in 2019 after the low pressure service port developed a leak
    Supercharger serviced 15k miles ago - snout oil, replaced coupler, re-greased needle bearings Spark plugs changed 10k miles ago, OEM iridium plugs due to SC
    Useful things:
    Driver side CV joint was replaced with a new OEM one in February
    Toyota coated frame twice, once in 2015 and again in 2019 - frame is in great shape, some mild surface rust but no areas of concern
    15ACOR, dj4230 and fatfurious2 like this.
  2. Aug 31, 2022 at 8:19 AM
    spithead051
    Patrick
    Fairfax, VA
  3. Aug 31, 2022 at 8:20 AM
    spithead051
    Patrick
    Fairfax, VA
  4. Aug 31, 2022 at 8:20 AM
    spithead051
    Patrick
    Fairfax, VA
  5. Sep 2, 2022 at 12:11 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Bump for a clean truck. Plus rare parts too
    spithead051[OP] likes this.
  6. Sep 5, 2022 at 10:33 AM
    spithead051
    Patrick
    Fairfax, VA
    bump, truck has had the oil changed and alignment dialed in, she's ready for a new home!
    fatfurious2 likes this.
  7. Sep 6, 2022 at 2:30 PM
    spithead051
    Patrick
    Fairfax, VA
    bump, price dropped to 23k
  8. Sep 9, 2022 at 2:03 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Dang ,someone will grab this right up !
  9. Sep 11, 2022 at 8:33 AM
    spithead051
    Patrick
    Fairfax, VA
    weekend bump!
  10. Sep 11, 2022 at 9:10 PM
    fatfurious2
    David
    Ashburn, VA
  11. Sep 12, 2022 at 10:05 AM
    RoaminRoman
    RoaminRoman Well-Known Member
    Roman
    2000 4Runner
    Midtravel Camping Fun Haver
    Woah, what a steal! If I wasn't enjoying my older 4Runner so much, I'd be all over this. I hope a fellow enthusiast buys this, I give you mad props for not price gauging in today's crazy market. Best of luck with the sale, someone's going to walk away lucky and very happy with this beauty!
  12. Sep 12, 2022 at 6:08 PM
    spithead051
    Patrick
    Fairfax, VA
    sale pending
  13. Sep 13, 2022 at 6:00 PM
    spithead051
    Patrick
    Fairfax, VA
Thread Status:
