SOLD: 2013 Tacoma SR5 DCLB - RC62F Manual Swap - 110k miles - CO
Discussion in '2nd Gen Tacomas For Sale (2005-2015)' started by anothernord, Nov 5, 2024.
Thread Status:
Not open for further replies.
  1. Nov 5, 2024 at 9:51 AM
    anothernord
    anothernord [OP] Well-Known Member
    Northern Colorado
    Various Toyotas
    DCLB Manual
    This was going to be my "forever" truck, but we've outgrown it. No vehicle has ever been harder to decide to part with.
    My approach with this build was to make an ultra-simple, absolutely 100% reliable rig to daily drive to work and putt around old mining roads during the summer in CO. It's a nod to the no-frills Toyotas of the 80s and 90s.
    I personally completed a manual swap using a 3rd gen RC62F (much better ratios than the 2nd gen RA60F). All factory or OEM parts used. It is as close to a factory conversion as I think you can get. I went to great lengths to make sure the ABS and cruise systems work perfectly and there are zero codes or CELs. You'd really never know that it didn't come from Toyota like this. Toyota never offered the 6MT with this cab and bed combination.
    Other highlights:
    - ALL maintenance done, everything ever done to the truck is in a spreadsheet
    - Totally rust free (2nd owner, first in AZ)
    - ARB bumper (pre-facelift version that doesn't stick out as far)
    - Earlier tail light conversion with LED bulbs
    - ECGS front diff bushing
    - 18-20 MPG, tracked on every fill-up
    - Bilstein 5100 front, AAL with overload in the back
    - 2WD low-range mod
    - Redarc brake controller
    - New Gates main belt
    - Custom engine tune (less aggressive rev-hang and tuning to optimize VE)
    - New OEM Toyota lower control arms/ball joints, welded cam tabs
    - If there's a fluid on board, it has been flushed or replaced according to proper intervals
    - Diode Dynamics SS3 Pro round amber fogs
    - <10k miles on Cooper Discoverer AT3 4S 265/75/R16 + matching spare rotated regularly
    - Rear view mirror relocation bracket
    - Problems:
    040 Super White paint woes - only really an issue around the window front window frames - see photos. It is present in the engine bay and a bit between the bed and cab but you don't really notice it in those spots. TPMS system is currently disabled but can be wired back to stock if you wish. The radio screen backlight sometimes inverts colors when it's cold, but it hasn't done that for a while.
    $25k - located in Fort Collins, CO
    PXL_20240821_015929054.jpg PXL_20240821_020005578.jpg PXL_20240821_020035294.jpg PXL_20240821_020044560.jpg PXL_20240821_020102664.jpg PXL_20241102_231233332.jpg PXL_20241102_231203476.jpg PXL_20241102_231145929.jpg PXL_20241102_231237170.jpg PXL_20241102_231505502.jpg PXL_20241102_231826512.jpg PXL_20241102_231850266.jpg PXL_20241102_232058099.jpg PXL_20241102_231644213.jpg PXL_20241102_232133695.jpg PXL_20241102_231644213.jpg PXL_20241102_231622450.jpg PXL_20241102_231655408.jpg PXL_20240821_020148856.jpg PXL_20241102_232022866.jpg
  2. Nov 21, 2024 at 5:26 PM
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    Bump, possibly open to trades for a Tundra or GMT800.
  3. Dec 1, 2024 at 2:50 AM
    jjgandarillas
    jjgandarillas Well-Known Member
    joseph
    Anc, AK
    SPORT DCSB MT
    ICON 2.5 VSRR, icon 2.0 ext travel, UCA’s, Ray 10 17x8.5 -12, 285/70r17 BFG Ko2
    ive wanted to do this so bad, i might have to pick your brain a little.
  4. Feb 13, 2025 at 3:28 PM
    cheezoto
    cheezoto Well-Known Member
    1KD Diesel ACLB, Supercharged DCSB
    Wow, super clean, great setup, and big kudos to you for the 6MT swap.
    anothernord[OP] likes this.
Thread Status:
